Are all Dish 5000's upgradeable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-25-2001, 07:39 AM - Thread Starter
cgott42's Avatar
Quoted: 157 Post(s)
I've located a Dish 5000 (refurb) for $160.
Can it be used with a modulator to allow me to connect to hipix and record HDTV?
The info :
5000rr
$ 159.00
5000 Receiver and Remote (Factory Refurbished)
The original model 5000 Receiver and Remote with integrated Off-Air channels included in the Guide Menu. Caller ID, UHF Controlled, IR Blaster and Event Timers.
Like New with 1 year Parts and Labor Warranty through
cgott42 is offline
post #2 of 3 Old 12-25-2001, 09:14 AM
ROBERT HUNZEKER's Avatar
Yes, the dish depot refurbs will work just fine with the modulator.
Bob H.
ROBERT HUNZEKER is offline
post #3 of 3 Old 12-25-2001, 10:09 AM
Ken H's Avatar
The 5000's themselves are relatively easy to find, even though they are discontinued. The problem will be the HD Modulator.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Recorders
