Official Moxi Hard Drive Replacement Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
Old 02-26-2015, 02:09 AM
miked1960's Avatar
Originally Posted by MasterOSkillio View Post
Is there a definitive guide for specifically for SSDs for the Moxi? I didn't see one when I searched Did the stuttering issues SSDs cause ever get identified/fixed? I have been using my stock hard drive for 4 years now with my 3 tuner DVR and I know that drive has to be ready to die soon. I'm thinking about getting a 512 for it when the stock drive finally goes, but obviously it's not worth the money if it won't ever work right.
Also do I have to worry about cloning my drive if I don't care about keeping TV shows that are on it? From what I understand if the drive works the procedure is as simple as an ffp and just wait for a while the moxi to do it's thing.
You should clone your drive that way you won't lose support. Once you change your HDD your DVR will report it and they will not repair it down the road for you. Cloned HDD saves the info on the present hdd it will continue to report nothing has changed from what I've read.
If something should go wrong other than the present hdd they will exchange it for $250+ $20 shipping cover it for a year. Hang on to the old hdd put it back in if you go that route. I lost my internet on my dvr sent it back for a repaired one.
miked1960 is offline
Old 02-26-2015, 10:37 AM
MasterOSkillio's Avatar
Understood, thank you. Any thoughts on the SSDs?
MasterOSkillio is offline
Old 02-26-2015, 10:43 AM
miked1960's Avatar
Originally Posted by dz2k View Post
Check out this article about hard drives: http://www.cdrinfo.com/Sections/News...x?NewsId=39283
Didn't WD buy out Hitachi? That would mean they are WD drives with a different name?
Old 02-26-2015, 10:51 AM
miked1960's Avatar
Sorry no I do not. I know they have a list of drives some have installed SSD had no luck with them There is a thread on here. Several have noted the best thing to do would put a smaller drive in and use an external drive. Some have used a NAS perhaps and in raid 1 that way if the DVR HDD dies you just put in one of the hdd's from NAS to DVR and you are up and running no loss videos.
As for HDD, you got lucky 4yrs usage. Mine only lasted 18mo first one maybe 28mos on the other hdd failure I sent back for Moxi to replace.
HDD WD look for the AV model they are DVR certified using silkstream. The seagates Moxi used were bad didn't last long. I don't know what they used this time and they won't tell me. I'll wait until the warranty is up I'll open it up see what the replaced it with and I can make a backup of it put it on the smaller hdd I have.
Old 02-26-2015, 08:19 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
That is true.
I thought this but it isn't the case. Once you contact support, they can determine your hdd model/brand. However, if you replace it with the same hdd model/brand hard drive as the original, you should be ok...but for how long is the question with the failure rates. lol.
dz2k is offline
Old 04-08-2015, 02:11 PM
BigJohnSudz's Avatar
Hi Guys, trying to replace the HD in my 2 tuner Moxi with a 2TB Seagate SVT35 drive. I can't seem to get the four finger press going correctly and the best I've had happen aside from the left light blinking (indicating a problem somewhere in the 4FP steps) is to get all 3 lights blinking in the front--does anyone know what this means? I seem to recall this happening when swapping HDs in my 3 tuner model last year.
BigJohnSudz is offline
Old 04-08-2015, 03:04 PM
oakforest's Avatar
I believe the 2 tuner model is limited to a 1.5TB drive>
BigJohnSudz likes this.
oakforest is offline
Old 04-08-2015, 03:07 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
nice catch. I wrote about this in the past.
oakforest and BigJohnSudz like this.
dz2k is offline
Old 04-08-2015, 03:35 PM
Thanks guys! I knew this and foolishly forgot. Back to PC Microcenter for an exchange!
oakforest likes this.
Old 04-08-2015, 07:27 PM
So I picked up a Seagate ST1000DM003 and it looks like that won't work either, best I get is just no flashing of the amber lights and the welcome screen never starts. Tried using a washer for the 4FP to make sure I had solid pressure on all 4 buttons but no luck. Also plugged ethernet cable right into router in case of network issues. I wonder if the 4FP is done for good or I just have another incompatible drive?
Old 04-08-2015, 09:29 PM
sslund's Avatar
Quoted: 55 Post(s)
I don't know about for the 2T Moxis, but the 4FP just worked this past weekend for me on a 3T. I don't think it's been updated for quite awhile, but you might want to check out the spreadsheet for drives that are known to work or fail -- the 2T results are at the top. You can find the spreadsheet link here.
sslund is offline
Old 04-09-2015, 07:53 AM
The thing is most of the 2T HD listed in that Excel file are not as routinely available as they were 4 years ago. The 2nd HD I tried is listed as having worked in a 3T model and since it was less than 2TB, I thought it might work here. What I didn't realize all along though is that my 2T Moxi was working OK, I had just deactivated it from my Moxi account and that is why when I started it up, it wouldn't show much on the screen except the settings menu. So I am going to put that HD back into it tonight and hope I didn't botch it up by trying to run the 4FP on it with no luck for 2 hours.
Old 04-09-2015, 10:44 AM
sslund's Avatar
Quoted: 55 Post(s)
I can relate -- I've been struggling to find compatible HD for my old RTVs for the past several years whenever a drive gives up the ghost. Glad the HD wasn't your problem & hope your original drive works when you pop it back in!
sslund is offline
Old 04-10-2015, 05:43 PM
Was able to get get the 2T running successfully after activating it online which is great news for me. But the cable card was giving me problems so I went into the Comcast office to swap it out and picked up an X1 DVR there as well just to try it out. As much as I love my Moxis, side by side its clear how ancient it is in regards to interface. But on the other hand, there are annoying things Moxi got right that Comcast just hasn't like buffering more than one channel on a box with 4 tuners.
Old 04-13-2015, 04:05 PM
Liked: 0
alternative to cloning
What about using data recovery software like stellar phoenix to recover the raw data and write it to a new drive? also i haven't seen anywhere if the new hdd needs to be formatted, and if so how do i format a disk in cdfs?
Matthew Frideres is offline
Old 04-13-2015, 09:41 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
Try it and let us know. I dont think the hdd has to be formatted because g4l will wipe it before starting.
dz2k is offline
Old 04-23-2015, 07:40 PM
Liked: 0
I'm having what I think is a hard drive problem with my 3-tuner Moxi...
A few days ago I turned on the TV and noticed that the Moxi was frozen. I reset the unit with the reset button. From that point on, the Moxi pretty much would not make it through a full boot but rather keep restarting. If/when it did boot all the way to the Moxi UI, at that point it would immediately restart itself.
I assumed it was a hard-drive problem and swapped in a WD 1 GB "purple - video surveillance" drive. The software reinstallation went smoothly and the boot up cycle goes much more quickly, but after that things are going bad again. The user interface is extremely sluggish, in the order of 10 seconds to much more just to move up/down one channel in the channel list. And now after being turned on for 24 hours, it has fallen into a cycle where it keeps restarting at the point that it's attempting to load the channel list.
Did I pick an incompatable hard drive? Is something else wrong with my Moxi?
Thank you.
biglaz is offline
Old 04-23-2015, 08:05 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
Try a hdd from the 3 tuner list. Return current one after results found.
dz2k is offline
Old 05-11-2015, 10:14 PM
Liked: 0
I grabbed a Seagate SV35 2TB which is on the list and has more favorable entries than the WD Purple 1TB.
The interesting problem I'm having now is that the four-finger-press is not working at all. I've tried probably 50 times over the past 2 weeks. I'm following the same procedure as when it did work with the box plugged into the modem. So...ugh. Not sure what to do other than keep trying. Is it possible they black-listed my Moxi?
biglaz is offline
Old 05-11-2015, 10:19 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
its doubtful you're equipment was blacklisted. unplug usb devices and addditonal cables on your 3 tuner and try another Ethernet cord.
TeeJay1952 likes this.
dz2k is offline
Old 06-07-2015, 09:35 PM
mmihalik's Avatar
Here is a link to my experience in replacing my failing HDD in my 2-tuner Moxi.
Thought for sure I had messed up something in my Moxi, and had just about given up hope.
Happy ending: used g4l and ddrescue to clone my failing 1.5 TB Barracuda LP drive with another identical replacement. After one day of trying different things, Moxi finally came back to life.
Key step: be sure to reboot your router. Even if your network connection seems to be working, something is rather important network wise for the Moxi.
Moxi HD DVR
M2 in OR
we live in interesting times
mmihalik is offline
Old 06-17-2015, 09:06 AM
VisionOn's Avatar
Liked: 1952
I need to upgrade the WD Green 2TB drives in my NAS this weekend and will have a couple of drives free, so I figure it's a good time to experiment with the Moxi again and try cloning and see what results I get. The current drive is an old 1TB WD from 2008. It's still working so I'll be keeping it around just in case.
Anyone still running WD Green with no issues?
VisionOn is online now
Old 06-20-2015, 04:37 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
make sure the hdds you upgrade to in your NAS work before experimenting w/ the moxi. otherwise, it'll be a headache.
dz2k is offline
Old 06-21-2015, 07:58 PM
VisionOn's Avatar
Liked: 1952
Updating the NAS was simple and I experimented with cloning my existing 1TB Moxi drive using G4L without issue. It did take 9 hours though.
Installed, the new drive worked fine, with no startup problems or pairing necessary. Of course the replacement drive is a 2TB WD Green and as we know there is no way to expand the useable space when cloning so I put the old drive back in for now.
Since the cloned drive was just sitting around I did a search to see if any new utilities or tricks had appeared lately. Various attempts with Linux and Ubuntu utilities just proved fruitless. What is on the drive is still locked away from quick partition access - possibly using Triple DES.
Since I have a Mate I also plugged it directly into the SATA and power ports on the PCB just to see if and how it would boot with an entire OS at hand. Drive spins up, but nothing happens. It's kind of sad looking at the potential the Mate had. All those connectors and ports are just useless.
Since I now have two drives with the same content I'm tempted to reformat the 2TB and use that and keep swapping between the new drive and the old recordings until they are watched. It would be good to have a quick swap option but I can only think of running longer cables out of a slot on the back of the Moxi and having both drives outside the case.
Old 07-03-2015, 06:19 PM
VisionOn's Avatar
Liked: 1952
Follow up to the previous post, just up there ^^^ .
I reformatted the 2TB Green and I'm using that as the primary drive now. However, I am also still using the old drive too until I've cleared off the backlog. Simply put, I converted them both to "external" drives! Since the Moxi is using basic PC components it was just a case of replacing cables.
  • I unscrewed the eSATA connector on the Moxi and removed that cable.
  • Disconnected and removed the internal SATA cable and power.
  • Bought a Monoprice SATA to eSATA cable. Connected that to the internal drive SATA port and fed it through the eSATA slot in the back panel.
  • Bought this eSATA dock from Amazon - http://www.amazon.com/gp/product/B00FDLDCD8 - and connected the eSATA cable.
  • Plug in the drives on demand.
It works, but I would not recommend this as a long term solution. Handy for a transition solution between drives with a few major caveats.
The docking station is fairly generic and you can find the exact same model under different brand names. The onboard controller does not seem that great and when watching recordings or buffer playback it will occasionally lock up for about ten seconds. Seems to record okay though. You don't actually need a docking station. Any hard drive enclosures with eSATA should work. I just didn't have one lying around and wanted to swap the hard drives easily.
The Monoprice cables are always thick, so I had to file down the opening slightly where the eSATA port is.
Since I installed a new hard drive the CC had to be paired again. That wasn't helped by my card failing, but it was 8 years old so I was kind of glad to get a replacement from this year.
If you are swapping drives you will need to reboot and power on the dock at the moment of reboot. I've also been disconnecting the network cable and card when using the old drive for playback so that recording information is not sent to the Moxi server. The cableCARD is not going to work with the old drive now so I take it out just to avoid frying it somehow. So no live TV when viewing recordings from the old drive. You may get some unencrypted QAM coming through but TWC have killed all those channels here over the past couple of days, so no TV for me.
I'm not going to keep using this setup for much longer. A few more weeks maybe until I've caught up or recorded what was on the old drive. After that it's just a case of plugging the old cables back into the Moxi, screwing the eSATA port in place and fitting the current drive in the bay.
Old 08-03-2015, 07:01 PM
OggiDoc's Avatar
Liked: 0
Originally Posted by daemonicpenguin View Post
Little under 2 years of heavy load, the drive in my 3 tuner MOXI finally gave up the ghost.<br><br>
Replaced with:<br><br>
120 GB Intel 320 Series SSD<br>
FFP Success<br><br>
Thanks for this thread.
Hi, Oggi here.
how is the intel 320 ssd doing in the moxi 3 years later.
Hope to place the same or the samsung 830 128gb internal and store mostly on external raid hdd
Thank You
OggiDoc is offline
Old 08-13-2015, 10:34 AM
Liked: 0
My Moxi 3 is due for a new drive anything new out there for replacement?
dpol06 is offline
Old 08-13-2015, 01:32 PM
dbrons's Avatar
Quoted: 12 Post(s)
It's not new, but I put a 2tb WD20EURX in my 3 tuner Moxi this past Dec and it's working well and very quiet.
Dave
dbrons is offline
Old 08-13-2015, 02:36 PM
Liked: 0
Thanks, I had a WD My Book 1TB external on it for a year that went so they sent me a new one but Moxi does not recognize it could it be bad?
dpol06 is offline
Old 08-13-2015, 02:46 PM
dz2k's Avatar
Quoted: 97 Post(s)
Liked: 37
It may just be the moxi being picky with the external hdd. IF the wd external hdd is empty and has no important data on it, Plug it up to pc to see if recognized and plug it back to moxi after.
dz2k is offline
