DirecTV HR 24 HDMI Brightness - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 09-13-2011, 06:38 AM
randys1's Avatar
no
randys1 is offline
post #32 of 36 Old 09-13-2011, 07:16 AM
veryoldschool's Avatar
Originally Posted by e3racin1 View Post
i just ordered this receiver. Is this issues still happening, or has it been fixed by a firmware update.
When "the problem" is in the TV you're connected to, it isn't going to be fixed with a receiver firmware update.
My Sony TV had no problem recognizing the RGB signal over HDMI.
A.K.A. VOS
veryoldschool is offline
post #33 of 36 Old 09-13-2011, 10:19 AM
e3racin1's Avatar
Thanks for the replys. I have a samsung UN55B7100 and calibrated it with my eye 1 pro with calibration disks ran from my ps3, my concern is that the picture will "look" different when running through the RGB since i calibrated using the ps3 setup to output with YPbPr...Any opinions on this?
e3racin1 is offline
post #34 of 36 Old 09-13-2011, 11:02 AM
rdgrimes's Avatar
Quoted: 2086 Post(s)
Liked: 1416
If the display is correctly set up to accept RGB-Video levels, it makes no difference at all. The display will convert RGB to 4:4:4 anyhow.
rdgrimes is offline
post #35 of 36 Old 09-15-2011, 09:58 AM
Droid6's Avatar
Still hasn't been fixed.
Droid6 is offline
post #36 of 36 Old 09-15-2011, 10:56 AM
It's hard "to fix" something that isn't broken.
The chips [hardware] in the HR24-500 output RGB. If the TV knows what to do with an RGB signal, there's nothing to fix.
If the TV doesn't know what to do with an RGB signal, then the TV needs to be fixed.
A.K.A. VOS
Reply HDTV Recorders
