Verizon Fios Motorola 7232 - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #241 of 479 Old 08-03-2011, 04:07 PM
rg-one's Avatar
When I picked up my 7232-2 a few months ago, the rep told me some were 250GB and some were 500GB, or that the 250GB was enabled now, and they would "enable" 500GB in the future...
This obviously sounded like lack of knowledge, anyone know how I can actually confirm the capacity on my specific box?
Oh btw, I got mine by just walking into the FiOS store with my old box and requesting it, I might have said it was getting HDMI issues or something, but I don't think I even had to give an explanation. Helps to get the guy on your side a little first with friendly small chat. This new box is great, a little snappier, and MUCH cooler running and less power drain. Really helps in the summer heat when it's in an AV cabinet.
Also finally glad to know what dU1 means, I always laugh to myself and imagine it means DUI (driving under the influence).
rg-one is offline
post #242 of 479 Old 08-07-2011, 11:30 AM
IslaTurbine's Avatar
I'm thinking about dumping TWC with my Motorola DCX dvr and going back to FIOS.
Does FIOS have a true 16:9 guide?...or at least one that fills up the whole screen even on HD channels?
IslaTurbine is offline
post #243 of 479 Old 08-07-2011, 11:38 AM
markjrenna's Avatar
Quoted: 13 Post(s)
Yes. IMG 1.9.
Only in these areas so far:
Harrisburg, PA
Buffalo, NY
Syracuse, NY
Buffalo, NY
Temple Terrace, FL
Pittsburgh, PA
It is planned to come to the following in the next few months:
Carrolton, TX
Pomona, CA
Palm Springs, CA
Queens, NY
Burlington, MA
Providence, RI
Freehold, NJ
Philadelphia, PA
Silver Spring, MD
Richmond, VA
Norfolk, VA
There are also some areas that are using the Cisco DVR and that has 1.9 on it already.
markjrenna is offline
post #244 of 479 Old 08-07-2011, 11:40 AM
Thanks for the quick reply.
So I guess that means only the Cisco DVRs can run it and the Motorolas won't?
post #245 of 479 Old 08-07-2011, 11:49 AM
markjrenna's Avatar
Quoted: 13 Post(s)
No. Verizon decided not to rely on only one manufacturer... Motorola. In some areas they are using both Motorola and Cisco. All areas over time will have 1.9 on both. The new Cisco boxes come with 1.9 regardless of where 1.9 has been rolled out or not. All existing Motorola boxes will get 1.9 per my list in my prior post.
post #246 of 479 Old 08-07-2011, 01:13 PM
s2silber's Avatar
How does the Cisco HD DVR compare with the newest and most updated version of Motorola's HD DVR?
s2silber is offline
post #247 of 479 Old 08-08-2011, 12:50 PM
scott_bernstein's Avatar
Quoted: 35 Post(s)
Liked: 25
No, the Ciscos will run it too, but Verizon is just slow in rolling out the new guide to all of their nodes. It's coming SOON (hopefully no more than 1 month away?) everywhere.
scott_bernstein is offline
post #248 of 479 Old 08-08-2011, 12:53 PM
markjrenna's Avatar
Quoted: 13 Post(s)
1.9 is on hold due to the strike.
post #249 of 479 Old 08-08-2011, 01:26 PM
Quoted: 35 Post(s)
Liked: 25
Actually, I wouldn't say that. They are moving forward in areas that are not affected by the strike.
post #250 of 479 Old 08-08-2011, 01:42 PM
markjrenna's Avatar
Quoted: 13 Post(s)
I wouldn't say it if it wasn't true. 1.9 is on hold.
post #251 of 479 Old 08-08-2011, 01:56 PM
Quoted: 35 Post(s)
Liked: 25
How is it on hold if deployments are continuing now? The definition of "on hold" would be that deployments are not continuing. But they are....
post #252 of 479 Old 08-08-2011, 02:17 PM
markjrenna's Avatar
Quoted: 13 Post(s)
Keep me informed when it starts again. Until then, it is on hold.
post #253 of 479 Old 08-08-2011, 04:25 PM
My service gets set up this Thursday. I'll post if I'm able to get my hands on a Cisco unit. Fingers crossed.
post #254 of 479 Old 08-09-2011, 06:22 AM
crankerchick's Avatar
Quoted: 12 Post(s)
Hmm, I don't believe that to be true. I thought the Cisco boxes still have to be updated to 1.9 according to the rollout. My Cisco box certainly does not have 1.9...
crankerchick is offline
post #255 of 479 Old 08-09-2011, 06:30 AM
markjrenna's Avatar
Quoted: 13 Post(s)
When did you get your Cisco box?
post #256 of 479 Old 08-10-2011, 06:11 AM
Quoted: 12 Post(s)
I got it I guess over 6 months ago. I guess I got it too early to have it come with 1.9?
post #257 of 479 Old 08-10-2011, 08:00 AM
markjrenna's Avatar
Quoted: 13 Post(s)
Exactly.
post #258 of 479 Old 08-11-2011, 07:36 PM
Well they came and installed today. I pleaded for the Cisco 435 but the tech said they didn't have them in this area (north DFW, TX). So now I'm the owner of a Moto 7232 running 1.8. Oh well.
post #259 of 479 Old 08-12-2011, 08:44 PM
ClemsonKev's Avatar
Just got Verizon FIOS last week. I like it so far, but we have the whole house DVR and the two secondary STB's won't SKIP and REPLAY like the main DVR will........ any suggestions?
thanks!!!
Kevin
ClemsonKev is offline
post #260 of 479 Old 08-13-2011, 06:28 AM
Fant's Avatar
Frankly I've given up ... They have been saying soon for so long. I even got an email saying it's coming and they have an entire channel showing you how to use it. It's frustrating that they can't just push it to everyone or allow individuals to pull it. If it's deployed in several areas already what is the reason they need to do one city at a time?
Fant is offline
post #261 of 479 Old 08-13-2011, 06:54 AM
jmschnur's Avatar
Can the ehternet port on the back of the 7232 (or 7100 for that matter) be used as a bridge to the internet for a normally connected unit? if not in 1.8 does 1.9 enable this
I would like to ue this connection to enable my integra 80.2 for the network rather than using a wi fi bridge.
jmschnur is offline
post #262 of 479 Old 08-13-2011, 07:25 AM
Jakes's Avatar
thanks!!!
Kevin
Hi,
You need to enable this in the STB settings. You can set the skip and replay intervals.
Jakes is offline
post #263 of 479 Old 08-13-2011, 07:40 AM
markjrenna's Avatar
Quoted: 13 Post(s)
No. Unfortunately. But there are solutions to get the IP Ethernet equivalent at your TV without running an Ethernet cable from your FiOS router. You can use Moca adapters to get the IP that is already on the coax at the STB. You can also use IP over power line adapters. Another suggestion is to use a wireless bridge/access point.
These will all work but you will have to determine what is best in your specific situation.
post #264 of 479 Old 08-13-2011, 08:21 AM
jmschnur's Avatar
I am using an wf fi ethernet bridge (buffalo) - just hoping for an easy wired connection.
jmschnur is offline
post #265 of 479 Old 08-13-2011, 08:21 AM
ClemsonKev's Avatar
Originally Posted by Jakes View Post
Hi,
Someone else said I would need the update (1.9a) for the skip/replay to work on the STB's.
Is that your understanding?
When will we get that in Mass?
post #266 of 479 Old 08-13-2011, 08:27 AM
markjrenna's Avatar
Quoted: 13 Post(s)
You DO NOT need 1.9 for SKIP or REPLAY on your non DVR's. You do need to have a DVR with Multi Room DVR enabled and watch a recording from the DVR on a non DVR. You can indeed, SKIP and REPLAY.
post #267 of 479 Old 08-13-2011, 08:35 AM
ClemsonKev's Avatar
hmmmm. I do have Multi Room working: I can watch, ffw and rewind shows from the DVR downstairs. I can even change the settings from 10 sec to 30 sec, etc.
STILL, my two STB's will NOT let me use the skip/replay feature on those STBs like I can on the DVR itself.
Maybe I should call tech support about these Cisco boxes?
post #268 of 479 Old 08-13-2011, 08:40 AM
ClemsonKev's Avatar
Moved into GRAFTON MA and got FIOS hooked up on 8/5/11 before the strike up here.
Got the whole house DVR with CISCO boxes and 1.9 installed.
Can't compare to Motorola b/c I never had that box or FIOS before.
Anyone know what 1.9a will bring?
post #269 of 479 Old 08-13-2011, 08:53 AM
jmschnur's Avatar
I looked up moca. Seems interesting. What rates will I get to the actiontec router. 100, 1000 (with g) or less?
Google is great. Answered my question. 175 bi directional 275 one way.
jmschnur is offline
post #270 of 479 Old 08-13-2011, 08:54 AM
markjrenna's Avatar
Quoted: 13 Post(s)
You can read all the opinions and some scattered facts here:
http://www.dslreports.com/forum/r252...Peak-has-begun
http://www.dslreports.com/forum/r257...G-1.9-is-live-
http://www.dslreports.com/forum/r258...G-1.9-is-dead-
http://www.dslreports.com/forum/r260...e-1.9-upgrade-
http://www.dslreports.com/forum/r260...-the-network.q
http://www.dslreports.com/forum/r261...to-the-network
Reply HDTV Recorders
