Looking to buy a DVHS recoder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-29-2002, 08:35 AM - Thread Starter
Fee
Fee's Avatar
Hello all!
I am in the market for a Digital VHS recorder. I been searching on the net, but I cant seem to find much stuff about them. So I was wondering what is your ideas on what the best one is? I want that has firewire out, and records in good quality. What is the price range on them? Is there any good ones under $1000? Can you record on SVHS tapes? Or do you need DVHS tapes? Thanks for you help! any feedback would be helpfull :)
Fee is offline
post #2 of 7 Old 01-29-2002, 09:16 AM
Don Landis's Avatar
Quoted: 1313 Post(s)
Liked: 373
Fee- You need to read the many threads on this subject. All your questions have been answered many many many times. Read first, then post any questions you have that you didn't understand. set the forum to go back 30 days and that should keep you busy!
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite: Edius7.53, Vegas Pro v13, Power Director15, i7-950, LG 3D TV DM2752
Don Landis is online now
post #3 of 7 Old 01-29-2002, 09:21 AM
h2ofun's Avatar
Don, I as still trying to decide if I should purchase the US JVC 30000 or the Japan 35000.
dave
h2ofun is offline
post #4 of 7 Old 01-29-2002, 09:42 AM - Thread Starter
Fee
Fee's Avatar
Thanks for the tip! Found some great info! Now Im really like the JVC 30000, but I read it has a playback bug? Are the new versions of the 30000 the same way? Any new model going to come out? Like the 35000?
Fee is offline
post #5 of 7 Old 01-29-2002, 12:43 PM
h2ofun's Avatar
Its not clear what the 30000 playback bug is. I have heard the tests were done recording from the S-video input onto tape and this is where the problem was seen.
Using the dtc100 to record firewire to the 30000 has produced NONE of these effects that we have seen. Staying digital solves many issues.
dave
h2ofun is offline
post #6 of 7 Old 01-30-2002, 12:16 AM
Don Landis's Avatar
Liked: 373
We all know that SVHS tape stock is NOT supported by any of these DVHS machines for HDTV recording. The fact that we can use it or make it usable is OK but when doing testing you should stick to the supported tape stock for best, most credible test results. Unless testing the tape itself, using DVHS tape stock should be the rule. I even used DVHS stock when first verifying the Mitsubishi compatibility. After that was established, I then went on to determine the Mits' ability to work with SVHS stock and determined the limits of acceptance. Therefore the report, I agree, may not be credible.
post #7 of 7 Old 01-30-2002, 07:40 AM
fjerina's Avatar
Quoted: 278 Post(s)
Liked: 69
This question may have been answered before but will those JVC DVHS decks be able to record and playback over-the-air broadcasts (e.g. ABC, CBS, etc.) and will take the input from the component video cables (e.g. from a Dish 6000 or HD tuner output)? Thanks.
fjerina is offline
Closed Thread HDTV Recorders
