Moxi HD DVR - Page 209 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #6241 of 7096 Old 06-26-2014, 06:32 AM
TeeJay1952's Avatar
Quoted: 128 Post(s)
Liked: 130
Originally Posted by dz2k View Post
Time to replace your hdd. Thats in a separate thread here.
2nd
It is easy, just like replacing a SATA drive. You will lose current recordings.
TeeJay1952 is offline
post #6242 of 7096 Old 06-28-2014, 12:31 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
I recently purchased a Sony 4K TV (XBR-65X900A) and started having audio problems. What is happening is after fast forwarding or skipping ahead the audio stops (still have video). Usually rewinding for a couple seconds and then playing will bring audio back. Anyone else experienced this? The Moxi is connected directly to the TV (doesn't pass through my receiver).
teeitup is offline
post #6243 of 7096 Old 06-28-2014, 12:41 PM
dz2k's Avatar
Quoted: 100 Post(s)
Liked: 37
No but my sony bravia kdl40xbr9 will do similar with moxi. It will stop playing audio, tv auto turn off, and then back on. They couldnt fix it..maybe an hdmi handshaking issue. I gave up as i like these better than the 40" samsung models
dz2k is offline
post #6244 of 7096 Old 06-28-2014, 01:09 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Interesting. It didn't do it with my other Sony TV (~2009 KDL-46Z4100). I did submit a ticket with Moxi support so we'll see what they say.
teeitup is offline
post #6245 of 7096 Old 06-30-2014, 07:50 AM
Xignals's Avatar
Quoted: 12 Post(s)
Charter cable
Got a couple of questions. I am thinking about getting a used unit from ebay and was wondering if VOD would work. Charter just went all digital in my area so there should be no problem with getting all the channels. I assume channel listings are still being updated as well. I know I will have to have an internet connection to get this done. Also will I be able to get support for a used unit?
Any other concerns I should be aware of?
Thank you.
Xignals is offline
post #6246 of 7096 Old 06-30-2014, 07:54 AM
dz2k's Avatar
Quoted: 100 Post(s)
Liked: 37
Make sure u are getting a retail moxi box. It wont have charter on it. U cant get vod but heard u can call in to charter to get a ppv. The listings are updated and moxi support could open a ticket if they arent.
dz2k is offline
post #6247 of 7096 Old 06-30-2014, 08:40 AM
metuckness's Avatar
Thank you.
I also have a used 3 Tuner Moxi if you are looking to purchase one. Haven't used it in years but it's been stored in the original box in my garage if you're interested just message me. I can't answer your question as it's been a while since I used the device (no Cable companies out here).
metuckness is offline
post #6248 of 7096 Old 06-30-2014, 11:12 AM
Xignals's Avatar
Quoted: 12 Post(s)
Sent messages to both of you about buying your old Moxi.
Xignals is offline
post #6249 of 7096 Old 07-05-2014, 09:21 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
I did some experimenting today with connecting one of my Moxi Mates via powerline and wireless adapters. In my experience I have always been let down with wireless networking and hardwire every component that has a Ethernet port (22 of the 24 ports are being used between my router and switches). I have spent many hours fishing Cat6 ethernet cable through walls, attics and the crawl space. Recently I needed to add another Moxi Mate to a guest bedroom. The thought of wading through the attic insulation motivated me to look at other solutions. I tried out two different wireless devices and a powerline adapter. I did a lot of experimenting and ended up deciding a wireless range extender worked best for my needs. These can plug directly into the wall and have a single Ethernet port for plugging into the Moxi Mate.
For those who don't know, you can check the connection link speed between the Moxi and Moxi Mate by doing the following: Hit the Moxi button, then scroll to the Media Link. Scroll up and highlight Moxi HD DVR, then hit the Info button on the remote. Scroll up to "check connectivity" and hit Ok. It will run and test and show 'Bandwidth Statistics'. Typically with a hardwire connection I will get between 85 and 95 Mbps. The Moxi has a 10/100 Ethernet port so this is near the theoretical maximum speed of the port. I used this as a reference when testing out wireless and the powerline adapters. Results are as follows:
NETGEAR AC750 -802.11AC Dual Band Gigabit Wi-Fi Range Extender (EX6100)
http://www.amazon.com/NETGEAR-802-11...=ATVPDKIKX0DER
Bandwidth Statics: ~91 Mbps
This is a dual band device that supports 802.11AC. I have a Netgear R7000 router which is a 802.11AC router. The location where I needed the extender was up one level from the router about 30' away. I found that my speeds were better on the 2.5GHz than the 5GHz. So I set the extender to connect to the router on 2.5Ghz only. I also shut off the range extender feature of the device and am strictly using it as a wireless to wired adapter. This device gives me near wired speeds and the Moxi Mate works flawlessly. Results will vary based on distance to your router. Also, this device only uses 2 watts per my Killawatt meter.
Belkin N300 Dual Band Wireless N Range Extender
http://www.amazon.com/Belkin-N300-Wi...=ATVPDKIKX0DER
Bandwidth Statics: ~86 Mbps
This is also a dual band device that supports up to 802.11n but not 802.11AC. Results were similar to the Netgear. A little slower, but still close to the wire speeds. This device was not as configurable and I wasn't able to turn off the range extender feature.
NETGEAR XWNB5201 Powerline 500Mbps to N300 Wi-Fi Access Point
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Bandwidth Statics: ~78 Mbps
First time I've tried using powerline and I have to say it exceeded my expectations. When on the same breaker these are undiscernible from wired. Speeds seemed to slow as you get further away or cross to a different breaker or buss. But, the throughput is more than adequate to use a Moxi Mate on. I probably would have stuck with the powerline adapters, but a disadvantage was it took up one extra wall socket and a Ethernet port.
Just thought I would post my observations for anyone looking to expand a Moxi Mate where wired access is a problem. I realize results will vary based on many factors (location, distance, wiring). I know others have had poor results with running a Moxi Mate wireless.
teeitup is offline
post #6250 of 7096 Old 07-05-2014, 10:59 PM
sslund's Avatar
Quoted: 57 Post(s)
Very cool -- I didn't know that! For me (and perhaps for others), I have to hit the "Next" button on the remote after doing "check connectivity" to see the results -- I now know both of my Mates connect to both of my Moxis at 94+ Mbps. I'm not looking for any alternatives at this time, but this is good info to have for the future just in case. Somehow, I don't know that my dh would be as willing to let me drill through floors/walls to run cable if we relocate after retirement as he was willing to do when I set up the networking in this house a decade or so ago :-)
sslund is offline
post #6251 of 7096 Old 07-10-2014, 09:41 AM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
I purchased another Moxi DVR and Moxi Mate from a forum member on here. Brings my total household Moxi count to 2 Moxi's and 4 Moxi Mates. I officially have more Moxi's than TV's! Guess it's time to buy some more TV's.
Spent some time playing around last night. Made me appreciate the Moxi all the more. Some observations.
1) I remember Moxi not recommending more than 3 Mates connected to 1 DVR. I can confirm that the Moxi will work with 4 Mates at a time. Obviously still limited by the 3 Tuners but I was able to stream HD to all 4 Mates simultaneously. Pretty cool!
2) Adding a 2nd DVR to the mix is awesome. I know this has been posted before, but very cool how all recorded programs between each DVR are integrated into one list and can be viewed from any connected Mate or DVR.
3) I thought I read this was not possible, but you CAN watch live TV on one Moxi DVR using a tuner from a different Moxi DVR (same as the Moxi Mate does). This can be done using the Media Link and connecting to the second Moxi DVR. You may ask why you would want to do this when the DVR has it's own tuners. Well in my case I get a number of clear-QAM channels without a cablecard. I can map these to actual channels in my second DVR as normal. My main Moxi has a cablecard and includes additional channels included with my cable subscription. A second cablecard is $5.99/month so this ability allows me to watch channels from the Main DVR without needing the extra cablecard. Awesome!
tveli and TeeJay1952 like this.
teeitup is offline
post #6252 of 7096 Old 07-11-2014, 07:44 PM - Thread Starter
cypherstream's Avatar
Our local area cable company just released the Arris 6 tuner gateway and media player product. See here: http://www.secv.com/birdsboro/prod_gateway_birds.html
Anyone have experience with this new Arris version? Its a big box with built in eMTA, wireless, DOCSIS 3 modem, 4 ports ethernet, battery backup, eSATA port and Moca. Then at each TV you install these smaller Moca enabled "Media Players" and they get all the data from the gateway (which I presume is where the m-cable card is as well).
Can you create a custom channel lineup, aka a favorites list? I would want to eliminate all SD duplicates, or if possible downmap HD from lets say 503 to 3 for example.
I currently have DirecTV and like it, but would consider this Arris system if it is any good. If you wouldn't count premium channels, this cable company has more HD than DirecTV. However we know that won't be forever as DirecTV is going to launch new satellites.
cypherstream is offline
post #6253 of 7096 Old 07-11-2014, 10:04 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
My local cable company also offers the 6-tuner Arris all-in-one home network gateway (http://www.wavebroadband.com/for-hom...twork-gateway/), however I have not used it. They charge a premium price for it even over the Motorola multiroom DVR and each client is $7/month. My setup of 2 Moxi DVR's and 4 Moxi Mates would be $68/month equipment rental, rather than just the $5.99 I pay now for a cablecard. My understanding is the user interface is basically the same as the consumer Moxi. The Moxi Mates are the same as the Gateway Clients but require hardwired Ethernet vice Moca.
If the Gateway is the same as the Moxi you can add/remove channels from your lineup so only the channels you want to see are in the guide. The Moxi also has a "Favorites" icon in the cross media menu which keeps track of the channels you watch most frequently. Remapping channels is possible when there isn't a cablecard in the Moxi, but you cannot remap channels with a cablecard installed as it does it automatically.
teeitup is offline
post #6254 of 7096 Old 07-11-2014, 10:14 PM
VisionOn's Avatar
Liked: 2071
Download the guide from the link at the bottom of that page.
Apart from the phone and VOD menus, adding a channel manually to the favorites list seems to be the only upgrade the Moxi UI has had since the retail version was discontinued. But as mentioned, you can remove any channel you want to from the main guide anyway.
VisionOn is online now
post #6255 of 7096 Old 07-12-2014, 04:30 AM
miked1960's Avatar
Quoted: 16 Post(s)
This is why Arris stopped selling the Moxi do to this new DVR for the cable company's I was told from Moxi techs. It would of be nice they could of sold it to the consumer also, I assume the cable company's would not stand for it, and made them sell it to them selves so they could make the money on the rental part of it.
miked1960 is offline
post #6256 of 7096 Old 07-12-2014, 05:14 AM
VisionOn's Avatar
Liked: 2071
It wasn't the cablecos it was Arris who decided to stop selling it. Like many acquisitions Arris bought Moxi just for the tech to use in their own equipment. Arris makes all their money selling technology to cable operators.
post #6257 of 7096 Old 07-12-2014, 03:18 PM
pgershon's Avatar
Roamio to replace Moxi
Asking on this thread because would like response from people familiar with Moxi. I have 3 Moxi DVRs and 3 Mates connected to 6 TVs in my house (family of 4 but TVs on different floors). Went with 3 DVRs because the delay on the Mates on live shows was annoying for all, especially on sports (one room would see what happened before the other). Does anybody know if Tivo Mini suffers from similar issues? Would be great to simply get one Tivo Roamio Pro and 5 Minis. Would need two less cable cards which partially makes up for the membership cost.
pgershon is offline
post #6258 of 7096 Old 07-12-2014, 04:20 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Good question, curious myself. You may have better luck asking about delay on the Minis in the Tivo thread. The delay between live TV on the main Moxi and Moxi Mate(s) is likely due to processing the feed over Ethernet. I suspect the Minis are also prone to it but couldn't say for sure. I have noticed the delay but it is a rarity in my household for a Moxi and Mate within earshot watching live TV on the same channel and in reality it is probably less than 2 seconds. Could see how it would be annoying when the next room erupts after a big play. Less cablecard fees is a nice bonus, although I'm sure the monthly Tivo and Mini subscription fees would far exceed the savings in 2 cablecards.
**UPDATE**A quick google search found a answer to your question about live TV delay on Tivo Mini. Appears it also has a 1-3 second delay:
http://www.tivocommunity.com/tivo-vb...50#post9862050
teeitup is offline
post #6259 of 7096 Old 07-14-2014, 05:01 AM
Liked: 687
There's no way to avoid a small delay on any whole home, extender based solution.
slowbiscuit is offline
post #6260 of 7096 Old 07-14-2014, 05:07 AM
dz2k's Avatar
Quoted: 100 Post(s)
Liked: 37
You'd have to have moxi dvr in each room to avoid delay for each tv.
dz2k is offline
post #6261 of 7096 Old 07-14-2014, 05:49 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
I'm wanting to mount one if my Moxi DVR's vertically on the wall behind the tv. Anyone mounted vertically and ran into problems? I suppose the only component that would be affected is the harddrive which are mounted vertically in computers all the time.
Sent from my SPH-L900 using Tapatalk
teeitup is offline
post #6262 of 7096 Old 07-14-2014, 07:40 PM
dz2k's Avatar
Quoted: 100 Post(s)
Liked: 37
Youd need to be able to change the channel via the ir sensor on the front. Otherwise, i dont see an issue
dz2k is offline
post #6263 of 7096 Old 07-15-2014, 12:48 PM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Installed a DVR vertically behind my TV and everything seems to be working as normal. Surprisingly the remote works about the same with the Moxi behind the TV. Doesn't work very well when you are right up next to the TV but works fine a few feet back at normal viewing distance.
teeitup is offline
post #6264 of 7096 Old 07-15-2014, 05:17 PM
dz2k's Avatar
Quoted: 100 Post(s)
Liked: 37
Cool
dz2k is offline
post #6265 of 7096 Old 07-16-2014, 09:02 AM
VisionOn's Avatar
Liked: 2071
Given the poor heat extraction within the box I guess the only problem would be the heat. Did you install it with the fan upwards?
I've been thinking about drilling some holes in the sides of the case in the hopes of prolonging the hard drive life.
post #6266 of 7096 Old 07-16-2014, 09:51 AM
teeitup's Avatar
Quoted: 112 Post(s)
Liked: 45
Heat was a concern I had considered. I ended up mounting with the fan on the right side (front of box facing left). This orients the harddrive at the bottom with the fan near the top right of the box. In theory this should allow good cooling and also made routing cables easier than if the back was facing up.
Maybe a good case study. Both my DVR's are still on the original hard drives, so will be good to see if horizontal or vertical goes first. The new location of the DVR is on a dresser. I was worried the constant shock/vibration from opening/closing drawers could reduce life which is one of the reasons I wanted to wall mount behind the TV.
teeitup is offline
post #6267 of 7096 Old 07-16-2014, 10:01 AM
VisionOn's Avatar
Liked: 2071
Makes sense. At least it will keep the heat from the power supply away.
post #6268 of 7096 Old 07-18-2014, 10:55 AM
Xignals's Avatar
Quoted: 12 Post(s)
Used Moxi
I just picked up a Moxi off of eBay and was wondering what to expect when I get it set up. Will I need to go through a registration process or will it just work after charter enables the cable card? My first thought is to try to install a larger HD from the HD replacement thread. I guess I want to know in what order I should do things. I got a Mate as well so please include any tips for that as well. I can't wait to use it!
Xignals is offline
post #6269 of 7096 Old 07-18-2014, 11:26 AM
VisionOn's Avatar
Liked: 2071
You have to register it with moxi.com during the setup and then you have to register your CC with Charter. It might pick up clearQAM cable channels after setup but you won't get your full package until the CC is activated.
I hope you picked up a black retail Moxi from eBay and not a cable-issued silver box. Those are doorstops.
post #6270 of 7096 Old 07-18-2014, 12:55 PM
Xignals's Avatar
Quoted: 12 Post(s)
Yes it is the 3-tuner MR-1500T3 and a MP-1000 Mate. Had about 3 of the large silver boxes since 2004 when Charter got them in my area. Loved it to death
but one of the tuners quit and the unit started rebooting all the time. I cuss the DVR I got in replacement everyday so can't wait to get the Moxi!
Thanks for the heads up.
Xignals is offline
Reply HDTV Recorders
