The Official AVS Dish DTVPal DVR Topic! - Page 619 - AVS Forum
 137Likes
post #18541 of 18564 Old 11-23-2014, 03:10 AM
P Smith's Avatar
Quoted: 92 Post(s)
Liked: 135
Originally Posted by kariches View Post
Thank you for responding. It looks like my best choice is to replace it with a CM 7500. Would you agree?
I could try to fix it, but it's your decision ...
phildaant likes this.
P Smith is offline
post #18542 of 18564 Old 11-24-2014, 12:34 PM
Liked: 0
Are updates still available for DTVPal units? My unit is a little glitchy and I wonder if an update may help. I've had my unit for several years and never hooked it up to the internet for an update. Thanks
bpeters2 is offline
post #18543 of 18564 Old 11-24-2014, 12:35 PM
falz's Avatar
Yes, you may download it per the instructions in the first post of this thread. I had mine attempt to auto update from the internet but it kept failing- the USB method worked.
falz is offline
post #18544 of 18564 Old 11-24-2014, 01:36 PM
phildaant's Avatar
Quoted: 416 Post(s)
Liked: 130
What version do you have? Mine came with the latest. :/
phildaant is online now
post #18545 of 18564 Old 11-24-2014, 04:34 PM
ed_in_tx's Avatar
Quoted: 49 Post(s)
Liked: 60
Press Menu,3,2,3 which should bring up your System Information and 3rd line down will show the version you have.
ed_in_tx is online now
post #18546 of 18564 Old 11-26-2014, 08:37 AM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
Sys Info key works too....
JHBrandt is online now
post #18547 of 18564 Old 11-26-2014, 08:59 AM
ed_in_tx's Avatar
Quoted: 49 Post(s)
Liked: 60
Forgot about that. Since I use a Dish 20.1 remote the system info key is the "PIP" key.
post #18548 of 18564 Old 11-30-2014, 07:29 AM
jdgomoney's Avatar
dtvpal dvr Freezing Repair
This thread has been very beneficial to me all the way back to 2009! (5yr pal owner) When I have a question about our ol' pal I come here. So I thought I'd post a problem my unit just recently experienced (it's similar to what others have experienced).
Problem:
Audio & Video freezes randomly and pal becomes unresponsive. Have to pull plug and reboot (don't necessarily have to be using remote to cause freezing). This happened on both hdmi and component outputs, the only difference being that the hdmi screen image would blink (black screen to picture over and over) whereas the component video image would be a still frozen image. This started out happening maybe once a week then every few days then every day until ultimately happening roughly every hour or so (pretty much unwatchable).
Attempted Fixes that Failed:
1.Hard drive reformat
2. Factory settings reset
3. Anything else you could think of that didn't involve disassembly lol!
Proper Repair Made:
After disassembling the pal to free up both circuit boards I found 2 bulging capacitors on the GREEN MAIN BOARD (not power supply). One bad cap was underneath the square shiny metal top (upper rh corner in pic#2) just like someone else in this thread experienced. The other one was a larger size cap close to one of the board edges (pic#1). I was able to find a tv repair man willing to replace the capacitors without guarantee of fixing the unit. I agreed and his charge was only $25!
The pal has been in use for 3 days now running quite a bit for testing and I've experienced no freezing at all, no reboots, nothing. So it's looking like problem is fixed, however, I will report if problems return.
Thanks to this thread/forum (especially hawk69) for posting problems with your own units because I have no electronic experience and wouldn't know where to begin troubleshooting. Without help my dvr would be in the trash and I would be out $250 instead of $25 for a new ota dvr.
ID:	393074   Click image for larger version
phildaant, golinux and happy2Lurk like this.
jdgomoney is offline
post #18549 of 18564 Old 11-30-2014, 07:43 AM
phildaant's Avatar
Quoted: 416 Post(s)
Liked: 130
Thumbs up
Originally Posted by jdgomoney View Post
This thread has been very beneficial to me all the way back to 2009! (5yr pal owner) When I have a question about our ol' pal I come here...
Ditto esp(ecially) when the company stopped caring about this rad(ical) DVR! I still have mine, but it is in storage for future usage (not for sale at this time) when I can get better OTA receptions.
post #18550 of 18564 Old 11-30-2014, 01:35 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
Are you moving, or just need a better antenna? I think CM has two of their biggest/best outdoor antennas on sale today, but it may have ended already. If you need an antenna, check their online store to see.
post #18551 of 18564 Old 11-30-2014, 02:19 PM
phildaant's Avatar
Quoted: 416 Post(s)
Liked: 130
Unhappy
Others and I tried RCA ANT751 and CM4228JD antenna(s/e). Both failed to get all the local stations we want. My family lives in the mountains and the small mountains/giant hills block the transmitters (wrong side).
post #18552 of 18564 Old 11-30-2014, 02:23 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
Yes that's a tough environment for OTA. Sounds like you need either to move or put in a tower!
post #18553 of 18564 Old 11-30-2014, 02:38 PM
phildaant's Avatar
Quoted: 416 Post(s)
Liked: 130
Unhappy
I wished I didn't have to be evicted to move from my old house that I lived in most of my life. It had a perfect view to most of the transmitters. The owners won't even put the antenna on the roofs. D: In attic doesn't work well. Outside in the front worked OK, but not all channels.
post #18554 of 18564 Old 12-04-2014, 01:35 PM
LenL's Avatar
Location: Randolph, NJ, 725' above sea level, 30 miles west of ESB
Quoted: 86 Post(s)
Liked: 133
Something interesting happened last nite. I was watching a recroded show from PBS. About halfway through the DTVPAL rebooted. About 30 minutes later is rebooted again. Then when it got to the end and I was watching the credits it would reboot. I would come back to the credits and it would reboot again. I gave up after about 4-5 reboots. I thought the unit was dying. However I then went to another recording of an hour and it never rebooted.
Now the PBS show did have some reception issues and some pixilation and sputtering. So I guess the OTA recording was the problem or perhaps a hard drive issue with some bad sectors?
LenL is offline
post #18555 of 18564 Old 12-05-2014, 02:04 AM
P Smith's Avatar
Quoted: 92 Post(s)
Liked: 135
looks to me it was OTA signal issues, but to eliminate HDD problems I would run Scan+Remap with taking SMART before/after (by MHDD or Victoria)
P Smith is offline
post #18556 of 18564 Old 12-06-2014, 01:42 PM
Jim in Phoenix's Avatar
Repair
Problem:
Proper Repair Made:
I had exactly the same problem about 2 weeks ago & replaced the same 2 budging caps.
So far everything is working great.
Thank You AVS Forum
Jim in Phoenix is offline
post #18557 of 18564 Old 12-09-2014, 12:07 PM
bnewt's Avatar
the link to F208 is no longer active..............is this the latest version available?
May God Guide and Guard the USA!
bnewt is offline
post #18558 of 18564 Old 12-09-2014, 12:29 PM
Aleron Ives's Avatar
Quoted: 511 Post(s)
Liked: 450
Yes. There have been no new firmware revisions for years, as the DTVPal is no longer supported.
Aleron Ives is offline
post #18559 of 18564 Old 12-09-2014, 01:14 PM
phildaant's Avatar
Quoted: 416 Post(s)
Liked: 130
Thumbs down
Yep, it was short lived.
post #18560 of 18564 Old 12-21-2014, 08:35 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
Originally Posted by ed_in_tx View Post
A new one for me: One Pal is showing 5:03PM when it's 11:03AM! The other one is OK. I have an auto-tune timer set up to tune at 11AM and it worked. Went into setup installation Time Zone and it somehow got set to Eastern, which wouldn't account for +6 hours ahead, set to Central and it corrected to the right time. Weird. Still running almost a minute fast though.
Sounds like somehow it got set to GMT internally. There's no external setting for GMT so it probably just displayed the default time zone (Eastern).
I just had the identical experience on one of my two Pals. Everything was fine except all times were displaying in GMT. I went to set the time zone and it said Eastern; changed it to Central and everything was fine again.
post #18561 of 18564 Old 12-22-2014, 06:37 AM
ed_in_tx's Avatar
Quoted: 49 Post(s)
Liked: 60
Both of mine OK. Strange problem! Now I know it wasn't just me.
One thing of note: Clocks have been running very accurately within + or - 5 seconds for at least a month, since I posted about that 6 hr glitch.
post #18562 of 18564 Old 12-22-2014, 06:52 AM
ed_in_tx's Avatar
Quoted: 49 Post(s)
Liked: 60
The no (or wrong) audio has continued to happen randomly, most recently on KDFW Fox 4 yesterday. Tuned to Ch 4, it was in Spanish, but the SAP selector had only English to select. Bumped the channel up and back to 4 to retune it, and then had English audio with both English and Spanish available to select.
post #18563 of 18564 Old Today, 03:09 PM
JHBrandt's Avatar
Quoted: 251 Post(s)
Liked: 215
And yesterday, my wife told me her Pal had the same 6-hour glitch. Once again, resetting the time zone to Central fixed it.
Since it's happened to both of mine and one of yours and we're both in the DFW area, I wonder if some local station's funky PSIP somehow triggered these anomalies?
post #18564 of 18564 Old Today, 03:26 PM
ed_in_tx's Avatar
Quoted: 49 Post(s)
Liked: 60
I thought about that possibility. Some local garbage causing it.
I happened to tune in 21.1 this morning, they were playing KLUV music and showing the burning fireplace, but when I tuned to it first time no audio. Tried switching SAP mode, nothing. Then Tuned up to 21.2 and back to 21.1 and had audio. I could now turn it on and off with the SAP button but the mode indicator stayed English.
I noticed last night Pal #2 clock time was 1 min 50 sec fast, Pal #1 still within 5 seconds of actual time.
Reply HDTV Recorders
