Question about Panasonic PV-HD1000 Digital VCR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-20-2002, 11:57 PM - Thread Starter
Eric_1's Avatar
Hi, I am new to HDTV and any help will be appreciated. With the help of a friend, I think I can get my hands on a Panasonic PV-HD1000 Digital VCR and a TU-DST51 Digital TV decoder. I am in the process of building my first HT and I think I will get DishTV for HD programs. I would like to know I if can record HDTV programs off the dish with the above set up. Do I need anything else? Is it possible at all? TIA.
Eric
Eric_1 is offline
post #2 of 6 Old 01-21-2002, 04:15 AM
DSperber's Avatar
Quoted: 237 Post(s)
Liked: 191
If you want to record with the DST51 and PV-HD1000, you'll need
to also acquire (1) a Dish 5000 reciever, and (2) a Dish HDTV
Modulator.
See another thread in this group for more details:
Dish 5000 vs. 6000
The DST51 and PV-HD1000 can be used separately to record
DTV/HDTV from off-air local channel input (from your roof antenna)
but to record from Dish-HD you'll need the above equipment.
DSperber is offline
post #3 of 6 Old 01-21-2002, 10:24 AM - Thread Starter
Eric_1's Avatar
Thanks for the info. However, I will be subscribing to DirectTV instead of DishTV. Will the setup you described work with DirectTV too?
Eric_1 is offline
post #4 of 6 Old 01-21-2002, 10:38 AM
Ken H's Avatar
Moving to HDTV Recording.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 6 Old 01-21-2002, 10:49 AM
Ken H's Avatar
To answer the question, no, there is no way to record digital DirecTV HDTV.
Some members have the Dish 5000 w/HD Modulator that is set up for ExpressVu, a Canadian DBS company. When EVU has HDNet programming from DirecTV, it can be recorded that way. Unfortunately, this has been problematic due to a non-standard HDTV signal that EVU uses for the HDNet re-transmission.
There are also the W-VHS units from JVC. They record the analog HDTV signal and analog l/r stereo audio.
For more info, see recent topics here in HDTV Recording.
Ken H is offline
post #6 of 6 Old 01-21-2002, 10:20 PM
Techsa1's Avatar
"Some members have the Dish 5000 w/HD Modulator that is set up for ExpressVu, a Canadian DBS company. When EVU has HDNet programming from DirecTV, it can be recorded that way. Unfortunately, this has been problematic due to a non-standard HDTV signal that EVU uses for the HDNet re-transmission."
Ken,
Can you please elaborate on how a 5000 can be setup for EVU. Also, is it working or is it touch and go due to non-standard issues depending on what is being broadcast?
David
Techsa1 is offline
Closed Thread HDTV Recorders
