The Official AVS Dish DTVPal DVR Topic! - Page 642 - AVS Forum | Home Theater Discussions And Reviews
 242Likes
post #19231 of 19247 Old 11-01-2016, 10:40 AM
OLDXTECH's Avatar
TiVo OTA tuners
First of all, the TiVo tuners seem to be equal to or better than the Dish Pal tuners, which are fine. Also similar to the old Dish tuner/converters.
HOWEVER, I am between 50 -70 miles north of Fresno, CA in the foothills so that I have to use a 30 foot tower with an 8 Bay Bowtie feeding a Channel Master mast preamp. Without the added preamp/tower/bowtie, I get nothing!
Cheers.
OLDXTECH is offline
post #19232 of 19247 Old 11-06-2016, 11:37 AM
Bozzmonster's Avatar
Red face
Final report on my now closed DTV Pal issues. I received the caps I ordered from Amazon and replaced the bulging cap at C34. Very easy to do and the motherboard was easy to remove from the case without damage. I rediscovered my soldering skills from long ago and had the cap replaced in a few minutes.
End result... no more freezups and the recording option works flawlessly. Plus, with the HD at 1Gb now, I have a lot of room to record!
I really like this unit and was very happy I was able to fix it.
Bozzmonster is online now
post #19233 of 19247 Old 11-06-2016, 02:13 PM
JHBrandt's Avatar
Quoted: 1329 Post(s)
Liked: 708
I assume you mean 1TB. (A 1GB drive would barely hold 30 minutes of SD video!)
JHBrandt is offline
post #19234 of 19247 Old 11-07-2016, 08:52 AM
You are totally correct! Fat fingers on the typing!
post #19235 of 19247 Old 11-20-2016, 08:21 PM
honeymonkey's Avatar
Could someone be so kind as to point me to the tutorials for
1- steps to remove the dvr cover to get at the motherboard
2- instructions for capacitor replacement / troubleshooting.
I remember reading it a long time ago when mine were not broken, and now I cannot find them.
Oh, and has there been any fixes for the ......loading screen issue?
I have one that has been stuck for years and kept it just incase.
honeymonkey is offline
post #19236 of 19247 Old 11-20-2016, 10:03 PM
wiscojim's Avatar
Quoted: 144 Post(s)
Liked: 236
From post #1:
Instructions to remove the cover, courtesy of AVS member otaviewer in this post:
- I unplugged the power
- Removed the smart card from the front so I didn't accidentally break it
- Removed the visible screw on the case's bottom
- Pried off the rubber pad on the case's bottom which is closest to the green and yellow RCA jack and unscrewed the screw underneath
- Pried off the rubber pad on the case's bottom which is diagonal from the one just pried off and unscrewed the screw underneath
- Looked in the slots on the bottom of the case with a flashlight to see that an object could be stuck in them and bent slightly to unlatch, except for the three inner slots with green circuit board visible which can be ignored
- I unbent four medium-thickness 1.5" (2" long measured with a ruler) cotter pins, the kind obtainable from a hardware store, to a 90 degree angle
- Inserted one end of the cotter pin straightly into either one of the two slots closest to the back of the case, to the point where it stopped on its own
- Carefully applied sideways pressure (relative to the case) to the cotter pin so the part of the cotter pin outside the case moved away from the case and the part of the cotter pin inside the case moved toward the other rear slot
- At a certain point while bending the cotter pin sideways and applying slight downward pressure, the cotter pin slipped farther into the case. I let it slide in a bit more. This unhooked the latch in the slot and allowed me to remove my hand from the inserted cotter pin during the rest of the steps.
- I repeated this with the other three slots using the other three bent cotter pins. Noted that the slots in the front only allowed me to insert the cotter pin slightly past the point where the cotter pin stopped on its own.
- I Inserted a flathead screwdriver in between the top and the bottom of the case at the closest corner to one of the back cotter pins
- Twisted the screwdriver at the corner to pry the top and the bottom of the case apart slightly but not enough to damage the case
- At the same time, with my other hand, used another flathead screwdriver to unhook the closest of the two tabs on the rear of the case. That corner of the case now opened up farther
- Removed the screwdriver from the corner of the case
- Inserted the screwdriver slightly to the outside of the tab that the other screwdriver is in, and used it to pry apart the top and bottom of the case just to the point where the screwdriver fits in between the top and bottom of the case
- Removed both screwdrivers, and noted that the top and bottom of the case remain somewhat separated
- Repeated the last six steps with the other rear corner
- I separated the top from the bottom of the case at the back of the case with my hands, without much effort, and noted that this caused the front of the case to also separate
wiscojim is online now
post #19237 of 19247 Old 11-20-2016, 10:33 PM
P Smith's Avatar
Quoted: 486 Post(s)
Liked: 279
you should read the thread, easy-peasy way
P Smith is offline
post #19238 of 19247 Old 11-21-2016, 05:03 AM
frank70's Avatar
Quoted: 104 Post(s)
Liked: 82
Originally Posted by P Smith View Post
you should read he thread, easy-peasy way
Well, to make things a little easier, start by looking at post 19201 (which, in turn, has a link to post 5383) and a few following it. I have this written on a Post-It note for when I'll eventually need it .
frank70 is offline
post #19239 of 19247 Old 11-21-2016, 08:04 AM
golinux's Avatar
Liked: 29
golinux is offline
post #19240 of 19247 Old 11-21-2016, 09:16 AM
P Smith's Avatar
Quoted: 486 Post(s)
Liked: 279
after revisiting my post with pictures, I found some of them cannot be viewed ; error message guiding to call administrator... I'm curious if he could restore eg fix it ?
P Smith is offline
post #19241 of 19247 Old 11-22-2016, 07:42 AM
golinux's Avatar
Liked: 29
I just checked a few of your images and they all came up just fine here. But when they redid the board, my old bookmarks were broken. Had to manually point them to the right place. If you still have those images, maybe you could upload them again?
May the FORK be with you!
golinux is offline
post #19242 of 19247 Old Yesterday, 12:04 PM
jcgc50's Avatar
Hard Drive replacement
Lately mine has been freezing when playing recorded video forcing a restart. However, today live TV froze too and it would not respond to the remote other than holding down the power key till it restarted.
I happened to have a 2.5" 1TB SATA drive laying around so I installed that. So far it has been at the loading please wait screen for a half hour or so. Is that normal or is this drive not going to work. I believe it was a Seagate about 2 years old.
jcgc50 is online now
post #19243 of 19247 Old Yesterday, 12:34 PM
ed_in_tx's Avatar
Quoted: 174 Post(s)
Liked: 82
Originally Posted by jcgc50 View Post
Lately mine has been freezing when playing recorded video forcing a restart. However, today live TV froze too and it would not respond to the remote other than holding down the power key till it restarted..
Symptoms are more like C34 capacitor failure. Which would also explain why the new drive won't work. When I had a HDD fail the 'Pal put up a HDD error message letting me know.
ed_in_tx is offline
post #19244 of 19247 Old Yesterday, 05:41 PM
jcgc50's Avatar
I was afraid that might be it. Is there someone out there repairing these?
post #19245 of 19247 Old Yesterday, 11:42 PM
P Smith's Avatar
Quoted: 486 Post(s)
Liked: 279
there ?
ask local TV fixing services, re-soldering the capacitor is easy task for someone who can hold soldering iron
P Smith is offline
post #19246 of 19247 Old Today, 08:42 AM
jcgc50's Avatar
there ?
I will have to check that out. I thought TV repair shops was as abundant as unicorns these days.
post #19247 of 19247 Old Today, 08:57 AM
P Smith's Avatar
Quoted: 486 Post(s)
Liked: 279
then seek cellphones' tablets' repair shops
P Smith is offline
Reply HDTV Recorders
