HD Cable Box Recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-21-2002, 02:54 PM - Thread Starter
HughScot's Avatar
Does anyone know if it is possible to record HDTV after the signal has passed through a TW HD Cable Box and before it goes to the TV?? And if it is what recorder do you use?
TIA
Hugh
Hugh Campbell
HughScot is offline
post #2 of 2 Old 01-21-2002, 04:47 PM
Ken H's Avatar
Your only choice is a analog WVHS from JVC. These cost $2k used and go for about $4k new.
It will record the RGBHV or component video and l/r audio.
Try a search for JVC & WVHS for more details.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
Closed Thread HDTV Recorders
