Panasonic STB Factory Repair... My Experience - AVS Forum | Home Theater Discussions And Reviews
Old 01-03-2002, 12:37 AM - Thread Starter
LarryB's Avatar
When my Panasonic TU-DST51A digital decoder was hooked up to my Panasonic PV-HD1000 D-VCR via the firewire cable the display indicated the D-VCR was “NOT PRESENTâ€.
Thanks to suggestions from you guys I checked the firewire sockets on both the STB and the recorder with a magnifying glass and one of the pins broke away from the socket in the STB.
Gridleak and others suggested replacing the socket myself, but I was too chicken. So I sent the unit to Elgin, Illinois for repair. The turn-around time was 7 weeks. Yep, 7 long weeks! I went through HD withdrawal!
The repair summary:
DV Jack (VJJ0568)..............7.65
S-Panel (TNP2AA039S)......324.04
Labor.................................50.00
Parts..................................331.69 \ t
Shipping.............................30.00
Total...................................411.69 Yikes!
To those in the know... What’s an “S-Panel� And Gridleak... If I tweak my pin again can I bring it over to your place for a lesson in repair???
Larry
LarryB is offline
Old 01-03-2002, 07:48 AM
cnixon's Avatar
Wow! I fixed a broken firewire socket on one of my TU-DST51s last March for about $2.50 at Fry's and an hour fiddling at home.
Charles
cnixon is offline
Old 01-03-2002, 07:25 PM
gridleak's Avatar
Larry... bring decent wine.
BTW, the S-board is the ATSC tuner. It's over $400 on the panny website, so you did ok if the tuner was weak.
-Roger
gridleak is offline
