Bell PVR 9242 - Without Bell Service? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-31-2009, 11:50 AM - Thread Starter
vlrafspv's Avatar
I owna Bell PVR 9242 but I'm tired of paying for the Bell Expressvu service. Is it possible to attached an HD antenna and use the PVR with it, without subscribing to Expressvu?
Bert
vlrafspv is offline
post #2 of 7 Old 08-31-2009, 01:02 PM
walford's Avatar
Since the 9242 only supports satellite broadcast signals and does not support OTA analog or digital broadcasts how would you expect to get any satellite broadcasts for it you do not have their service?
http://www.bell.ca/shopping/HD-PVR-P.../62129.details
walford is offline
post #3 of 7 Old 08-31-2009, 01:08 PM - Thread Starter
vlrafspv's Avatar
Well, there is an "Antenna In" coax input in the back of the unit.. I assumed it was for plugging in an Antenna... but I can't get the signal to get to the TV (my receiver is currently not hooked to the expressvu dish).
Why would there be such an input then?
vlrafspv is offline
post #4 of 7 Old 08-31-2009, 05:28 PM
walford's Avatar
I assume that the antenna in connector on the back of the unit is for input from the satellite antenna.
walford is offline
post #5 of 7 Old 08-31-2009, 07:21 PM - Thread Starter
vlrafspv's Avatar
There are two Satellite inputs (since it's HD there are two cables from the dish) and separately there is a Antenna input and a Cable input. I'm still thinking there may be a way to use it without subscribing to Bell.
Anyone else has some thoughts?
Bert
vlrafspv is offline
post #6 of 7 Old 08-31-2009, 08:53 PM
Ken H's Avatar
None of the cable or DBS DVR's work unless they are subscribed.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #7 of 7 Old 09-01-2009, 05:26 AM - Thread Starter
vlrafspv's Avatar
That's unfortunate. Thanks for the answer guys.
vlrafspv is offline
Reply HDTV Recorders
