User friendly HDTVtoMPEG2 converter utility available - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-12-2002, 06:52 PM - Thread Starter
bencooley's Avatar
I've converted the bcdmux utility program I wrote to a very nice windows utility called HDTVtoMPEG2. This program, like bcdmux, automatically converts HiPix HDTV files to DVD player compatible MPEG2 files. Unlike bcdmux, it is easy to use and has a nice progress meter, etc.
Temporary ftp for "HDTVtoMPEG2.zip": ftp://67.166.245.50/
I have a hacked version of Vidomi that will encode hidef files to .divx, and I will make that available as soon as it is tested.
Anyhow.. enjoy.
bencooley is offline
post #2 of 17 Old 01-12-2002, 06:56 PM - Thread Starter
bencooley's Avatar
This program uses comctl32.dll in Windows XP. If you have trouble, please tell me.
post #3 of 17 Old 01-13-2002, 11:23 AM
gergg's Avatar
Ben,
I have used your new program and BCDMUX and am having the same problem. It seemed to work fine with some 1080i content from CBS, but it just gives me an empty file when I try 480p FOX content. No errors and it seems to convert but I get nothing.
Not only is the FOX content 480p, but FOX here is 44-2, the second channel. What do you think might be the problem?
-Gergg
gergg is offline
post #4 of 17 Old 01-13-2002, 11:30 AM
mmburke's Avatar
Just curious.
What happens once you get it to DVD format can you play it back on DVD or just use it as an archive or what?
Mark
mmburke is offline
post #5 of 17 Old 01-13-2002, 11:57 AM - Thread Starter
bencooley's Avatar
You can play it back with a Windows DVD player software, and use it as an input file to Vidomi .divx converter or FlaskMPEG, etc.
Tested DVD players:
Ravisent CineplayerDVD 4.0 - Plays ok
PowerDVD - Doesn't play video
WinDVD 3 - Seems to be the best player (as far as I know)
ATI Player with Radeon - Plays at full speed for most folks
You can save a HiPix file to a DVD-R, and play it back on your computer. It won't play back on a DVD player because DVD players don't play High-Def video.
post #6 of 17 Old 01-13-2002, 11:59 AM - Thread Starter
bencooley's Avatar
Gergg,
It's using a different channel number. To be honest, I used the program bbdemux.exe to have it scan the file for the pid's before converting. I will put the scan function in HDTVtoMPEG as soon as i can. For right now, just try 0x21/0x24, then 0x31/0x34, etc. until it works. Sorry.
post #7 of 17 Old 01-13-2002, 12:51 PM
gergg's Avatar
I tried up to 0x41 with no success. Any chance it would be higher?
-Gergg
gergg is offline
post #8 of 17 Old 01-13-2002, 01:38 PM - Thread Starter
bencooley's Avatar
Yup. Stations can pick any stream id they want.
Try grabbing the bbtools.zip and run bbdmux on it to see what is in it.
post #9 of 17 Old 01-13-2002, 06:32 PM
Ken H's Avatar
Moving to HDTV Recording.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #10 of 17 Old 01-26-2002, 12:39 AM
gergg's Avatar
Ben,
Is BBTOOLS.ZIP still posted anywhere?
-Gergg
gergg is offline
post #11 of 17 Old 01-26-2002, 09:14 AM
samiam95124's Avatar
Originally posted by gergg
Ben,
-Gergg
More like everywhere. See the usual suspects.
I want HDTV 'cause I'm nearsighted !
samiam95124 is offline
post #12 of 17 Old 01-26-2002, 03:52 PM
kirkh's Avatar
Ben,
I sent you a pm. I am not able to download from above ftp site. I would love to try the software if it is around.
Kirk
kirkh is offline
post #13 of 17 Old 01-28-2002, 04:42 AM
lrowland's Avatar
Does anyone know what FTP ste Ben's utility is at now? I sent him a pm yesterday but there has been no reply yet.
Larry
Larry
lrowland is offline
post #14 of 17 Old 01-28-2002, 05:41 AM
trbarry's Avatar
Try http://www.midwinter.com/~bcooley/
- Tom
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
post #15 of 17 Old 01-29-2002, 12:13 AM
kirkh's Avatar
Tom I will try it
Kirk
kirkh is offline
post #16 of 17 Old 03-01-2002, 01:22 PM
merc's Avatar
If I use Ben's utility v1.07 to move my HiPix files to DVD-R, can I then just play back those DVD-Rs on my stand alone DVD player such as the Panasonic RP-91?
merc is offline
post #17 of 17 Old 03-01-2002, 06:30 PM
trbarry's Avatar
Not without a lot more work and probably not if they are higher than 480p.
- Tom
trbarry is offline
Closed Thread HDTV Recorders
