Convert HiPix files to 480P - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-26-2002, 11:39 AM - Thread Starter
gwalborn's Avatar
I am considering the purchase of a HiPix HDTV card. Is it possible to downconvert HiPix transport streams to another format? In particular, I would like to be able to take a 1080i stream and convert it to 480p. How difficult is this?
Gary D. Walborn
gwalborn is offline
post #2 of 3 Old 02-26-2002, 09:10 PM
PVR
PVR's Avatar
Yes it is possible.
Ben Cooley wrote a utility that lets you extract
the MPEG2 data then you can use other utilities
to re-encode it with different characterestics.
Check out this topic:
http://www.avsforum.com/avs-vb/showt...hreadid=118518
PVR is offline
post #3 of 3 Old 02-27-2002, 06:12 AM - Thread Starter
gwalborn's Avatar
That's exactly what I was looking for!
Gary D. Walborn
gwalborn is offline
Closed Thread HDTV Recorders
