New Samsung HD DVR from Time Warner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 03-23-2008, 10:54 AM - Thread Starter
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Has anybody tried the new HD DVR that Time Warner is now offering. I hear it is made by Samsung. I spoke to a Time Warner tech and he said this is the best DVR he has seen.
HeffeMusic is offline
post #2 of 24 Old 03-25-2008, 11:54 AM
slickshoes's Avatar
What area are you in??
Crime Warner MDN 2.4.4-16
slickshoes is offline
post #3 of 24 Old 03-26-2008, 09:02 PM
phousley's Avatar
What software is it using?
SA8300HDC - ODN 5.2.0_9 - 1TB eSATA
phousley is offline
post #4 of 24 Old 07-01-2009, 10:00 PM
DAVIDRN's Avatar
I have a new Samsung SMT H-3090 HD/DVR from Time Warner in South East Wisconsin. Works Great with my new Samsung HD TV.. Small Hard Drive 160GB only allows for 15 hours of HD storage. Looking for a DVR expander to the E-sata port. The western digital one looks good but can only find listed compatabilities with SA8300 or TiVo. Any one tried this on the Samsung Box???
DAVIDRN is offline
post #5 of 24 Old 07-02-2009, 09:38 PM
intheb0x's Avatar
damnit!
im also in southeastern wisconsin and just got installed with the 8300hdc
i want the samsung to match my tv.
is it any better???????
could i take it in and get a swap?
intheb0x is offline
post #6 of 24 Old 07-03-2009, 03:02 PM
RobioAXP's Avatar
Raleigh, NC will be testing the Samsung units in the next few months. I imagine there will be a mix of the Samsung's in the Triangle by year-end.
RobioAXP is offline
post #7 of 24 Old 07-03-2009, 03:40 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
Sammies have been out in Charlotte and other markets for several months. Still some kinks to be worked out.
Much more here:
http://www.avsforum.com/avs-vb/showthread.php?t=1152474
and here (starting around April timeframe - about at the page referenced here):
http://www.avsforum.com/avs-vb/showt...=3090&page=254
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #8 of 24 Old 07-05-2009, 09:28 PM
Echo Three's Avatar
I'm in NYC and just got the SMT-H3090 (160GB). After recording 7 movies and a couple of half hour shows, the hard drive was already 90% full. I connected the WD 1TB Expander (eSATA) and followed the installation instructions. First reboot did not seem to take. So I unplugged everything and started again. I then followed the onscreen intructions and waited for everything to finish (NOTE: The 3090 reboots twice during reformat/installation). The entire procedure took about half an hour. The DVR turned itself off when reformatting was complete. I turned the box back on and noted that the hard drive was now 10% full.
Word of advice: Do not turn off the DVR during the installation procedure, even if you think nothing is happening. Just follow the instructions (both printed and onscreen) and you'll be fine.
Echo Three is offline
post #9 of 24 Old 07-05-2009, 09:41 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
There have been similar reports before (succesful installation, recognizes added capacity, etc.) but the box has not been able to record more than its internal capacity. Have you added any recordings beyond what was represented by the original 90%?
post #10 of 24 Old 07-07-2009, 12:38 AM
Echo Three's Avatar
Originally Posted by jcalabria View Post
There have been similar reports before (successful installation, recognizes added capacity, etc.) but the box has not been able to record more than its internal capacity. Have you added any recordings beyond what was represented by the original 90%?
Yes, I recorded 7 more movies (in HD), plus a couple of one hour programs (also HD). So there are about 17 recordings in the DVR's library. Hard drive is now 11% full (up from 10).
post #11 of 24 Old 07-07-2009, 12:05 PM
hdtvfan2005's Avatar
I'm glad that you got eSATA to work. Keep us updated if it has any problems.
hdtvfan2005 is offline
post #12 of 24 Old 07-07-2009, 12:07 PM
Raleigh, NC could start testing the 32xx boxes instead of the 30xx ones. The Samsung 3260 is a nice looking box. Looking forward to try out the 3270.
post #13 of 24 Old 07-07-2009, 08:21 PM
Echo Three's Avatar
So, yes, I was able to record seven more HD movies. But I just looked at the new recordings. Only the first six minutes of each movie was actually recorded. So maybe it's not possible to expand beyond the original HD capacity. Or maybe I just need to delete everything recorded before the DVR Expander was added, then start recording programs again.
Suggestions?
post #14 of 24 Old 07-21-2009, 11:43 AM
srepstein's Avatar
I had a SCI ATL 8300 VR w/ an Apricorn SATA attached via ESATA
THe Box had some issues and TW s=came and just gave me a 3090
It sees the SATA port but will not format it..
Apricon had no clue and has sent me to Samsung oit see if TW has the port on.. It sees the hardware on sata but dies not format
Steve
srepstein is offline
post #15 of 24 Old 07-30-2009, 06:25 PM
clang81969's Avatar
Suggestions?
I am in NYC I have the samsung 3090.
I installed the WD DVR 500gb expander.
After a couple of tries it was recognized and I was prompted to format it.
After the reboot the DVR dropped from 50% full to 10%.
Once I got to about 17% it started to delete older material to make room for new recordings.
I called Time Warner, they dont support it.
I called WD, they don't support the dvr expander.
TW also supplies the SA 8300HDC but WD said they didnt support that either.
clang81969 is offline
post #16 of 24 Old 09-21-2009, 05:38 PM
bnate5's Avatar
I am in the NYC Area and have the same problem
I reset the cable box and DVR twice.
I am to del stuff I wanted to start recording again and I had to change
the settings on saved stuff to NEVER DEL.
Bnate5 Here!
bnate5 is offline
post #17 of 24 Old 09-24-2009, 01:19 AM
The Samsung SMT-H3270 now works with Start Over and VOD thanks to SW v4.2.2.3 dated 8/16/09.
post #18 of 24 Old 09-24-2009, 10:44 AM
humdinger70's Avatar
Quoted: 261 Post(s)
Liked: 177
Moderator, please merge this topic into the existing thread for the Samsung 3090/3270 DVRs.
humdinger70 is offline
post #19 of 24 Old 07-28-2010, 06:40 PM
Echo Three's Avatar
So buying the DVR Expander was a waste of money. That blows. There's supposedly a new cable box out. Don't know if the Expander would work with it.
post #20 of 24 Old 07-31-2010, 03:05 PM
cam94z28's Avatar
Suggestions?
Mine has just started doing this without having a External drive hooked up. Every new, scheduled show is exactly 7 minutes long. It records the active channel just fine though, and if I hit record in the middle it will save the entire thing. Also, if I delete a few of the 7 minute shows it will record full length for a while. I'm about to take the box back but wanted to see if anyone else solved the problem. Probably a year ago I had a External hard drive installed, but removed it. Haven't had any issues until recently, right after the recent firmware update for the 8300HDC, of which I have 3 in the household. I have the SMT-H3090.
cam94z28 is offline
post #21 of 24 Old 08-05-2010, 03:03 PM
Echo Three's Avatar
My 3090 crapped out on me last week. At the Time Warner office I asked if there were any new boxes available. I was told, "Yes, but we don't have them in stock." So I settled for the same Samsung box. However, this one recognizes the WD 1 TB DVR Expander. I know this because I taped about 8 movies and 6 or 7 one hour programs, just as an experiment. I set the record options for each program to "Do Not Delete." Everything recorded and nothing was deleted. I have about 24 hours worth of recorded programs on the hard drive, all in HD. The drive reads 44% full.
Awesome.
post #22 of 24 Old 12-11-2010, 05:42 AM
bobbis's Avatar
Is TWC in Cary giving out these boxes? I'm interested in replacing my old SA8300HD. Also, do they have the larger capacity drives in them?
Trying to understand all of this
bobbis is offline
post #23 of 24 Old 12-13-2010, 03:38 PM
They might have the SMT-H3270 with a 320 GB HDD, and a SMT-H3272 with a 500GB HDD, but the latter is only for SH customers.
post #24 of 24 Old 12-07-2013, 07:18 AM
Scuba767's Avatar
It's a great big POS!!!!!
I signed up with TWC 2 weeks ago and it worked great for 3 days. Then problems! Problems! Problems!
Today....it will not even reboot and my wife's getting the run around from Customer service!
Back to dish!
Scuba767 is offline
Reply HDTV Recorders
