The Official AVS Dish DTVPal DVR Topic! - Page 637 - AVS Forum | Home Theater Discussions And Reviews
 222Likes
post #19081 of 19088 Old 02-08-2016, 02:00 PM
fatherom's Avatar
Quoted: 124 Post(s)
Liked: 54
Originally Posted by ed_in_tx View Post
I would say so. It's been a year since I replaced C34 and C242 and haven't had a problem since. Be sure to select high quality 105°C low ESR low impedance capacitors.
Sweet...thanks...is there a particular online store that you used? I'm having a friend repair this for me, so if I could order the same parts you did, that would be ideal...then I know it'll work out!
Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D, Dune HD Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is online now
post #19082 of 19088 Old 02-08-2016, 10:30 PM
P Smith's Avatar
Quoted: 308 Post(s)
Liked: 224
Well, started my SW eng carrier from 1980, been in HW R&D of smartphones/eBooks from 2000, also a lot of time spent to IT fields ... online stores ? digi-key, mouser, etc ... other capacitor to replace ? use ESR meter, no need to remove from PCB. BTW, I'm re-posting the info, it been posted here before, I hope you'll take your time to be familiar with all the aspects...
Last edited by P Smith; 02-09-2016 at 09:10 AM. Reason: Typo; perhaps we will see ESM what will measure ESR with capacitance value
P Smith is offline
post #19083 of 19088 Old 02-09-2016, 06:58 AM
Pete-N2's Avatar
Quoted: 53 Post(s)
Liked: 39
Try here: The Official AVS Dish DTVPal DVR Topic! for one option.
fatherom likes this.
Pete-N2 is online now
post #19084 of 19088 Old 02-09-2016, 07:20 AM
ed_in_tx's Avatar
Quoted: 129 Post(s)
Liked: 77
Originally Posted by P Smith View Post
... other capacitor to replace ? use ESM meter...
I think that would be ESR meter. In case you look for one....
ed_in_tx is offline
post #19085 of 19088 Old 02-09-2016, 07:31 AM
ed_in_tx's Avatar
Quoted: 129 Post(s)
Liked: 77
Bought from a seller on ebay. Normally I would buy from Mouser but small orders and shipping make that not such a good deal. Check your PM.
ed_in_tx is offline
post #19086 of 19088 Unread Today, 12:45 PM
Pete-N2's Avatar
Quoted: 53 Post(s)
Liked: 39
Originally Posted by Pete-N2 View Post
October 1st is exactly one month before the DST change -- so check you recording schedule carefully tomorrow morning. That being said, I checked diagnostics this morning and the data for ION was correct. I don't expect most of us to have a problem. However, for those of you with 99 channels (and nothing to watch) anything is possible! (Diagnostics shows you about 18 channels)
Reminder: February 13th is one month before DST begins. As on this morning the data for ION and all my locals is correct.
post #19087 of 19088 Unread Today, 01:11 PM
JHBrandt's Avatar
Quoted: 792 Post(s)
Liked: 496
I set two reminders on my phone:
Tonight: Set both Pals to ignore DST
Sunday: Set both Pals to honor DST again
That should get me through Saturday safely.
JHBrandt is offline
post #19088 of 19088 Unread Today, 02:05 PM
ccrider2's Avatar
Quoted: 25 Post(s)
When I change mine to NO on Time Zone for DST, click DONE then go back, it has changed to YES????
Is there another place to change this?
Chris C
ccrider2 is online now
Reply HDTV Recorders
