The Official AVS Dish DTVPal DVR Topic! - Page 641 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #19201 of 19212 Old 09-21-2016, 01:51 PM
L David Matheny's Avatar
Quoted: 16 Post(s)
Liked: 31
Originally Posted by vmalhotra View Post
I have spent hours looking for some instructions/photos for motherboard removal on the DTVPAL, any search 'hints' ?
This post by "Will in MKE" has interior photos and comments that might help you get the case apart. Maybe it will then be clear enough how to remove the motherboard.
L David Matheny is offline
post #19202 of 19212 Old 09-21-2016, 01:59 PM
wiscojim's Avatar
Quoted: 140 Post(s)
Liked: 229
Did you read post #1 in this topic? Once you open the case per the instructions there, it is pretty obvious that a phillips screwdriver is all you need.
wiscojim is offline
post #19203 of 19212 Old 09-21-2016, 02:07 PM
vmalhotra's Avatar
I have the case open (second time, to attempt to replace the capacitors, first time I did was to attach an external e-sata port to the unit) I just wanted to learn from experts about tips to remove the motherboard.
You got to be nuts; you want me to pay to watch commercials?
vmalhotra is offline
post #19204 of 19212 Old 09-21-2016, 02:48 PM
wiscojim's Avatar
Quoted: 140 Post(s)
Liked: 229
Remove screws mounting board to case. Push case tabs out of way to release board and front panel LED lenses.
Seriously though, if you could not visually see how to do that with the case open, do you really have the skills to replace caps on a multi-layer circuit board?
Just sayin'. You could easily end up doing more harm than good.
Good luck.
wiscojim is offline
post #19205 of 19212 Old 09-21-2016, 03:08 PM
vmalhotra's Avatar
Good luck.
Wiscojim:
Thanks for the tips and caution. I have build PCs from components, have modded the PAL to have an pluggable external eSATA drives. Here is the picture with loopback connection to internal drive and external pod. And professional looking labelling too
https://*******/photos/XPK4DFp8KLbu3jER8
ID:	1674217   Click image for larger version
post #19206 of 19212 Old 09-21-2016, 10:25 PM
P Smith's Avatar
Quoted: 445 Post(s)
Liked: 268
vmalhotra, your URL above is disguised and have no meaning now
I think you mean "built PCBA" not PCB
P Smith is offline
post #19207 of 19212 Old 09-22-2016, 05:32 AM
Pete-N2's Avatar
Quoted: 59 Post(s)
Liked: 40
The only "got ya" I can remember is release/remove the light pipe assembly before removing the screws on the board. If the board is sitting on top of the stand-offs you will have interference between the board and light pipe assembly.
JHBrandt likes this.
Pete-N2 is offline
post #19208 of 19212 Old 09-22-2016, 05:40 AM
Pete-N2's Avatar
Quoted: 59 Post(s)
Liked: 40
Originally Posted by ed_in_tx View Post
I sometimes (maybe 1 out of 5 recordings) have to do the trick where you go into the menu 3, 3 Audio Setup, switch from English to Spanish then back to English to get the audio to come on particularly on NBC (local KXAS-5) recordings. If you stop the playback and go back to the tuner you have to do it over when you resume playback. Another oddity I noticed doing this, one time I could not get the audio to come on no matter how many times I did the language switch. The tuner happened to be on MeTV or another 480i channel. I thought to change the tuned channel to the NBC channel, and it worked first time I switched the language back and forth.
+1
I see this problem only on my CBS station. And yes, the fix works better if you are tuned to the station that caused the problem.
I see this problem in about 1 out 30 recordings.
Pete-N2 is offline
post #19209 of 19212 Old 09-22-2016, 07:21 AM
vmalhotra's Avatar
Yes, that is exactly what I was looking for, I vaguely recall someone was having difficulty with.
post #19210 of 19212 Old 09-24-2016, 07:47 AM
ed_in_tx's Avatar
Quoted: 165 Post(s)
Liked: 81
My main 'Pal DVR did something odd this morning: would not turn on. Power light would flash for a second and go off, along with a brief flash of video on the TV. A Power button hold down until it reboots fixed it. Phew!
ed_in_tx is online now
post #19211 of 19212 Unread Yesterday, 10:01 AM
Liked: 0
Does anyone know how to slow down the clock on the DTVPal? I bought mine in '09, I stopped using it in '12 because the clock was too fast.
mannynyc36 is offline
post #19212 of 19212 Unread Yesterday, 10:12 AM
ed_in_tx's Avatar
Quoted: 165 Post(s)
Liked: 81
Probably you set the clock manually. They will gain time about 8 sec a day that way. To get it back in auto clock set mode, I recall you do a couple of resets back to back by holding down the power button, then let it gather time and program data from the broadcast stations, and it should come up with a reasonably close clock time. If you manually adjust it that takes it out of this automatic mode and you'll be back to gaining time again. I let mine set the clock automatically and they both stay within + / - 10 to 15 seconds. Only issue with this is if a station is sending bad time data it might throw off the time calculation with the 'Pal.
Also coming up, you will also have a day with the time "off" by an hour I recall a month before DST changes. Just leave it alone and it will probably correct itself within a day.
Reply HDTV Recorders
