The Official AVS Dish DTVPal DVR Topic! - Page 640 - AVS Forum | Home Theater Discussions And Reviews
 237Likes
post #19171 of 19187 Old 05-25-2016, 04:36 PM
therabbit78's Avatar
Liked: 3
Order has been restored, my PAL is back up and running without any issues. It is a beautiful thing. Praise the Lord, and thank you to the fine folks here.
ccrider2, JHBrandt and LuvMyDVR33 like this.
therabbit78 is offline
post #19172 of 19187 Old 07-18-2016, 06:23 PM
haiku's Avatar
Quoted: 12 Post(s)
It appears my pal is either dead or dying. It is perpetually in the "Please wait loading" stage. I have unplugged the device several times already, but every time it starts up it hangs at the "loading" stage.
I plan to keep it unplugged overnight and see if that makes a difference. Even if it does, I think it is close to the end of its life and no longer reliable. I have already ordered something else, but I was thinking about trying to repair this and use it as a backup device - or when i need to record a third program on the rare occasion.
Based on your experiences, what do you think I will likely need to do to make this function normally again? Don't need specific instructions right now; just a general description of what would need to be done to help we decide whether to make the effort or not.
Haiku
haiku is offline
post #19173 of 19187 Old 07-18-2016, 06:33 PM
wiscojim's Avatar
Quoted: 129 Post(s)
Liked: 226
The only thing I can recommend is to see if P Smith will still work on these. He's the only one that seems to have mastered them. He cured one of mine several years ago and it is still in daily use. Well worth the price!
wiscojim is online now
post #19174 of 19187 Old 07-18-2016, 08:25 PM
JHBrandt's Avatar
Quoted: 1098 Post(s)
Liked: 602
Haiku
There are a few things you can try yourself:
  1. This probably won't work but it's easy to try: boot the Pal with the antenna input disconnected. If you're lucky enough to get past "loading..." go to the menu and do a factory defaults reset.
  2. The problem could be the hard disk drive, especially if the animation of the "loading..." screen keeps freezing. If that's the problem you'll have to take it apart (not easy but doable) and replace the HDD (easy once you have it apart). You'll lose your recordings, but at least your Pal will be usable again. You can use any SATA HDD up to 1TB; the Pal will format it when you boot up again so make sure you save any old files on it first.
  3. Last resort: take it apart and look at the electrolytic capacitors on both circuit boards. Replace any that are visibly bulging. This requires soldering skill so you may want to find someone that repairs electronics to remove and replace the bulging capacitors for you.
If none of that works, you'll have to try sending P Smith a private message as Wiscojim suggested.
JHBrandt is offline
post #19175 of 19187 Old 07-19-2016, 07:12 AM
golinux's Avatar
Liked: 29
Haiku
Do you have the latest firmware installed? The current Firmware F208 is here
http://www27.zippyshare.com/v/65643705/file.html
Can't remember whether it's possible to upgrade once locked in to the "loading please wait' screen though.
May the FORK be with you!
golinux is offline
post #19176 of 19187 Old 07-20-2016, 01:55 PM
haiku's Avatar
Quoted: 12 Post(s)
Thanks for the suggestion. To be honest though, I wasn't all that happy with this device when it was working "normally." I probably won't be investing any money to fix this. Thought I might be able to fix it myself if there were some simple fixex.
haiku is offline
post #19177 of 19187 Old 07-20-2016, 02:12 PM
haiku's Avatar
Quoted: 12 Post(s)
Thanks for the help. As you thought, pulling the antenna didn't do anything.
Right after I first got the device, I replaced the HDD with a higher capacity one. I still have the stock drive and put it back in and it did not solve the problem. It was a pain to open up the case - even though I had taped over the tabs the first time I opened it. It doesn't seem to work with either drive.
In theory, both drives could be bad. I wasn't able to verify that either of these drives were working. I hooked them up to my windows 10 computer using a sata to usb adapter/bridge. The bridge was recognized but the drive was not accessible; I could not "initialize" it or assign a drive letter to it. I tried using ext2volume manager but it said it was RAW and would not mount either drive. Do I need some other special utility to mount and test these drives because of how the drives are formatted by the dtvpal?
I inspected the caps. There was no obvious evidence that any of them were blown based on anything I could see.
Thanks again.
Haiku
haiku is offline
post #19178 of 19187 Old 07-20-2016, 02:19 PM
haiku's Avatar
Quoted: 12 Post(s)
Yes, I did have the last fw for the device installed. Maybe I will copy the firmware on to a flash drive and see what happens. Perhaps it will interrupt the cycle in some fashion and give me something to work with.
Haiku
haiku is offline
post #19179 of 19187 Old 07-20-2016, 06:44 PM
haiku's Avatar
Quoted: 12 Post(s)
Haiku
Update. When I put in the flashdrive with the update on it, it changed some of the behavior of the device. After hanging at the "loading stage" for a few minutes, it would turn itself off. However, it responds to the remote and turns on. I was able to access the menu and the default reset command. However, after restarting it now hangs at the Searching for channels/find new channels" window. "No Services Stored." I touched the tuner and it is running really hot. I wonder if the tuner has failed.
It does soft reset using the remote but ends up at the channel setup menu which only has the point antenna, continue or help options. The first 2 options end up freezing. Help only goes to the help screen and only has the option to returnn to the previous screen.
Although this has not turned into a fix for my problem, it might be worth noting that a flash drive with an update on it might help someone else in the future if they need to escape a hang.
In any case, my new DVR is scheduled to arrive on Friday.
JHBrandt likes this.
haiku is offline
post #19180 of 19187 Old 07-21-2016, 12:26 PM
JHBrandt's Avatar
Liked: 602
From the symptoms you described in your last post, it does sound like one of the tuners (naturally, the one it uses to scan for channels) has failed P Smith could probably fix that but I think at the moment you'd have to ship it overseas to him. Oh, well, it was worth a try.
BTW, I don't think I've seen the trick of using a USB stick with Pal firmware to get out of a "loading" loop before. Thanks for letting us know; it may help someone else.
As for the format of the HDDs, the Pal uses a proprietary file system without an MBR. Also, the "stock" drive was shipped with a firmware setting that prevents it from powering up on a Windows PC. (That setting can be fixed; search this thread for info on the "hdparm" utility.)
If you want to reformat either drive for PC use, you can create a new MBR and partition, then format the new partition. I'm not sure how you do that with Windows 10, but with Windows 7 it's usually Start / Programs / Administrative Tools / Computer Management, then select Disk Management. Hopefully it's not too different in Win 10.
JHBrandt is offline
post #19181 of 19187 Old 07-21-2016, 01:51 PM
haiku's Avatar
Quoted: 12 Post(s)
Thanks. I just downloaded hdparm. Hopefully, it will allow me to reclaim one or both of these drives. At this point, this is probably the most I expect to get out of this. If it can, I might give it one more shot with a drive that I can confirm is actually working. Right now, the behavior seems to suggest it is the tuner but it would be good to actually rule out drive failure(s).
haiku is offline
post #19182 of 19187 Old 07-22-2016, 04:52 AM
P Smith's Avatar
Quoted: 418 Post(s)
Liked: 256
and try to use some programs to verify a health of the drive, like MHDD(selfboot/DOS) and Victoria(WinOS)
P Smith is offline
post #19183 of 19187 Old 07-23-2016, 04:01 PM
haiku's Avatar
Quoted: 12 Post(s)
That's the plan. The problem is finding something that works with a usb-sata adapter bridge. So far, nothing i have used can interactive with drives formatted by my dvr.
I justed downloaded hdparm and will look into the programs you mention too. Thanks.
haiku is offline
post #19184 of 19187 Old 07-23-2016, 06:14 PM
JHBrandt's Avatar
Liked: 602
There's a free program called "Crystal Disk Info" that will display the SMART data from a USB-connected HDD. It's not a full diagnostic, but just seeing the SMART data should let you know if there's been a problem with either HDD.
JHBrandt is offline
post #19185 of 19187 Old Today, 02:25 PM
CO_Bear's Avatar
r.i.p. cm-7000pal?
Hello...? Is anybody still in here? Am I the last person on the planet with a [semi] functioning CM-7000PAL? Should I write "Wilson" on the back of my remote so I don't feel so alone?
My CM-7000PAL that had been functioning tirelessly since November of 2011 is starting to lock up. It will freeze, flash a black screen, then flashes the frozen screen, repeat... This happens when viewing the program guide, viewing a recording, or viewing live TV. The problem is intermittent. When frozen, remote control commands make the little green light flash on the box but the remote control commands are ignored. If a program is recording it ends at the time of failure. One time I let it keep flashing and it came back after 13 minutes. Another time I let it flash for more than an hour and it was still flashing. The only remedy is to pull the plug and power it up again--then it's fine. The lock-ups are happening so often I'm worried I'll wear out the power cord prongs! The unit does not feel hot to the touch and my apartment is usually about 80 degrees. I tried cranking up the air conditioning in my apartment and had a fan blow directly on it but that didn't help.
It also goes black for maybe a quarter second when watching a recording or live TV. Hitting the 10-second rewind remote button to re-view the black-out correctly shows the program that was missed. So it looks like everything was being recorded to the hard drive--the black-outs seem to be a display issue only.
CM Support suggested I "Restore Factory Defaults" so I first removed all timers and recordings then Restored. Didn't help. I re-formatted the hard drive. Didn't help. I was surprised how fast the re-format was--I thought it would take some time to check for bad sectors on the hard drive--like the "Error checking" tool on Windows. Considering how many times that drive has spun over the last four and a half years some sectors must have gone bad. Re-mapping/de-fragmenting the drive must be going on when it's not recording. I am surprised how long that drive has lasted--I've been around since floppies flopped (the 5 1/4 inch kind) and drives have gotten so much more reliable.
Is this the capacitor issue previously reported? Someone replaced capacitors and reported that their failure had been fixed for at least a week. But that was in 2014...
It's a presidential election year and I live in a swing state--the only way I can survive TV is to record everything and 30-second skip all the political commercials!
CO_Bear is offline
post #19186 of 19187 Old Today, 02:30 PM
ed_in_tx's Avatar
Quoted: 160 Post(s)
Liked: 80
"...It will freeze, flash a black screen, then flashes the frozen screen, repeat... This happens when viewing the program guide, viewing a recording, or viewing live TV. The problem is intermittent."
Yes sounds like the capacitor problem. almost 5 years before failure, doing good!
ed_in_tx is online now
post #19187 of 19187 Old Today, 02:49 PM
CO_Bear's Avatar
And now the hard part...how much $$$ to fix it? If it's even possible. I'm not an E.E. major--I don't own a soldering iron. I don't want to buy a soldering iron...
CO_Bear is offline
Reply HDTV Recorders
