Patched Vidomi divx encoder now supports HDTV mpg streams - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-13-2002, 04:22 PM - Thread Starter
bencooley's Avatar
Hi all,
I've built a patched version of GPL'ed Vidomi .divx encoder which will encode 720p and 1080i HDTV .mpg streams (as converted from HiPix files by HDTVtoMPEG2). You must install the standard vidomi on your computer, then copy the encoder.exe over the old file to get it to work.
Happy encoding.
Temporary ftp: ftp://67.166.245.50
I've also fixed the HDTVtoMPEG2 utility to recognize some FOX streams that it wasn't recognizing. Any more problems.. just drop me a line.
bencooley is offline
post #2 of 2 Old 01-13-2002, 06:31 PM
Ken H's Avatar
Moving to HDTV Recording.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Recorders
