Basic question on Cox DVR recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-12-2011, 07:47 PM - Thread Starter
jake9's Avatar
I just got with a Cox 8240 HDC, and I have a question I can't seem to find anywhere:
Does the DVR box have to be on in order to record a program? I want to record a show at midnight, but I"m not sure if I need to leave the box on, or if it will power up at that time.
5.1 System
Denon AVR-2312CI | Oppo BDP-105D | Martin Logan Dynamo 1000 | Energy Take Classic | Toshiba 42RV530U HDTV
2.1 System
Oppo BDP-105D | Parasound Halo A 21 | Parasound Halo P 5 | Rega RP-3 | Martin Logan Theos | Martin Logan Dynamo 1000
jake9 is offline
post #2 of 3 Old 02-12-2011, 10:28 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
No.
It doesn't power up. It records to the HDD without fully powering up. It's never really all the way off.
domino92024 is offline
post #3 of 3 Old 02-13-2011, 10:43 AM - Thread Starter
jake9's Avatar
Thank you.
5.1 System
2.1 System
jake9 is offline
Reply HDTV Recorders
