Moxi HD DVR - Page 217 - AVS | Home Theater Discussions And Reviews
 18Likes
post #6481 of 6486 Unread 02-21-2015, 01:41 PM
dz2k's Avatar
Quoted: 31 Post(s)
Originally Posted by dmusoke View Post
Hooray!!!
Thanx dz2k...You guys rock... after a dismal unsuccessful evening hours with tech support last night with folks from (India/Bangladesh?), I called again per your instructions exactly and within 15 minutes TW tech support in Buffalo NY fixed it immediately. The asked for a bunch of CC tech info in addition to the ones you suggested and all is well.
great! please add the info to the hard drive replacement thread using the template on first page.
dz2k is offline
post #6482 of 6486 Unread 02-21-2015, 02:20 PM
dmusoke's Avatar
Quoted: 106 Post(s)
Liked: 99
Done!
How to phase match subwoofers to the mains speakers: http://www.avsforum.com/avs-vb/showt...0#post19542630
dmusoke is online now
post #6483 of 6486 Unread Today, 08:48 AM
tveli's Avatar
I do lots of fast forwarding and reversing plus skipping the commercials. Does this increase wear and tear on the drive killing them off sooner than expected?
negative, dmusoke: , fastfwding & rewinding & skipping commercials does not increase or decrease wear/tear on the hard drive.
tveli is offline
post #6484 of 6486 Unread Today, 10:11 AM
dmusoke's Avatar
Quoted: 106 Post(s)
Liked: 99
Thanks Tveli ...but doesn't this increase the random movement of the read/write heads of the disk drive, hence its life time? Fro regular PC drives, it I believe it does but I may be wrong here...
post #6485 of 6486 Unread Today, 12:11 PM
tveli's Avatar
You are most welcome, dmusoke...
The read/write heads will be gyrating back and forth about the same whether or not you fastforward/rewind/commercial-skip, due to the ongoing recordings, and the tendency towards disk fragmentation.
A possible way to reduce the read/write head/servo activity of the drive would be to tune every tuner to an unauthorized "you are not subscribed to this" channel, so there will be nothing to record onto the hard drive. (Or disconnect the input coax cable....)
This question brings to mind fun I had with a DEC RP06 "washing machine" disk drive back in the 1970s on a PDP-11/40:
Using nonprivileged system calls, one could position the heads at any physical block, so i wrote a program which looped and moved the r/w heads from an innermost block to an outermost block, on the platter(s). This caused r/w heads to go back and forth between their extreme positions as fast as mechanically possible - so the 300 lb washing-machine-sized drive "walked itself" across the floor until it pulled out its own cable, and system would crash. (I didn't run that program more than twice.)
tveli is offline
post #6486 of 6486 Unread Today, 02:41 PM
dmusoke's Avatar
Quoted: 106 Post(s)
Liked: 99
Reply HDTV Recorders
