I just called Time Warner (WI - Milwaukee area) and multiple people there had no idea what a SATA port (initially and then figured it out) or why their SATA ports were not active.
If you live in WI and have an SA8300HD, please call below to ask if the SATA ports are active for adding a DVR hard drive expander.
The WD 500GB My DVD Expander is listed as the Amazon.com Sales Rank: #204 in Electronics, so it's not a completely esoteric concept.
Obviously people in this foum know this, but apparently not my cable company.
My AVS search showed (don't have reference links) that cable companies may deny an active SATA so they don't have to support the SATA or external products.
But the SATA is usually active.
Is this true?
Any comments?
I realize I could just buy and external HD and try it, but I hate the hassle of returns etc if not needed.
No one should have denied that it is active but I totally believe the lack of support you received on this topic. The truth is no one ever goes into much detail on training lower level technicians on advanced setup as such. Most of the time the support staff's information is ONLY from on the job training and entirely based on experience. Sadly, HDMI is still a battle half the time.
As per federal mandate, every port on the back of the cable box has to be active.
No, the firewire (IEEE 1394) ports on the SA DVR's have never been active. They are supposed to furnish an STB with working firewire, meaning any receiver they have in stock (used to the the SA3250; that stopped in August of '06). That's the FCC mandate you mentioned. They willingly ignore it. The FCC is too busy handing out fines for half-second booby shots or slipped profanities to bother with such trivial stuff.
The fact that the eSATA port works is simply a happy accident. They don't want to have to deal with problems with expansion drives that are privately purchased, not controlled by them. It's understandable. So they just say they don't know anything about them, which is true because the eSATA and firewire ports are not part of their training. Every TWC tech I've had come out here has been astonished at seeing my expansion drive and hearing I have nearly a terabyte of drive space. It's funny and sad at the same time.
I can tell you that not ALL of them are inactive. In the Central NY region that I'm in, I haven't come across a single one that hadn't been active. And I can also say that Support Reps have absolutely no problem telling a customer that they cannot help them with non-TWC equipment. In their defense, it's not that they're avoiding the topic, it's really that they just simply don't know.
Are you saying that the firewire ports in the SA8300 are active (not eSATA which, to my knowledge, are indeed active everywhere)? They work with D-VHS recorders in terms of transferring HD content to tape? Really?? And your TWC division is running Navigator? Because that would be the first I've heard of them working with D-VHS in several years. That would be huge!
If they just said we don't know I wouldn't have minded, but it was the complete lack of understanding people were interested in HD DVR expanders that blew my mind.
This just seems like something that people would commonly think about -- "...wish I had more memory...".
I'll order a DVR expander HD soon (from someplace with a good return policy just in case).
Again thanks.
Mike
PS - I was also eyeing those firewire inputs and wondering about them as well.
PS2 - Is there any FCC mandate about the SATA (or FW)? If so, any links or references?
Actually, it just says they have to provide an HD-STB with working IEEE 1394 ports if a customer requests it; it doesn't have to be DVR. But the point is, it's irrelevant because the cable companies (TWC, anyway) simply ignore it and the FCC has never, not once (to my knowledge or anyone here on AVS) issued an enforcement notice regarding this issue. When I used to bring it up to my TWC division, they just laughed at me.
And again, the eSATA ports are always active and working properly. It's the IEEE 1394 (firewire) ports that are not active and have not worked properly since at least August of 2006. I suspect this is also the case with Sta11i0n, since he hasn't specifically answered the question I posed (he would need a D-VHS tape deck to test it, or know someone who has one). Let's not confuse the two types of ports, please; they're entirely separate and do different things.
I understand what you are saying........I asked the Techs here in Greensboro, NC about the USB and eSATA ports and she told be that the USB wasn't capable of doing it but she wasn't sure about the eSATA ports as there were no notes on it in her library of FAQs...lol
Please let me know the exact steps you used to get yours to work. I just got the My DVR 500GB drive from Western Digital. I want this to work!
I have Time Warner of course, and have the SA 8300HD model. I did the following steps:
1. Unplug the power to the SA.
2. Connect the eSata cable to the SA and the Ext HD.
3. Power on the Ext HD.
4. Wait about 30 seconds.
5. Power on the SA. Wait for it to boot up.
6. It never displayed any message about the HD.
7. I then pressed the Power button on the SA.
8. TV image came on like normal.
After about 1-2 minutes, a message comes up talking about I should only disconnect external hard drives when the power to the settop box is off. It also says to connect an external hard drive, wait at least 10 seconds after turning off the settop box power. I've done that. I turn off the power to the SA, wait 30 seconds, connect the eSata cable to both, then turn on the power to the HD.
Still, that message comes up after about 2 min, and the List of programs still shows the same % used.
Originally Posted by mdreinders /forum/post/14921618
Mike_WI,
Mike_WI,
I just installed an Apricorn DVR Xpander 1TB eSATA to my Time Warner Scientific Atlanta 8300HD and it works just fine. Setup was simple and went just as advertised.
It has worked perfect so far. Haven't had any issues after a week or so.
You can get a great deal on this right now and Amazon and the manufacturer has a $50 rebate coupon on their website that is good through the end of the month. $143.99 net after rebate.
I have the Time Warner DVR SA 8240HDC. Does anyone know for sure if the eSATA is functioning and an eHDD will work? I don't want to buy one and have to take it back.
I just went to the TW local customer service center and exchanged my 8240HDC for a 8300HD. What a difference. I will not go back to that crappy box. I have had a 8300HDC and a 8240HDC. You can group them both together, they are both crap. Go with the 8300HD if you can get it from Time Warner....or whomever else you are getting cable through.
I have it installed in a Middle Atlantic rack in a custom cabinet I built that is accessed from the rear in an adjoining room to our HT. I have dual fans in the bottom of the rack that keep things cool. It does not feel very warm and because it is in a cabinet it isn't any louder than the the DVR, fans and amps in there.
I have had it for a few weeks now and I love it. But now I have to deal with DVR guilt because I can't keep up with everything I have stored on it already. And it is only 42% full!
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
