Capture 1080i YPbPr to avi file? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-30-2002, 08:36 AM - Thread Starter
Gerald C's Avatar
I have some technical footage in the JVC W-VHS format, and I want to capture some clips at relatively low res avi (or mpeg) format.
The problem is that the JVC does not apparantly do NTSC/composite output if the source tape is 1080i; otherwise, I could use any old inexpensive capture card! (The unit will output either VGA or YPbPr).
Any thoughts on how to do this for <$1000?
Gerald C
Gerald C is offline
Closed Thread HDTV Recorders
