Moxi HD DVR - Page 234 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #6991 of 7004 Old 10-25-2016, 01:25 PM
VisionOn's Avatar
Liked: 1740
Plug it directly into the modem and avoid any router you may be using.
VisionOn is offline
post #6992 of 7004 Old 10-26-2016, 12:29 AM
Liked: 0
The mate was registered prior to August 12, yet right now shows as Retrieving Data. The used moxi was not.
Some other questions:
1) Do we have any contact information for Arris / Moxi / new moxi company owners?
2) Do we have any information as to how long our moxis will continue to receive channel lineups?
3) The online moxi.com portal is vital for deleting shows on other units without having to go to them physically, plus for online searching and show programming. Does anyone know how much longer that site will still be working?
4) Is anyone working on moxi developments or work-arounds?
It is a great system (even though it has a few missing features my Replay Tvs had - ie multi dvr scheduling / conflicts and multi unit show deletions) but it seems like it was shut down while still in its prime. Replaytv had huge outside development, but sadly it was stuck with SD recording.
I loathe thinking about having to pay a monthly subscription to my cable operator for their box(es) for whole house dvr.
REPLAYTVS is offline
post #6993 of 7004 Old 10-26-2016, 02:20 AM
VisionOn's Avatar
Liked: 1740
The answer to all of those questions is basically "no" because we are on our own at this point just squeezing whatever drops remain out of the system until the well dries up.
If you don't find the answer here then you won't find it anywhere else at this point. You can try emailing the Moxi support guy and you might be lucky enough to get a response depending on the query.
VisionOn is offline
post #6994 of 7004 Old 10-26-2016, 10:07 AM
dz2k's Avatar
Quoted: 84 Post(s)
Liked: 32
i hope u didnt brick your moxi dvr. it must be registered fully to an account prior to doing ffp. when u got it, was it still registered to the seller or did it immediately try to take u through the setup process that u eventually get to the passcode screen?
did u have a mate and moxi prior to getting the used moxi? i would try to pair it with original moxi. i hope u didnt make big changes regarding the mate on your online account.
1) I think they still use the customercare@moxi.com email but I wouldn't expect much help regarding our devices. they are focused on the moxi whole home solution that generates revenue each month through providers. an arris exec moved over to espial to be their GM. I really hope they just keep the system going for a very long time.
4) I wish there was a secondary way to get the guide data.
dz2k is online now
post #6995 of 7004 Old 10-27-2016, 06:48 PM
Xignals's Avatar
Moxi Mate
So after reading the latest posts I got to wondering if my Mate would still work after not being used for the last 8 months or so. It has been registered since 2014. It came right up and after about 10 minutes it told me it needed to reboot to update. I let it and it came back up and worked just like it always had. I guess as long as it was on your account before the cut off things will still work.
Xignals is offline
post #6996 of 7004 Old 11-06-2016, 03:15 PM
dz2k's Avatar
Quoted: 84 Post(s)
Liked: 32
Originally Posted by Mike Wolf View Post
As a long time Moxi customer, I'm quite unhappy about this news. I've not been happy about this situation since Moxi was bought by Arris. I really wish that Arris wasn't essentially forcing customers to rent equipment from their service provider. It has the stench of collusion between the service providers and the manufacturer that supplies those service providers with equipment.
I read a Comcast faq about mpeg-4. it seems to only affect hd channels at this time and not sd channels. that is at least some sigh of relief.
tveli likes this.
dz2k is online now
post #6997 of 7004 Old 11-07-2016, 10:11 AM
TeeJay1952's Avatar
Quoted: 112 Post(s)
Liked: 120
My 2 gig will get entire season of everything in SD.
TeeJay1952 is offline
post #6998 of 7004 Old 11-12-2016, 08:09 AM
AMMO's Avatar
Can anyone point me to the directions for the 4 finger press for rebooting.
Moxie went out last nite and I have another drive to try. This other drive is either the original or one that I configured several years ago in anticipation of an eventual failure.
Mike
AMMO is offline
post #6999 of 7004 Old 11-12-2016, 08:13 AM
VisionOn's Avatar
Liked: 1740
Official Moxi Hard Drive Replacement Thread
VisionOn is offline
post #7000 of 7004 Old 11-12-2016, 02:42 PM
domm's Avatar
Quoted: 40 Post(s)
Liked: 24
Can anyone please help me to get the Moxi programming guide to update/work. I am a snowbird just returning to our Florida house & I booted up my Moxi but I can not get the programming guide to work. I am getting all of my channels fine but when I go to the guide it just shows what is on at present but nothing in the future. Thanks
domm is offline
post #7001 of 7004 Old 11-12-2016, 02:50 PM
dz2k's Avatar
Quoted: 84 Post(s)
Liked: 32
it will auto update the program guide in due time. However, if you want to force a guide update, make sure your Ethernet is connected and go into settings > diag > service status > update program guide.
TeeJay1952 likes this.
dz2k is online now
post #7002 of 7004 Old 11-12-2016, 02:57 PM
domm's Avatar
Quoted: 40 Post(s)
Liked: 24
Thanks for your quick reply. I followed your forced guide update & it worked! Thanks
domm is offline
post #7003 of 7004 Old Today, 07:34 PM
Craddock01's Avatar
OK. I've searched and not found a post relating to this but I may have missed it. My Moxi is working fine as was my Moxi Mate but a few days ago, the Mate seems to have lost connection with the remote. The remote works fine adjusting the volume and turning on & off the TV so I know the remote is sending a signal to TV but the only way I can control the Mate is from the front panel buttons. I've tried the reset (pressing reset button for 3-5 seconds) & have unplugged (basically same as reset) with no success. I tried resetting remote to factory settings and only lost control of TV. Any ideas to determine if it is the Mate or the remote &\or a fix? Thanks.
Craddock01 is offline
post #7004 of 7004 Old Today, 10:19 PM
dz2k's Avatar
Quoted: 84 Post(s)
Liked: 32
you have a dvr and a mate. I think you have 2 remotes so try the other one for the mate.
dz2k is online now
Reply HDTV Recorders
