The Official AVS Dish DTVPal DVR Topic! - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 255Likes
post #121 of 19437 Old 12-23-2008, 05:22 PM
Ken H's Avatar
Originally Posted by ccrider2 View Post
I might be off-base here, but I have a Sony SXRD, and it will only output PCM audio ....IRC. Might see if the Pal can send the audio as PCM and not Dolby.
Just a thought.
As already noted, the DTVPal DVR can send either DD or PCM, via a menu selection.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #122 of 19437 Old 12-23-2008, 05:36 PM
arxaw's Avatar
Originally Posted by OhMyTVC15 View Post
Would be curious about the PQ if anyone out there is using an analog TV and the composite or coaxial outputs of the DVR...
The PQ should be as good as your analog TV is capable of displaying.
Originally Posted by FRANK43 View Post
... The local CBS station just was bought by a new owner after bankruptcy so the don't even use PSIP.
The FCC requires them to use PSIP.
arxaw is offline
post #123 of 19437 Old 12-23-2008, 05:43 PM
autobot's Avatar
I have been wanting this thing since it was introduced in the beginning of the year so as soon as it was up for pre-order I ordered it.
Hooked and set it all up downloaded the update, it was a fast download.
OH and mind had the batteries included.
This thing picks up the OTA HD signal better that my internal HD tuner on the TV does a much sharper and clearer picture quality.
And the Dolby sounds better too.
I am doing a test recording in HD now I have not played it back still recording.
I hope to be as happy with the PQ on the playback as I am with the live tv signal beautiful.
autobot is offline
post #124 of 19437 Old 12-23-2008, 05:52 PM
OhMyTVC15's Avatar
I just know this thing is going to make me wanna go out and buy a new HDTV. Maybe Santa will be good to me this year. Nope, nothing that big under the tree. Merry Xmas
OhMyTVC15 is offline
post #125 of 19437 Old 12-23-2008, 05:54 PM
autobot's Avatar
Originally Posted by dlhoppe View Post
Anyone have any idea what the "smart card" is for? I assume it's for future features. Network based features? Movie downloads?
I haven't hooked mine up yet, but will tonight. Just wondering if anyone tried removing the card to see what happens.
IDK either nothing on the manual about it, or what the USB will be used for either.
I don't know I removed it for a moment while watching TV nothing happened so I just slid it back in.
Wonder what its for
autobot is offline
post #126 of 19437 Old 12-23-2008, 05:55 PM
arxaw's Avatar
Can't you go back and start watching the program after it starts recording it?
arxaw is offline
post #127 of 19437 Old 12-23-2008, 06:07 PM
nolim2873's Avatar
I set my to record a several half shows this afternoon (on PBS, one from the HD channel, the others from one of two SD sub-channels), plus some shows tonight. A few of these were 0:38 and 0:39 minutes recorded. It seams to be starting the recording earlier than it's suppose to. Any one else noticing this? I set my default options to 0 minutes early/late. Also both 8:00pm shows tonight started recording about 13 minutes early. Weird. (I did update mine to F202.)
nolim2873 is offline
post #128 of 19437 Old 12-23-2008, 06:09 PM
nolim2873's Avatar
Yes you can.
post #129 of 19437 Old 12-23-2008, 06:36 PM
RegGuheert's Avatar
Originally Posted by nolim2873 View Post
I just tried what you asked because mine is currently recording two shows. I had to turn off the DTVPal (it was still recording, just the output was turned off), but once off, I could watch a third channel on the TV.
Or simply split your signal and send your antenna coax to both the DTVPal DVR and your TV, then you can watch TV on your television whenever you like, regardless of what the DTVPal is doing at the time. Just beware that this cuts your signal by more than half (due to loss) so be sure you either have plenty of signal or have added a preamp to establish your noise figure prior to the splitter. Otherwise, you may make your reception poor.
Also, I advise you to purchase one of the splitters which is rated for satellite operation up to 3000 MHz. While this bandwidth is not required for television, you will likely have less loss at the upper end of the TV band.
Reg
RegGuheert is offline
post #130 of 19437 Old 12-23-2008, 06:57 PM
Scooper's Avatar
Are you getting TVGOS data ? If not - I'll bet your local stations' PSIP time is not all in sync.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #131 of 19437 Old 12-23-2008, 07:00 PM
dlhoppe's Avatar
Ok, I just did the initialize and some channel surfing. I have it connected to a "virgin" HDMI input (all settings stock flame mode) and the PQ looks very good. I can imagine how nice it's going to look after I dial things in. Once I do that, I'll be able to do some A/B comparisons to my Sony.
Other observations; Very responsive (compared to the Sony). Easy to setup. Tuner is very sensitive. Menu system intuitive. Initial PSIP guide data loaded very fast and actually is pretty accurate (kudos to the local stations on that).
Haven't done any recording yet, nor have I scheduled any. The unit is currently turned off until tomorrow so the guide data will load. I will give it a more thorough "look-see" and give updates then.
dlhoppe is offline
post #132 of 19437 Old 12-23-2008, 07:13 PM
Servicetech571's Avatar
Sorry, I was confused what you were asking. I thought you meant the output of the DTVPal through the coax - that will only give to SD on channel 3 or 4.
The TV's ATSC tuner will not pick up the output from the DTVpal DVR (or the output of anything else for that matter). You would still need a separate connection from the DVR to the TV such as an HDMI or Component cable. You are best off just to split the signal and forget the coax output is even there.
The Coax output is basically for ancient TV's that don't have video jacks. Sometimes the coax out could be used to feed an SDTV in another room while only having to run one cable. You would still need to get an IR repeater to send the remote signal though.
Servicetech571 is offline
post #133 of 19437 Old 12-23-2008, 07:49 PM
kerrym80's Avatar
see what happens if you set for 1min early
kerrym80 is offline
post #134 of 19437 Old 12-23-2008, 08:04 PM
woody777's Avatar
Quoted: 25 Post(s)
I have two questions on this unit:
1) Will it send the native resolution of broadcast? Or do you have to choose a resolution to send during setup? Or are you simply choosing the max resolution your TV can support?
2) You have to choose between PCM and DD for audio, right? If you choose DD, will it send whatever the broadcast is sending? Am I correct in thinking that not all stations send audio in DD?
Looks very promosing though!!!
woody777 is offline
post #135 of 19437 Old 12-23-2008, 08:06 PM
isnms's Avatar
You can not just tune to the channel to go back and start watching from the beginning. You have to access it from 'My Recordings' to start watching it and it will continue to record the full program as you watch.
isnms is offline
post #136 of 19437 Old 12-23-2008, 08:15 PM
Ken H's Avatar
You have to choose the output format you want in the menu, and the unit converts all output to that format. The choices for HD are 720p or 1080i. Try both to see which looks best on your HDTV.
No, all DTV stations use Dolby Digital audio, but it may not be full 5.1. DD audio can be anywhere from 1 to 6 channels, almost always either 2.0 or 5.1.
As already noted, the problem can be with the Dolby encoding hardware local stations use. If they get a 2.0 signal from the network and have the 5.1 flag set on the encoder, some audio processors (AV receiver, AV preamp, etc.) will only be able to deliver audio out of the 2 main left & right channels. When the DTVPal DVR is in PCM mode, it will allow the audio processor to use matrix decoding like ProLogic II or Circle Surround, for a simulated surround experence.
Ken H is offline
post #137 of 19437 Old 12-23-2008, 08:48 PM
NorthDallasGuy's Avatar
I'm pretty much ready to order the DTVPal DVR. About the only reason I'm waiting is to get some early reviews on the picture quality.
Specifically (assuming you watch on an HDTV...and not an older analog TV):
1) Does the live picture quality coming through the DTVPAL DVR look pretty much as good (or fairly close to) the picture quality from the HDTV alone?
2) Does the recorded playback picture quality from the DTVPal DVR look pretty much as good (or fairly close to) the picture quality as a live broadcast? (Does there seem to be any degradation in the quality from being recorded and then played back?)
Any comments would be appreciated. Thanks.
NorthDallasGuy is offline
post #138 of 19437 Old 12-23-2008, 09:02 PM
woody777's Avatar
Quoted: 25 Post(s)
Thanks! Nobody broadcasts anything past 1080i, correct?
woody777 is offline
post #139 of 19437 Old 12-23-2008, 09:05 PM
cavemaster's Avatar
Is the clock on the unit correct? Check it against your cell phone.
cavemaster is offline
post #140 of 19437 Old 12-23-2008, 09:08 PM
iwnt1's Avatar
I had the unit paused while on the phone and at 8:58 PM the dish logo comes on and then a guide update screen. The guide updated and the pal returned to live tv without any buffer to run back to where I was.
I have the time,zip and pacific zone configured right. I wasn't recording at the time so I don't know if it would stop the recording like it did last night.
Any thoughts or help? I checked the update default time and it is set for 1 AM.
iwnt1 is offline
post #141 of 19437 Old 12-23-2008, 09:10 PM
dlhoppe's Avatar
Haven't watched any recorded material yet other than pause and follow, but I'm a little concerned about something I'm seeing in the picture. During both monologues for Jay Leno and Dave Letterman, the decoration lights in the background (tree on Leno, and bridge on Letterman) were kind of flickering or pulsating in a seemingly random frequency. I was doing A/B tests to compare to the Sony and that was really standing out on the DTVPAL DVR. The Sony picture was rock solid. The pulsating almost seems like it coincides with audio spikes, but I can't be certain about that. In any case, it's not good. Otherwise the picture is clean and sharp. Very much on par with the Sony and the internal TV tuner (Toshiba DLP 1080p).
More to follow as I spend more time...
dlhoppe is offline
post #142 of 19437 Old 12-23-2008, 09:12 PM
cavemaster's Avatar
That correct's. ...And 1080"p" output is typically from BluRay players to TV's that can support it.
post #143 of 19437 Old 12-23-2008, 09:13 PM
dlhoppe's Avatar
Same thing just happened to me. Strange. Hopefully it's not a common occurance. I was watching CBS at the time. I was thinking that maybe it recognized the guide data stream and had to reset to save the "host" channel. Obviously only a guess at this point.
dlhoppe is offline
post #144 of 19437 Old 12-23-2008, 09:22 PM
iwnt1's Avatar
It happened again. I checked my recording program I forgot about and my 2hr Nova recording is now 3 separate recorded segments and I lost my short buffer. Bummer, I don't think there will be anybody at dish that can help. May be this is what they were disclaiming in their disclaimer.
iwnt1 is offline
post #145 of 19437 Old 12-23-2008, 09:37 PM
mbuchana's Avatar
Quoted: 12 Post(s)
1) My HD monitor does not have an internal tuner, so I can't answer directly, but how these compare will depend on the scaler & de-interlacing capbilities of the particular HDTV and what format conversions are being performed. I suspect any differences would be quite subtle.
2) As should be true for all DVRs when recording a digital source, there is no difference when playing back a recording vs. watching live.
Mark
mbuchana is offline
post #146 of 19437 Old 12-23-2008, 09:52 PM
Ken H's Avatar
Not over-the-air DTV, no. Both Dish Network & DirecTV have 1080p HD PPV, along with Blu-ray.
Ken H is offline
post #147 of 19437 Old 12-23-2008, 09:54 PM
bootymonger's Avatar
Quoted: 93 Post(s)
Liked: 60
iwnt1, did you get the newest firmware by connecting to an ethernet cable? Maybe that would solve your problem??
bootymonger is offline
post #148 of 19437 Old 12-24-2008, 03:01 AM
OhMyTVC15's Avatar
I don't have the unit yet but am suppose to get it today. The DTVPal converter does this update guide crap as well (why it can't do it in the background is beyond me). I am thinking that once all these DVR units get TVGOS data, it won't have to do that update guide stuff anymore. But if you are only getting PSIP data then the update guide data will happen now and then. I'm speculating here so maybe someone with the actual unit can give better info. And i believe the update default time is for software updates, not guides. Again speculation. Have you done the update to f202?
post #149 of 19437 Old 12-24-2008, 03:23 AM
RegGuheert's Avatar
Thanks for the detailed testing!
A couple of thoughts on this:
1) Is your DTVPal DVR outputting the the same resolution that the stations were broadcasting? If not, that is the likely cause of the problem.
2) One test might be to swap the two HDMI inputs on the TV to see if that makes any difference.
3) Another test might be to try swapping the two HDMI cables to see if that has any effect.
4) If it's coincident with sound, I'm also wondering if muting might make any difference. (Muting on the DTVPal DVR, if possible, but maybe muting somewhere else, like the TV or amplifier, might also be worth trying.
Thoughts?
Reg
post #150 of 19437 Old 12-24-2008, 05:05 AM
nolim2873's Avatar
Overnight it did not get TVGOS data, so I set it to the Alternate zip code for Baltimore, MD since that is the CBS station that I am receiving and it's suppose to have TVGOS data; and not my actual zip code, which is in the Harrisburg, PA DMA, but I am far from Harrisburg (I'm in PA, but close to the MD border).
If the PSIP time is not in sync than at least two stations are off (PBS and CW) by the exact amount of time (which appears 8 or 9 minutes).
Reply HDTV Recorders
