If recorderis DVI capable but your HDTV is not will the recorder still record in HD? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-01-2002, 01:19 PM - Thread Starter
FrankS's Avatar
I was curious what the specs are for encryption on DVI/Firewire equipted recorders. If the recorder has DVI or Firewire to accept a HD signal from HD Satellite receiver (that also has DVI or Firewire capabilities) but your HDTV does not, will the recorder still record the FULL HD resolution but display it downres'd to the HDTV (and when the TV is replaced with a compatible HDTV it will then display full res) or will it record only a downres'd picture?
FrankS is offline
post #2 of 8 Old 02-01-2002, 01:34 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
If the recorder was connected via 1394 firewire to a STB or ATSC tuner which was 5C compatable AND the programming was allowed to be copied, then yes, it would record full resolution and even output full resoltion via the component connections. If it is tagged "copy never" it won't record in the first place. The recorder may allow the copy never material to flow through the recorder out to the component jacks, but then it would be image constrained.
DVI is a non issue here because DVI is strictly a display device connection. You won't see DVI input prots on anything but display devices.
To summarize, if you can record it, then you can watch it in full HD resolution via analog connections. If it's not recordable, it must be watched constrained.
If your idea is to record premimum content and watch it later when you get a digital equipped monitor, it's not going to work.
There could be some exceptions to Image Constraint for the first few yaers where it is turned off while still keeping copy never.
Glimmie is offline
post #3 of 8 Old 02-01-2002, 08:18 PM
Erik Garci's Avatar
It is technically possible to create a storage device that records DVI signals. However, if the DVI signal has been encrypted with HDCP, then the HDCP license agreement would prohibit the recording of that signal.
Some non-display devices such as switchers, splitters, scalers, converters, and extenders have DVI inputs.
Erik Garci is offline
post #4 of 8 Old 02-01-2002, 09:25 PM
michaeltscott's Avatar
Quoted: 2708 Post(s)
Liked: 1429
Not quite true. There's are two recordable modes, "Copy Freely", which I think you're talkin about and "Copy One Generation". "Copy One Generation" content is encrypted and must be image constrained for analog HD output, unless it also contains "Image Constraint Tokens" (a flag within an MPEG-2 TS extension packet).
-- Mike Scott
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #5 of 8 Old 02-01-2002, 09:26 PM
Ken H's Avatar
Moving to HDTV recording.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #6 of 8 Old 02-01-2002, 09:27 PM
Liked: 1429
You won't see DVI/HDCP inputs on anything except displays (or possibly repeaters). The DVI/HDCP licensing agreement is pretty strict about this.
-- Mike Scott
post #7 of 8 Old 02-01-2002, 10:53 PM
Erik Garci's Avatar
Switchers, splitters, scalers, converters, and extenders are all examples of repeaters.
Quotes from the HDCP LA:
“Repeater†means a Licensed Product that has a “Repeater Function,†which is the capability to receive, decrypt, re-encrypt and re-transmit HDCP Content to one or more outputs, in accordance with the HDCP Specification.
Decrypted HDCP Content may be temporarily buffered to enable and perform the Repeater Function or image processing function (e.g., picture-in-picture display, image overlay, image enhancement and brightness adjustment), provided that such buffer shall not persist for more time than is necessary to perform such function.
post #8 of 8 Old 02-02-2002, 08:47 AM
Hot
Hot's Avatar
If I have a digital display with only one DVI/HDCP input and have two receivers with DVI/HDCP outputs, are there any switches which will let me change sources?
Currently I have two receivers with component outputs. I connect them through a switch to the one component input on my HDTV.
Will I be able to do this with DVI/HDCP connections?
Mike aka Hot
Hot is offline
Closed Thread HDTV Recorders
