Pace TDC787X (aka Aspen) Release Notes Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-28-2008, 12:34 PM - Thread Starter
lindend's Avatar
This thread will only contain release notes for Pace TDC787X (a.k.a. Aspen) firmware releases. Please don't ask questions on this thread as it is strictly for release notes. General Aspen questions, or specific questions about releases can be posted on the Aspen CableCARD thread.
Linden
Pace Americas, Inc. (note the views expressed here are my own and not necessarily those of Pace).
lindend is offline
post #2 of 9 Old 07-28-2008, 12:44 PM - Thread Starter
lindend's Avatar
Disclaimer: Please don't ask (or PM me) if/when your local cable company is going to roll out this release or if/when your cable provider will deploy Aspen boxes.
Since this is the first release out of the gates, its bug free. On a serious note, there are fixes in this release, but they would only be relevant to beta testers so I won't post them here.
Known problems:
1. After boot, front panel brightness settings may be lost.
2. Closed caption rendering artifacts.
Linden
lindend is offline
post #3 of 9 Old 09-15-2008, 11:17 AM - Thread Starter
lindend's Avatar
Disclaimer: These are highlights from the release notes with issues that are relevant to AVS users.
1. Fixed One Moment Please (OMP) when swapping to a tuner. Symptoms also may include missed recordings.
2. Slow forward doesn't work on Music Choice (MC) channels.
3. Diags dashboard shows red on Inband Tuner Errors field (short term error indicator not accurate).
4. Front Panel Brightness Settings lost after reboot.
Linden
lindend is offline
post #4 of 9 Old 12-03-2008, 12:55 PM - Thread Starter
lindend's Avatar
  1. Audio loss after 7 seconds on some channels (mostly VOD though)
  2. Loss of closed captions after swap from HD to SD.
Linden
lindend is offline
post #5 of 9 Old 01-14-2009, 02:14 PM - Thread Starter
lindend's Avatar
  1. VOD fix
  2. Audio breakup when playing some VOD content.
  3. Closed captions lost when surfing between SD and HD.
  4. HDD spin down temporarily removed when going into standby.
Linden
lindend is offline
post #6 of 9 Old 04-27-2009, 10:36 AM - Thread Starter
lindend's Avatar
  • DVR functionality lost and requires a reboot to recover
  • Ch. 1 on the front panel when coming out of standby
  • Time drift causes recordings to start late
  • Garbaled news ticker on channels such as Fox News/Bloomberg etc.
  • Screeching audio on HDMI if you surf to an unauthorized channel
  • False overheating warning
  • TVG messages show up after being deleted.
  • TVG messages re-appear in standby after they expire.
  • A/V dropouts on HDMI after a hot plug.
  • Seachange VOD client shows One Moment Please (OMP) during navigation.
  • 1 TB and larger drives are now supported.
  • Frozen video on some channels
Linden
lindend is offline
post #7 of 9 Old 08-09-2009, 09:25 AM - Thread Starter
lindend's Avatar
  • Infinite CableCARD reset loop
  • Garbled news ticker on channels such as Fox News/Bloomberg etc.
  • Frozen/stuttering video after a channel change.
  • False lock on invalid OOB frequency.
  • Discrete caption and resolution codes.
Linden
lindend is offline
post #8 of 9 Old 05-26-2010, 05:27 PM
stbfan4m's Avatar
Can anyone advise me as to the processor used for the TDC787x?
stbfan4m is offline
post #9 of 9 Old 03-28-2012, 01:55 PM - Thread Starter
lindend's Avatar
  • Audio muted under some scenarios when RF bypass is enabled
  • Memory leak fix
  • SDV tuning speed improvements
  • SDV channel surfing fix
  • PVR authorization from headend now more robust
  • Improved performance on 128MB units
  • Fix for blank one time recording when box is in standby
  • CallerID fixes
  • PPV fix with certain equipment
  • Work around NAOU error after swapping to an unauthorized channel
  • False disk full message displayed after formatting HDD
Linden
lindend is offline
Reply HDTV Recorders
