The Official AVS Dish DTVPal DVR Topic! - Page 621 - AVS Forum
 152Likes
post #18601 of 18607 Old Yesterday, 08:11 AM
homer86's Avatar
I have questions about the double soft reboot. Does it mean at least 2 soft reboots, or does it mean only 2 soft reboots, i.e. every other one should fix drifting clock problems?
homer86 is offline
post #18602 of 18607 Old Yesterday, 08:32 AM
Pete-N2's Avatar
at least 2 soft reboots (or power failures)
(Mark, if you are still monitoring this thread, how did you ever figure that one out?)
Jim in Phoenix likes this.
Pete-N2 is offline
post #18603 of 18607 Old Yesterday, 03:02 PM
ed_in_tx's Avatar
Quoted: 55 Post(s)
Liked: 63
An observation: Last weekend my Pal DVR #1 locked up twice in 24 hours, and I had to do a soft re-boot each time to get it to respond again. From doing that the clock has obtained lock on PSIP time and stopped drifting 8 sec a day. It was a minute and a half fast and gaining last week before the lockups. Now it's 13 sec slow matching 'Pal #2 in the other room.
ed_in_tx is offline
post #18604 of 18607 Old Yesterday, 05:48 PM
clarkss12's Avatar
Stand alone DVR using an android TV box
I started to look for a replacement for my beloved PALDVR box after I stopped getting a good guide data.. Then last month it finally bit the dust. So after months and months of trial and errors, I finally found my solution.
I wanted an inexpensive solution for a device that could play my over the air channels, both SD and HD, flawlessly. I wanted free guide data, recording, and pause/play function.
With the right $100 Android TV box and a $75 HDHomeRun dual OTA ATSC I have an awesome DVR box. However it is not an out of the box solution, it does take time to set it up.
Here is a video I made showing my setup.
andy416us, kwg and phildaant like this.
clarkss12 is offline
post #18605 of 18607 Unread Today, 12:32 AM
P Smith's Avatar
Quoted: 109 Post(s)
Liked: 147
Clark, it would be too early derail the thead to other DVR models. Many thousand of TR50 still working fine. Lets keep the thread on the topic!
phildaant and Chuck44 like this.
P Smith is offline
post #18606 of 18607 Unread Today, 06:58 AM
ed_in_tx's Avatar
Quoted: 55 Post(s)
Liked: 63
On the other hand, I appreciate the information. I wouldn't know about it had it not been posted here in this thread. Thanks Clarkss12!
kwg likes this.
ed_in_tx is offline
post #18607 of 18607 Unread Today, 07:48 PM
mabuttra's Avatar
Location: Wichita, KS OTA (w/optional cable connection)
Liked: 30
I'm still here. I discovered that the double reboot locked the clock to the PSIP data, after I had been experimenting with setting the clock manually. When I was done experimenting, I wanted to lock the clock back to the PSIP time, and thought a reboot would do it. When that didn't work, I tried the reboot again, and that time it worked. I then repeated the experiment by setting the clock off a few minutes, and verified that it took two reboots to lock the drifting clock back to the PSIP time.
mabuttra is online now
Reply HDTV Recorders
