Replace Cox HD-DVR box with Tivo? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2011, 09:36 PM - Thread Starter
Fredephriam's Avatar
Cox has recently changed the UI on their DVR for the worse. I can no longer review my future recording list. Looking for an alternate recorder but really don't know what my options are. Reading some of the posts informs me that to use Tivo I will need a Cablecard. I really don't know about this stuff and would appreciate a link that explains it. I'm in Rhode Island and am a captive Cox customer: satellite is no go because of blocked view to the southwest. Any help will be appreciated.
Fred
Fredephriam is offline
post #2 of 4 Old 10-09-2011, 11:21 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
Fred
First, what DVR and software are you using that prohibits you from viewing your future recording list? I know of none.
As far as a CableCARD goes, yes you will need one for proper channel mapping and encrypted services reception.
domino92024 is offline
post #3 of 4 Old 10-11-2011, 10:43 AM
ak3883's Avatar
The new Cox guide(Passport/ROVI) doesn't probit you from viewing future recordings. I think it's "List" button you have to hit(the one that brings you into the DVR recordings menu), while in the DVR recordings menu, and then scroll up to "Scheduled recordings" Yes it's not as easy as hitting the "B" button directly on the remote like before, but you can still view what is scheduled to record in the future.
ak3883 is offline
post #4 of 4 Old 10-21-2011, 12:23 PM
sycle's Avatar
Yeah, it's still there (as described above). MUCH worse than before (not sure what they were thinking!), but it's there.
sycle is offline
Reply HDTV Recorders
