Recording to a MAC from a Scientific Atlanta 8300HD SA8300HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-23-2009, 05:34 AM - Thread Starter
umenon's Avatar
Quoted: 645 Post(s)
Liked: 206
I have a SA8300HD from COMCAST ... running SARA. Firewire is enabled.
I have read the several hundred posts on "Recording to a PC ...".
I am able to record to a PC using VLC (videolan) ... but the 1080i recordings periodically show very frequent pixelization which has been reported by other PC users who tried this technique.
Since I am desperate (have quite a few valuable recordings on the DVR) ... I might end up buying a Mac Mini.
But the $$$ question is ... does any know if the pixelization will continue to be problem via the Mac platform as well ?
Can anyone share their Mac-based experiences.
Thanks !!
umenon is offline
post #2 of 4 Old 04-25-2009, 05:33 AM - Thread Starter
umenon's Avatar
Quoted: 645 Post(s)
Liked: 206
umenon is offline
post #3 of 4 Old 06-10-2011, 05:36 PM
jdherman40's Avatar
How did you accomplish this? Cox cable has made a house call, only to tell me that it cannot be done --that they are "for future use." I have already downloaded the VLC software that one of the Geniuses at my friendly, local Apple store pointed me to.
I bought the double-ended Firewire cable.
QUESTION: How can I activate these 2 1349 OUT ports?
RSVP: jdherman@hotmail.com
jdherman40 is offline
post #4 of 4 Old 06-10-2011, 05:47 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Thanks !!
I'm pretty sure the SA boxes introduce the glitches you mention due to hardware/software problems in the DVR? What you can try doing is recording a couple shows on the dvr, then play them back and record to a PC/Mac and note the points where glitches occur. Go back to the DVR and see if they are present on the DVR during playback. If not, then try re-transferring through firewire and note if it re-occurs and if in the same location.
Mac's will record through firewire once you download and install the Apple Firewire SDK 26. I use it every day and have both PC's and a Mac.
qz3fwd is offline
Reply HDTV Recorders
