Channel Master CM-7000PAL HD DVR - AKA Dish DTVPal - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #721 of 790 Old 08-17-2014, 02:53 AM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
it's written on many pages in that main thread about DTVpaDVR - the remotes are the same, just a couple buttons [CC, sysinfo, power] has different names
P Smith is offline
post #722 of 790 Old 08-17-2014, 02:57 AM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
Originally Posted by Hankw69 View Post
Have to state AGAIN... Unless the reported failing units have defective soldering under the LSI chip with the Ball Gate Array (BGA), I'll bet dollars to doughnuts problems like these can and are caused by DEFECTIVE CAPS.... THIS is probably a better assessment........ (I know of a good optometrist Mr. Smith ;-)
I don't know how many TR50 you did fix, but seems to me your knowledge a little short.
A.There is no LSI chip.
B. Usually bulged caps (by my own statistics around 50+ fixed devices) are NOT the case.
C. Many cases related to developed bad BGA contacts during time of using (head/cooling cycles).
P Smith is offline
post #723 of 790 Old 08-17-2014, 09:09 AM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
Thanks for the immediate info. Link at
http://www.ebay.com/itm/321418554112...84.m1497.l2649
has one for $6.36 with free "standard shipping"... My original is still working and just wanted to have a spare on hand..
Hankw69 is offline
post #724 of 790 Old 08-17-2014, 10:19 AM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
deleted to repost with pix....
Last edited by Hankw69; 08-17-2014 at 10:30 AM. Reason: deleted to repost with pix....
Hankw69 is offline
post #725 of 790 Old 08-17-2014, 10:27 AM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
Mr. Smith, IF I understand that the TR50 and DTVPal are identical in design then my observations in my ONE repair(my unit-DTVPal), I can state that there IS an LSI chip on the main motherboard, under the front left metal shield/cover. A quote from Wikipedia "Further development, driven by the same economic factors, led to "large-scale integration" (LSI) in the mid-1970s, with tens of thousands of transistors per chip." The way an integrated circuit is mounted is dependant on the number of circuits that is contained inside the chip itself. The multitude of connections that these LSI chips need to communicate to the other devices circuitry require a different method to solder via small balls to the circuit board pads. BGA (Ball Grid Array). Regarding the bulging tops on capacitors, I would be remiss if I performed a repair without replacing any cap I saw that had a bulging top, even thought its function was not associated with the reported problem. Although these "bulgers" may still function properly, you will have to agree that they ARE on the way to failure and their replacement would be mandatory for a proper service repair... I hope in your 50+ repairs that you DID replace ANY cap that was bulging... Even though you may have measured/tested them as "good"... I have attached two jpg's one of a TYPICAL BGA chip, in this case an Intel chip and another that does show an LSI chip that is used in the DTVPal, (front left).... Again the link for the LSI chip used in the DTVPal is : http://www.alldatasheet.com/datashee...S/STI7109.html
A block diagram attached shows that there is a ton of functions that this LSI chip provides..
Your assessment of the cause of BGA failure is quite accurate and proper. Even slight printed circuit board flexing will be detrimental to the mounting of thee chips...
That's my story and I'm sticking to it.. :-)
I still know a good optometrist :-)
reposted with pix, I hope...
Name:	DTVPAL LSI BLOCK DIAGRAM.jpg
ID:	216209   Click image for larger version
ID:	216217   Click image for larger version
Name:	PAL PCB-mod.jpg
Hankw69 is offline
post #726 of 790 Old 08-17-2014, 11:33 AM
FeedMeNoSpam's Avatar
Thumbs up Over A Week Later And Still Spinning
So continue the adventures of the CM7000PAL post repair shop visit.
It's been over a week and the repaired CM7000PAL with it's replaced capacitor is working like a champ
Still using the WD Blue label drive that came in this unit. Haven't seen anything in the way of bad behavior out of it. Noted one event that did not get recorded, but that was caused by the station dropping it's signal not what I would consider the CM7000's fault - I had a Magnovox DVR set to record the same event and they are like old VCRs and go off no matter what and it recorded ~10min of dead air before the station got itself back on the air, so no wonder the CM7000 just dropped the job...that's just the way they are
FeedMeNoSpam is offline
post #727 of 790 Old 08-17-2014, 02:54 PM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
I do not know what soldering skills you may have, but, it is not really that difficult to perform some of the repair work yourself. My suggestion is to buy some surplus printed circuit boards to practice on, and if you eff one up-no problem. A good soldering iron is key and to use enough heat WITH soldering wick that contains rosin flux(dried and is evident when heated). It is my opinion to use a bit higher heat ~700 ' for a shorter time than to cook at a lower tip temperature for a longer time. Remember that the circuit boards used are multi layered and will take a bit more heat to successfully un-solder a component. The wick works best for me and a little "wick wiggling" helps in the de-soldering process. whatever you do, do not force the component removal as you DO NOT want to lift a solder pad. Again, several practice sessions with junk PCB's will provide good practice. As I have posted before in the DTVPal thread, I had similar issues with the unit dropping audio and then freezing up. A reboot only "fixed" the problem for a short time. After getting frustraited(sp) -pi$$ed enough to open the box and take a look, I found that some electrolytic capacitors had entered a failure stage indicated with "BULGING TOPS"... YES, I also have some broken cover tabs and as long as the unit sits nicely on my audio/video wall, I figured what the heck I'll just live with it. Anyway, I am glad that I looked under the hood and spotted and replaced the bad caps which DID SOLVE my freezing issue... (I still have a bag of 30 new replacements to replace, just because they are old and for 19 bucks for 34 caps - well - it's a no-brainer to do preventative maintenance, with four already R&R'd). I realize that someday I'll have to get a new box but am holding off as long as I can. My present setup is using the component outputs feeding a component splitter-1 in and three out. These feed the main TV, the BR TV and the last output to a Hauppague 1212 PVR to record to file then disk the shows saved on the PAL. The Toslink output from the PAL runs to the DVR and is looped back to my Sony receiver. This requires the DVR to be powered on all the time, but BFD with <10W draw. Anyway if you like the PAL, fix what you can until you want/need to upgrade as it really does a great job when you maintain/repair the occasional component failures... Whew-too many words. enuf for now.. Good Luck...
Hankw69 is offline
post #728 of 790 Old 08-17-2014, 03:30 PM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
Well, the chip usually named by mfg and model: STMicro STi7109 (I forgot the ancient acronym LSI because today it's a company name what produce a lot of different chips include SC2000 for STB).
BTW, please remove middle picture, it's totally wrong BGA layout of STi7109 used in TR50.
P Smith is offline
post #729 of 790 Old 08-17-2014, 03:36 PM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
IF I am not mistaken, I DID state the pix of the BGA was of an INTEL CHIP - to illustrate what a BGA underside looks like, NOT the actual PAL chip.... Thank you.. My earlier post - AS stated below..
Prescription Glasses should be considered................
Last edited by Hankw69; 08-17-2014 at 03:41 PM. Reason: Additional info of previous post included...
Hankw69 is offline
post #730 of 790 Old 08-17-2014, 03:38 PM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
sorta out of thread's content ...
P Smith is offline
post #731 of 790 Old 08-17-2014, 03:50 PM
Hankw69's Avatar
Quoted: 28 Post(s)
Liked: 36
IF sharing with the members details of the components used in the CM7000/ PAL is permitted, I will give examples of TYPICAL component attributes/build structure and the Intel BGA pix showed a good example of what we speak of when we mention B G A.... I'm done...
Hankw69 is offline
post #732 of 790 Old 08-17-2014, 05:58 PM
Thumbs up Thanks for the advise for DIYSers
I am too chicken to try any "solder your" own on a board in a CM7000PAL. Loong ago, far away in another age I was in an electronics training program and it was fairly well proven I should stick to black box level work ;> I do fine with that sort of fix it actions.
Everything I ever tried to solder that was electronic parts involved turned up DOA... So I stick to just soldering wires and such - those I have no problems with ;>
post #733 of 790 Old 08-26-2014, 04:46 PM
squiddiddler's Avatar
Liked: 0
Would this model be a direct replacement for the original PAL 5.3 remote OR it being a "learning remote", would it need to be programmed with my still working 5.3 unit?? Thanks for the info...
Get the Dish network 5.3 ir. 148785. Exactly the same except the button markings.
squiddiddler is offline
post #734 of 790 Old 09-13-2014, 11:17 PM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
see the thread's last page - there you'll find encouraging posts how to fix your Pal by change capacitors (typical failure and typical DYI)
http://www.avsforum.com/forum/42-hdt...-avs-dish.html
P Smith is offline
post #735 of 790 Old 11-17-2014, 08:09 AM
Liked: 0
Frozen Channel Master Loading Screen.......
Hello,
My channel master 7000pal is stuck on the loading screen (which is what you normally see when setting up the device). I unplugged it let it sit for a week but when hooking it back up its still stuck on that screen. I called the 800 number but they didn't help, just wanted to sell me a newer unit. I cannot believe these devices don't have a hard or soft reset button to resolve issues like this. Has anyone experienced this and if so, were they able to resolve the problem?
marci1111 is offline
post #736 of 790 Old 11-17-2014, 08:25 AM
JHBrandt's Avatar
Quoted: 1553 Post(s)
Liked: 768
Could be several problems. Here are two possibilities you can do something about:
  1. Bad hard drive. The word "loading..." should "throb" smoothly between red and black when you power it up. If it's jerky or frozen instead, you may need to replace the HDD.
  2. Corrupted timers. Did your Pal freeze up shortly after daylight saving time ended? If so, this could be the problem.
Could also be a different problem such as corrupted firmware, but let's hope it's one of the above.
You can try to fix corrupted timers by disconnecting the antenna cable, then plugging it in. Hopefully this will get you past "loading..." so you can get to a menu. If so, immediately reset to factory defaults (Menu-3-2-4). You can then reconnect the antenna cable (the Pal will scan your TV channels again). Once the reset is done you should be OK to re-enter your recording timers.
Unfortunately the CM-7000Pal is no longer produced, so CM can't repair or replace it. (They can only sell you their new DVR+.)
JHBrandt is offline
post #737 of 790 Old 11-17-2014, 05:27 PM
Liked: 0
Hey BRandt,
Now that you mentioned it, the problem did start on Nov 3, the day after daylight savings.....Its not the HD, I just replaced that 3 months ago. So I did disconnect the antenna, but its not helping it. I opened up the unit and disconnected the HD to see if that would help it. Nothing is moving it past the loading screen. The DVR lights come on when I plug it in but then the unit shuts down after about 5/10 secs and the loading screen just continues to display on the tv even though the dvr has shut down.
But yes, it did happen when the daylight savings went into effect. Anything else you can suggest?
post #738 of 790 Old 11-18-2014, 08:33 AM
Liked: 0
Does anyone repair these DVR's on here?
If anyone is able t repair my cm 7000-pal, please let me know. Its stuck on the loading screen. Problem started after daylight savings took place. Tried troubleshooting and it will not bypass loading page. No service techs in my area will attempt to work on this DVR. If you know anyone I can send my DVR to be repaired, please reply to this thread.
post #739 of 790 Old 11-18-2014, 09:02 AM
Kelson's Avatar
Quoted: 1959 Post(s)
Liked: 1150
This pretty much sounds like you have the PAL loading bug which is generally the kiss of death -- corrupted firmware. User @P. Smith used to service the DTVPal DVR's by re-flashing the corrupted firmware into the ROM -- but that was before he moved from Ca back to Greece. Even so, it is probably not possible for the CM-7000 because there never was a firmware update released for it, which means there is no firmware file anyone could use.
Still, I guess one could try and flash the DTVPal DVR F208 firmware -- what would you have to lose. But other than @P.Smith, no one else did the repair. If he is out of business, you are pretty much out of luck and probably should start thinking about your next DVR.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #740 of 790 Old 11-18-2014, 09:55 AM
Liked: 0
Great, thanks for the reply
post #741 of 790 Old 11-18-2014, 10:24 AM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
actually, I'd like to help ... send me PM
P Smith is offline
post #742 of 790 Old 11-18-2014, 10:42 AM
JHBrandt's Avatar
Liked: 768
Originally Posted by marci1111 View Post
Hey BRandt,
The highlighted part is actually normal behavior - but if the "loading..." doesn't go away after 45 seconds or so, even with the antenna disconnected, then you probably need the firmware re-flashed.
Go ahead and check with P Smith and see if he can help. If you can get the DVR to him, he can probably re-flash the firmware from a good unit. Shipping won't be cheap but still beats a new Pal, or even a DVR+....
JHBrandt is offline
post #743 of 790 Old 11-18-2014, 03:07 PM
Kelson's Avatar
Liked: 1150
He can't, he only has 5 posts. You need to send him the PM.
JHBrandt likes this.
- kelson h
Kelson is offline
post #744 of 790 Old 12-10-2014, 09:32 PM
bobbyc's Avatar
Quoted: 64 Post(s)
Liked: 37
If anyone is looking for a working CM7000PAL, I put mine on ebay this evening. item id 281526819232
bobbyc is offline
post #745 of 790 Old 12-23-2014, 09:48 AM
a1pilot's Avatar
Liked: 0
Hi all,
First of all thanks for the many posts about CM7000PAL (timing) issues. After more than a few years my unit starting locking up a couple of months ago, so I researched all the input and found the 2 bad capacitors, which I replaced and it's back to normal now- THANK YOU!!
On a related note, I wanted to update my firmware, and knowing that CM no longer provides CM7000 updates, thought that the F208 firmware would work for me. What I downloaded, was "phpQYEZB5" which was then renamed to "TR50_F208_0HUC00.upd" but neither of these work on my CM7000 PAL. (it says the current software is F480 TALD-N)
Any suggestions on (a) what I might be doing wrong, or (b) where I can get the right version for the CM7000?
a1pilot is offline
post #746 of 790 Old 12-23-2014, 12:15 PM
JHBrandt's Avatar
Liked: 768
AFAIK there were never any firmware updates for the CM7000 Pal. Mine came with F400, as I think everyone's did. The CM7000 Pal only allows newer firmware to be loaded, and the latest DTVPal firmware was F208, which it considers an older version and won't load.
But apart from cosmetics, AFAIK no one has ever identified any difference between F208 and F400.
JHBrandt is offline
post #747 of 790 Old 12-23-2014, 01:22 PM
a1pilot's Avatar
Liked: 0
Thanks, I guess then if it ain't broke, don't fix it!
a1pilot is offline
post #748 of 790 Old 12-28-2014, 08:38 AM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
Originally Posted by a1pilot View Post
Hi all,
Sorry, it cannot or doesn't say that. Wrong FW number.
Next time just post a picture, it will help you avoid mistyping.
P Smith is offline
post #749 of 790 Old 06-24-2015, 10:05 PM
Liked: 0
Hello P Smith,
I have run into the dreaded......"Loading. Please wait...." boot loop.
Have atte4mped all the online techniques....unplugging this and that.....have checked the supply voltages...all look good. albeit the fan seems to be slow....
do you offer .......?
or do you have any suggestions?
thanks,
viewlynn
viewlynn is offline
post #750 of 790 Old 06-24-2015, 11:46 PM
P Smith's Avatar
Quoted: 562 Post(s)
Liked: 304
you could send it to me ...
viewlynn likes this.
P Smith is offline
Reply HDTV Recorders
