Official Moxi Hard Drive Replacement Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
Old 10-13-2014, 11:48 AM
Quoted: 13 Post(s)
Liked: 0
I will thanks I am still glad I got the moxi from you no problem there just want to get it going
firemanret is offline
Old 10-13-2014, 12:33 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Originally Posted by firemanret View Post
Samsung hd204ui hd204ui/z4 and I try a wd wd10ears 1.0 tb and a Samsung hd501lj and a heads up this is MARK"s old dvr
It seems like you need to get a new drive that others have had success with. In the document, nobody ever reported on that Samsung hd501lj drive, or on a Western Digital EARS, but there has been success with the WD EADS line. We know that the Samsung hd204ui works, but now that drive may have mechanical issues, as you had mentioned.
Mark
giomania is offline
Old 10-13-2014, 12:36 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
I did find out ATT Uverse you can't do Udp I called my charter after an hour on the phone last night found out my modem and all the support udp
I realized that Charter was the cable company renting the Moxi to their customers, so I would think that all communications on the ports for the retail Moxi should work, unless they do something special in the customers router. Does anyone else think this is logical?
If so, that is another indicator that the drive in the box has suffered a mechanical failure, I think.
Mark
giomania is offline
Old 10-13-2014, 12:37 PM
VisionOn's Avatar
Liked: 2011
Originally Posted by giomania View Post
I did not delete it from my Moxi account until he got it up and running initially, so I think you may be right; it makes sense to me. I think he should create a Moxi account and then try again
If that is the case it may be a problem. If the box needs to be registered to an account before the FFP will reinstall and he doesn't have a drive with a functioning OS to create an account to register the hardware, then there is no way to link the hardware.
The best method might have been to have had the unit unlinked from your account and factory reset the box. That way it could have initialized and an account made during the next startup. During which the hardware would have been registered to his account. After that registration process swap out the drive and reinstall. Since the box would be already linked to the account it would exist on the Moxi network as an active box. Right now the Moxi network might not even recognize the hardware ID as an active unit.
VisionOn is offline
Old 10-13-2014, 01:02 PM
Quoted: 13 Post(s)
Liked: 0
I have a call in to moxi 18669696694 hope to hear from them
Old 10-13-2014, 01:29 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
If what VisionOn said is accurate (seems to make sense), and Moxi is unwilling to help you (likely), then I can call to see if I can get my account restored.
giomania is offline
Old 10-13-2014, 04:20 PM
Quoted: 13 Post(s)
Liked: 0
Greetings,
We have completed review of this issue. Unfortunately, it shows that the previous owner opened the casing on the Moxi HD DVR, and replaced the hard drive already. As the casing has been opened, and the Moxi HD DVR tampered with, any warranty coverage such as repair, replacement, and escalation is now null and void. This includes out-of-warranty services as well and extends to the below Moxi Mate(s) bundled with the Moxi HD DVR as part of the 3 room bundle.
Moxi Mate serial numbers: US1001Z00010B and US1001Z0000DD
We will no longer offer any support outside of limited basic assistance with items unrelated to stability, recording problems, abnormal noises or temperature levels, and possible software issues. This also includes your request for assistance with further tampering through an unauthorized proprietary procedure.
If you have any questions regarding the warranty and terms of use, please refer to our published online document below:
http://www.moxi.com/us/support/MC4R/Moxi_HD_DVR_advisory_doc.pdf
Old 10-13-2014, 05:10 PM
Quoted: 13 Post(s)
Liked: 0
what is the normal boot up process as far as lights and reboots with the forefinger push
Old 10-13-2014, 05:59 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
On page 7 of the instructions linked in my signature, point #8 is the critical thing to know if it worked or not:
8. After releasing the 4 directional keys, the Welcome to Moxi screen to initiate the recovery process appears; press front panel “OK” button to continue. If the message “Moxi Is Checking Your Hard Drive“ appears, you have to start over.
I think the lights are irrelevant if you do not get to the initiate recovery process screen.
Mark
giomania is offline
Old 10-14-2014, 06:25 AM
Quoted: 13 Post(s)
Liked: 0
Is that right after are 20 to 30 minutes that that will pop up
Old 10-14-2014, 09:59 AM
Quoted: 13 Post(s)
Liked: 0
moxi dvr software torrent any out there
Old 10-14-2014, 10:00 AM
Quoted: 13 Post(s)
Liked: 0
Are can you clone one moxi software to another moxi
Old 10-14-2014, 02:26 PM
Quoted: 13 Post(s)
Liked: 0
my next step I'm going to try a unformatted harddrive
Old 10-14-2014, 06:08 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
I thought about posting that suggestion yesterday, but I suspect the OS is tied to the MOBO of the specific DVR, just like Windows activation.
Mark
giomania is offline
Old 10-14-2014, 11:19 PM
VisionOn's Avatar
Liked: 2011
I can see that might work if the clone is made of a drive with a brand new, unregistered FFP install. Once the box is linked to an account the hardware ID will not transfer, so the clone would have to be made before the startup registration process is complete.
If that works the drive sizes would not necessarily be the same so the FFP would need to be done again to reformat the drive, but at least the box would be linked to an account.
VisionOn is offline
Old 10-15-2014, 06:05 AM
Quoted: 13 Post(s)
Liked: 0
I have all day today to play with the moxi will try ffp
Old 10-15-2014, 10:21 AM
Quoted: 13 Post(s)
Liked: 0
I guess the moxi will be back on eBay the mates are good but don't know about the DVR
Old 10-15-2014, 11:01 AM
Quoted: 13 Post(s)
Liked: 0
Old 10-15-2014, 05:33 PM
Quoted: 13 Post(s)
Liked: 0
On one forum I looked at it said that you can do the ffp with any blank/empty/new sata drive has any one done this with a old hard drive are thy all new one
Old 10-17-2014, 03:17 PM
pghyndman's Avatar
You should be able to initiate the procedure but it may hang if errors are encountered during the format. I'd choose one of the successful drives listed in the database and go from there (a 500 GB will be adequate and far quicker to prepare).
The most difficult part was always keeping all 4 buttons depressed, but placing an appropriately sized washer over them makes it far easier.
If the old drive was only intermittently failing and you wanted to keep the programming etc. cloning/restoration would have been an option.
pghyndman is offline
Old 10-17-2014, 07:33 PM
VisionOn's Avatar
Liked: 2011
I used a drive older than the one that came with the Moxi. It's still working fine. It's completely random how an unreported drive will work.
I think at this point if you cannot get a reported drive to work then nothing will. You are either not hitting all the buttons properly or the box will not work because it was never linked to your account with the old bootable drive.
VisionOn is offline
Old 10-18-2014, 03:25 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Greetings,
http://www.moxi.com/us/support/MC4R/...visory_doc.pdf
So you are listing on ebay the bundle of useless hardware that moxi told you they will not support any of the boxes and you cannot apparently get a functioning operating system image on a working hard drive for the base DVR and trying to sell for $250 without mentioning this key detail?
Nice ethics.
Even if you list it for parts or repair-there in effect is no way to repair it since Moxi considers these units to be "tainted/tampered with"......
qz3fwd is offline
Old 10-18-2014, 04:02 PM
Quoted: 13 Post(s)
Liked: 0
All the mate are good they jest won't help with any questions are support with them but can get to work with another moxi dvr
Old 10-18-2014, 04:08 PM
Quoted: 13 Post(s)
Liked: 0
I did just update eBay description can not get the 4 finger push to work and Moxi will not help
Old 10-19-2014, 11:36 AM
Liked: 0
New hard Drive
I have replaced my moxi pipleine with a seagate 1tb sv35 It has stated that this drive works good with the moxi. However the other day my moxi froze & when i rebooted it would not pass the hard dive checking state. I did the 4 button press again & it working fine. SHould i be worried if it is a bad drive?
JoJoCutie6 is offline
Old 10-19-2014, 12:05 PM
VisionOn's Avatar
Liked: 2011
There's always a chance any drive is bad. Even a new one.
Only way to tell is to put it in a PC and run some diagnostics on it.
VisionOn is offline
Old 10-19-2014, 02:14 PM
Quoted: 13 Post(s)
Liked: 0
so apparently the forefinger press is still up and running I have tried this on the AT&T network and charter network with no download I have a friend that has Comcast wondering if I should try that my moxi mates still shows the register to the previous owner assuming the d_v_r is also
Old 10-19-2014, 04:52 PM
dz2k's Avatar
Quoted: 99 Post(s)
Liked: 37
it doesn't seem you were able to get the moxi to fully load to a picture. if you did, in settings, moxi setup, you can select remove from account. I see the moxi bundle sold for you so that's good. hope you didn't lose too much.
dz2k is offline
Old 10-19-2014, 06:24 PM
Quoted: 13 Post(s)
Liked: 0
I have removed the moxi of eBay going to try a few different things to see if I can get it back up and going
Old 10-19-2014, 06:28 PM
Quoted: 13 Post(s)
Liked: 0
I have never gotten to the welcome to moxi though it might be network problems if it is a bad drive will it still get to welcome to moxi and stop there are what
