VOD: Delete a movie listed in "in progress" list? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-19-2008, 09:27 PM - Thread Starter
cu_shane's Avatar
Quoted: 46 Post(s)
I am in the Carolinas. I use Time Warner Cable on a Scientific Atlanta 8300HDC running Mystro.
Whenever I watch a free on demand movie/show it lists it under "in progress". Even once I have finished watching it, it stays in the list. When I press info it gives me the following options: Resume Play, Restart, Back to List, Exit. No delete!
How can I clear a movie from the list? If I can't does it automatically clear after a certain amount of time?
cu_shane is offline
post #2 of 5 Old 09-20-2008, 01:25 AM
BeachComber's Avatar
When you select it in the beginning, I believe it tells you that it is available until xx:xx does it not?
After xx:xx it goes away, does it not?
BeachComber is offline
post #3 of 5 Old 09-20-2008, 09:27 AM
Super Moderator
DrDon's Avatar
Quoted: 870 Post(s)
Liked: 1727
Topic title edited to add box make/model.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #4 of 5 Old 09-20-2008, 10:48 AM
I believe if you check, this is the way VOD works making a title available for x number of hours until you need to reselect it.
It has NOTHING to do with the box make/model number and everything to do with the VOD software.
post #5 of 5 Old 09-20-2008, 11:43 AM
Super Moderator
DrDon's Avatar
Quoted: 870 Post(s)
Liked: 1727
This would require work and effort on a day that's supposed to be dedicated to beer and football.
So, I'll take your word for it.
DrDon is online now
Reply HDTV Recorders
