Anyone have firmware file for DVTPal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-17-2011, 06:17 PM - Thread Starter
Help Me Please?'s Avatar
Hi,
We have a Dish Network branded DVTPal standalone DVR that we've been using for OTA stuff for a few years. Today, the DVR functions (including menu and guide) fail to work.
Before tossing it, I thought I might try a firmware update but Dish doesn't have it on their site anymore.
Wondering if anyone has a copy of the latest (or any) firmware update?
Help Me Please? is offline
post #2 of 12 Old 09-18-2011, 07:13 AM
TheKrell's Avatar
If you want to toss it, toss it my way! I think you might need to replace the internal disk. Check out the main thread on the DTVpal for info on how to do this.
The latest firmware for the DTVPal is F208. You may already have the latest.
TheKrell is offline
post #3 of 12 Old 09-18-2011, 08:38 AM
Scooper's Avatar
Yes I have it. The issue is how to get it to you.
If you want to replace the harddrive - the stock unit is 250GB SATA, You can probably put in any thing up to 1TB , mine has a 500MB .
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #4 of 12 Old 09-20-2011, 03:29 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
I bet he doesn't come back.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #5 of 12 Old 11-27-2012, 08:34 PM
zepol359's Avatar
Do you still have the file F208 for an Echostar DishPal TR50!? Can you send it to me please? zepol_trash@yahoo.com
zepol359 is offline
post #6 of 12 Old 01-16-2013, 02:15 PM
lind777's Avatar
AS of Jan 2013 I am looking for the F208 firmware. The link at the top of the general DTVPAL AVS forum post that says "link to current firmware" looks awfully suspect as the filename says phpQYEZB5. I would think that it would have F208 in it somewhere. If someone could send it to me at yahtempmail-AVS@yahoo.com, I would appreciate it or vouch for that filename. THANKS.
lind777 is offline
post #7 of 12 Old 01-17-2013, 03:45 AM
harleyjoe43's Avatar
Quoted: 13 Post(s)
You might get some satisfaction if you GO to the DTV PAL forum......
harleyjoe43 is offline
post #8 of 12 Old 01-17-2013, 04:58 AM
lind777's Avatar
I don't see a forum on AVS titled DTV Pal. I only see HDTV Recorders. When I do a search on the AVS forums I don't see it either. A pointer to where the forum titled DTV Pal is would be appreciated. My search for posts listing where the firmware download is also don't bring back anything useful. Thanks!
lind777 is offline
post #9 of 12 Old 01-17-2013, 05:12 AM
Rammitinski's Avatar
There is an "official", dedicated thread for it, which is listed here on the first page of this HDTV Recorders forum.
Rammitinski is offline
post #10 of 12 Old 01-17-2013, 05:45 AM
lind777's Avatar
Thanks for that clarification. This brings me back to my post where I wrote:
The link at the top of the general DTVPAL AVS forum post that says "link to current firmware" looks awfully suspect as the filename says phpQYEZB5. I would think that it would have F208 in it somewhere. Please vouch for that filename.
I am just trying to make sure the file is in fact the F208 code and not virus laden. The official DTV Pal topic says it should be TR50_F208_0HUC00.upd.
lind777 is offline
post #11 of 12 Old 01-17-2013, 04:22 PM
dattier's Avatar
Quoted: 153 Post(s)
Liked: 62
Lind777: the link you're seeing is probably on a shortcut service, so the final element is their machine-generated code for the link.  It may actually lead to a file with the correct name.
dattier is offline
post #12 of 12 Old 01-18-2013, 05:12 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
It's a valid file. I had the file already of the same size. Rename the file to "TR50_F208_0HUC00.upd"
Reply HDTV Recorders
