Cast Away - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2002, 07:59 PM - Thread Starter
AJSJones's Avatar
Quoted: 96 Post(s)
Liked: 24
Maybe I screwed up twice trying to record this for viewing at 8pm west coast time or it was "Copy never"
Anyone else record it? If so, I must be losing my brain-hand-eye coordination.
I successfully recorded some of the boxing following the movie on the same tape on which Cast Away came out black. I didn't notice any alerts about "cannot copy". I used the DTV controls on the remote (as opposed to the VCR controls from the STB menu) for both Cast Away and boxing.
:confused:
Andy
AJSJones is offline
post #2 of 4 Old 01-05-2002, 08:05 PM
waters's Avatar
I just spot checked my tape of Cast Away and it looks fine. I set up using the timer on the VCR as always. I think its broadcast again a little later so you can try again..
waters is offline
post #3 of 4 Old 01-05-2002, 10:25 PM - Thread Starter
AJSJones's Avatar
Quoted: 96 Post(s)
Liked: 24
Thanks - I usually use the timer but had to change tapes since I didn't have a 160 on hand! I knew there was something weird about how to set it recording but don't understand how I got the boxing to tape using what I thought was the same commands from the remote. Oh well, I'll pick up some more 160's, refresh the brain and try again!
Andy
AJSJones is offline
post #4 of 4 Old 01-06-2002, 10:21 AM
bb1987's Avatar
recorded it with no problems. I don't think any HBO movie will ever be record never.
When playing back there was no CP shown on the VCR which is the case with BS tapes that have record once copy protection. It also copied perfectly to another tape.
Bernhard
bb1987 is offline
Closed Thread HDTV Recorders
