The Official AVS Dish DTVPal DVR Topic! - Page 320 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #9571 of 19336 Old 05-28-2010, 07:45 PM
mabuttra's Avatar
Location: Wichita, KS OTA (w/optional cable connection)
Liked: 32
Originally Posted by HoustonPerson View Post
Ok, I am considering one of these contraptions.
HoustonPerson,
I bought a DTVPal about a month ago, hoping to replace my Sony DHG with it. After playing with it, I've decided to continue using my Sony until it dies. I'll just use the DTVPal as a second (and third) tuner to record shows that overlap. I was aware before I bought it of some of the complaints that people had with it. Although the TVGOS gets up and running faster than the Sony, it really leaves a lot to be desired. I have six channels (three are sub channels) that show "no information" on the Pal. those same channels have eight days of data on the Sony. One of those channels missing TVGOS data is my CBS station, which is my host channel.
Mark
mabuttra is offline
post #9572 of 19336 Old 05-28-2010, 08:07 PM
keyboard21's Avatar
Originally Posted by mabuttra View Post
HoustonPerson,
Mark
There is a trick you can try for the NO information. After you go to the guide and see what stations say no info. Go back to View tv and go to that station. Then hit guide again. Should come up then.
It works for us. So if it is channel 2 (for example. Go to channel 2 then hit guide again. It forces the info to load.
keyboard21 is offline
post #9573 of 19336 Old 05-28-2010, 08:11 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
That trick only brings up the PSIP info, not TVGOS.
Chuck44 is offline
post #9574 of 19336 Old 05-28-2010, 08:12 PM
ss_sea_ya's Avatar
But if the box is not able to "pixel match" (no overscan for 1080), then that would be a deal killer for me.
Deal killer here is not pic qualtiy, but reliability of the product. If you have great reception and only need OTA, then this may barely work for you. back to back programming on multiple channels, locks ups, and DST changes will all mess up your recordings.
Other devices are available, that might suit your needs better if you are that concerned about video matching quality.
ss_sea_ya is offline
post #9575 of 19336 Old 05-28-2010, 08:28 PM
keyboard21's Avatar
12 to 48 hours of guide is better then NO info
post #9576 of 19336 Old 05-28-2010, 09:02 PM
Chuck44's Avatar
Quoted: 16 Post(s)
Liked: 48
Absolutely.
Chuck44 is offline
post #9577 of 19336 Old 05-28-2010, 09:51 PM
mabuttra's Avatar
Liked: 32
True, but I prefer 8 days of guide data which my Sony gives me consistently. I'm sure if the DTVPal was my first DVR it would be pretty cool, but after using the Sony for 4 years, I immediately miss its features when I try to use the DTVPal.
Mark
mabuttra is offline
post #9578 of 19336 Old 05-28-2010, 09:55 PM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
I'm holding in my hands unopened CM-7000PAL; if you have questions - I'll be glad to answer.
P Smith is offline
post #9579 of 19336 Old 05-28-2010, 10:24 PM
keyboard21's Avatar
Originally Posted by P Smith View Post
I'm holding in my hands unopened CM7000-PAL; if you have questions - I'll be glad to answer.
Can you open it? Are there any differences to the Dishpal dvr?
OR
Same box?
Also why would you spend over $350 for a $199 box?
post #9580 of 19336 Old 05-28-2010, 10:31 PM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
I can make pictures...
- Perhaps I've a high level curiosity in my blood.
P Smith is offline
post #9581 of 19336 Old 05-28-2010, 10:46 PM
keyboard21's Avatar
Great much appreciated. Can you also tell us if there is any difference to the Dishpal DVR.?
post #9582 of 19336 Old 05-28-2010, 10:58 PM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
I'll postpone unpacking and picturing - too late for tonight, lets make it tomorrow.
P Smith is offline
post #9583 of 19336 Old 05-28-2010, 11:41 PM
Rammitinski's Avatar
Originally Posted by sivartk View Post
Bottom line, I could tell no difference in picture quality between the two units with the same OTA antenna source. (This on a 720p TV and 100" 720p projector...output on both set to 720p)
Even on the 480i channels?
That's where you can see really a difference between my Sony and my TiVo HD. The TiVo is OK, but the Sony is better.
Rammitinski is offline
post #9584 of 19336 Old 05-28-2010, 11:49 PM
Yeah - like I've always said, the Sony DVR is the best piece of electronics gear that I've ever owned.
post #9585 of 19336 Old 05-29-2010, 05:41 AM
HoustonPerson's Avatar
Mabuttra and Rammitinski, yes that is exactly where I am coming from.
Mark you hit the nail on the head. I would like to add two more recording channels in my set up for a total of "three". And you have really answered my questions regarding the quality I am used to in the Sony. That is extremely hard to give up. After reading all the post(s) this morning I am inclined to just get another Sony, which only gives me "one" more tuner.
You wouldn't happen to have (or anybody), the DVR hook-up to a 1080p panel with pixel mapping would you? Like a Panasonic with HD-Size 2 option or any other panel that provides for pixel mapping on a 1080i source? If it cannot match the Sony on that feature, then I will not consider it any further. I already know it messes around with the 720 source which I do not like, because we do record a lot of FOX stuff and some ABC stuff.
HoustonPerson is offline
post #9586 of 19336 Old 05-29-2010, 05:54 AM
I've owned both the DTVPal DVR and the Sony DHG-HDD250. If you display doesn't overscan, this machine won't do it for you. When I had mine hooked to the projector, I could still see the VBI lines of some SD analog shows that the local broadcaster simply upconverted to 1080i.
Thanks, see my post just above.
To be more specific I am trying to locate someone with a fixed 1080p panel (plasma or LCD), that has selectable pixel mapping (Like the Panasonic HD Size 2), and has confirmed the DTVPal will not overscan on a 1080i source to that pixel mapping 1080p panel.
post #9587 of 19336 Old 05-29-2010, 06:17 AM
Bengoshi2000's Avatar
Well, I completed my DIY antenna and cable run to the attic and now have my Craigslist DTV Pal up and running. I've been using it for about a week and I'm very pleased. It's whisper quiet compared to my Directv hd-dvr. I actually find the PQ is better than Directv. If it only works for 2 months then I've broken even with Directv.
Directv has been canceled with extreme prejudice.
I LOVE stickin' it to tha Man!
My Evil Plan to take over the Tri-State Area: The Subwoofinator-inator.
Bengoshi2000 is offline
post #9588 of 19336 Old 05-29-2010, 07:40 AM
trp2525's Avatar
Liked: 58
I'm wondering if the Channel Master CM-7000PAL DVR has the card slot and card in the front of it like the Dish version has. From the pictures I've seen thus far I can't tell if it does or not.
I'd also like to know what it shows for the firmware version when you bring up the system info screen from your remote. I'm wondering if they are using the same numbering system (i.e. F208) like the Dish version or if they have their own unique numbering system. Lastly, what does it show on that same screen for the Internet Address (Dish version shows dtvpal.com)?
trp2525 is offline
post #9589 of 19336 Old 05-29-2010, 07:58 AM
sivartk's Avatar
The only 480i channels I get are 24/7 weather channels, so I don't really watch them much. When I had the Sony, there were only weather 480i channels then, so I really can't compare.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
post #9590 of 19336 Old 05-29-2010, 08:47 AM
NorthDallasGuy's Avatar
Just curious...any idea why was the Sony DVR you're talking about discontinued?
NorthDallasGuy is offline
post #9591 of 19336 Old 05-29-2010, 08:56 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
Without opening it, I can tell - it is dish DVR, on a label outside you can see all the Receiver CAID and SC CAID as regular DTVPAL DVR.
P Smith is offline
post #9592 of 19336 Old 05-29-2010, 09:10 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
Opening the box ...
On second picture you can see a smart card too.
P Smith is offline
post #9593 of 19336 Old 05-29-2010, 09:11 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
One post allow to attach only 5 pictures ... So, one more for exterior view.
P Smith is offline
post #9594 of 19336 Old 05-29-2010, 09:13 AM
frank70's Avatar
Quoted: 107 Post(s)
Liked: 83
The picture quality of OTA TV is, and always will be, vastly superior to subscription services. OTA is the original bitstream as it leaves the station (as good as it's ever going to be), while cable, satellite, and FIOS have only one goal - to cram as many channels as possible (so they can charge you for them) into as little bandwidth as possible (so they can sell other services over the same medium), thus the original bitstream gets uncompressed and then recompressed at a lower bit rate. Isn't it obvious that something that you pay for should be inferior to something that's free?
frank70 is offline
post #9595 of 19336 Old 05-29-2010, 09:25 AM
trp2525's Avatar
Liked: 58
I never owned one but from what I have read they were very well-made/high-quality units. One thing that I believe lead to their demise was the MSRP which ranged from $800 for the 250GB unit to $1,000 for the 500GB unit. I don't believe the majority of OTA viewers who wanted to record HD were willing to spend that amount of money. A lot of people buying electronics look for the cheapest price and unfortunately don't give much thought to the quality of the build or components inside. IMHO the Sony units had a limited market based on their MSRPs at the time.
trp2525 is offline
post #9596 of 19336 Old 05-29-2010, 10:07 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
If bfdtv want to add CM-7000PAL pictures to the first page he could use my collection of screen shots. It's too big to post by myself.
I did attempt to update SW, but it running current.
For particular question I will post a couple pictures, for now it's startup screen and System Info:
P Smith is offline
post #9597 of 19336 Old 05-29-2010, 10:19 AM
visualsensation's Avatar
Now we know it has a different firmware than the Pal DVR - F400. Since its not F109 or something close to that, I'm afraid that it won't be compatible with the Pal. Thanks for posting!
visualsensation is offline
post #9598 of 19336 Old 05-29-2010, 10:26 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
If someone brave enough, he could DL CM FW to flash drive and could try update his DTVPal DVR. Not sure if there is any advantage.
P Smith is offline
post #9599 of 19336 Old 05-29-2010, 10:46 AM
trp2525's Avatar
Liked: 58
Unfortunately that experiment is not possible yet because Channel Master has not posted the firmware at the Channel Master CM-7000PAL DVR Support Page. They probably won't post firmware there for download to a flash drive until there is an update available (assuming there will be future updates). Dish never posted the original version of their firmware, F201, on their website and only started posting firmware for download when F202 (and later F206, F207 and F208) was available.
trp2525 is offline
post #9600 of 19336 Old 05-29-2010, 11:03 AM
P Smith's Avatar
Quoted: 552 Post(s)
Liked: 302
There is other way - read CM flash and reprogram your PAL DVR. .
A couple more pictures - inside it is the same DTVpal DVR:
P Smith is offline
Reply HDTV Recorders
