Pace RNG150n & atlas 1056 remote program ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-13-2011, 11:50 AM - Thread Starter
awayne's Avatar
I just got installed today the Multi Room DVR with RNG150N and DC900x Pace equipment.
I am trying to program the 30 sceond skip into the new remotes and everything I have tried hasn't worked. Is there something special I must do to get this to program?
Another question is have they activated the eSATA port to add an additional harddrive to this setup? The software version is 78.73 and the provider is Armstrong Cable.
Thanks in advance for the help!
awayne is offline
post #2 of 5 Old 04-16-2011, 08:37 PM - Thread Starter
awayne's Avatar
Anyone?
Nobody has any info about this....
awayne is offline
post #3 of 5 Old 05-08-2011, 06:26 PM
Mellow129's Avatar
Very Interested in this as well.
I have the same model box (Pace RNG150N 'Denali'), but from Insight Cable out of Louisville, Ky.
>>I am Looking for remote codes for a 30 Sec FWD/15 Sec Back skip feature similar to my old Motorola DCT Series Unit<<
Awayne, Have you found the answer yet?
Has anyone reading this forum found a solution?
I wonder if the Pace unit even has the capability?
Mellow129 is offline
post #4 of 5 Old 05-11-2011, 12:57 PM
Mellow129's Avatar
I found my solution.
The Insight remote for my old Moto DCX and the Pace RNG was similar enough that the same programming codes worked, and as it turns out the Pace box has the same skip capability.
Pulled from this site.
1. Press the "Cable" button at the top of the remote to put it into Cable Box control mode.
2. Press and hold the "Setup" button until the "Cable" button blinks twice.
3. Type in the code 994. The "Cable" button will blink twice.
4. Press (do not hold) the "Setup" button.
5. Type in the code 00173.
6. Press whatever button you want to map the 30-second skip command to (ex: PIP CH +/-). The "Cable" button will blink twice if successful.
post #5 of 5 Old 06-13-2011, 11:30 AM
bigandugly's Avatar
Armstrong is now using a 1056B03 (old ones were 1056B01) - Armstrong informed me that the 1056B03 will not accept the 994 programming to reassign a key to the skip - My old 1056B01 was programmed with the skip and it works on the RNG150N/DC900X installed in my home so that proves that the PACE supports the SKIP.
bigandugly is offline
Reply HDTV Recorders
