Tivo Premiere Elite - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 92 Old 11-10-2013, 06:42 PM
Bryan_CoxPHX's Avatar
Quoted: 112 Post(s)
Liked: 52
Originally Posted by bwv1080 View Post
I have a Tivo HD Premiere Elite, and when I try to stream Netflix programs, the screen constantly goes black for a second or two about every 30 seconds or so. I can also stream Netflix through my Oppo 105, which works fine, so it isn't a network problem. I've spent a lot of time on the phone with Tivo's service reps, but to no avail. Any suggestions? (The Tivo is connected to a Marantz 8801 processor via HDMI, which is in turn connected to my TV.)
Uncheck the 1080p (pass-thru-only) option in the Video Settings.
Settings > Video > Video Output Format
And only check 1080i (or also 720p if you wish, I only use 1080i) The Premiere Series 4 CPU does not handle 1080p(24) very well.
It looks like TiVo actually disabled 1080p(24) for Netflix in the latest SW update SW Vers 20.3.7.1a
1080p (pass-thru-only) used to work with Netflix on the Premieres, I am not sure if it was a TiVo SW update that broke it or Netflix Super HD, but it quit working about the same time my provider got access to Netflix Super HD, The Premieres started to constantly switch resolutions between 1080p(24) and 1080i.
TiVo Bolt, Roamio Pro, Premiere XL4, Premiere 2TB-WD20EURS, TiVo Mini
Cisco Tuning Adapter Status Troubleshooting
Bryan_CoxPHX is offline
post #92 of 92 Old 11-10-2013, 11:29 PM
bwv1080's Avatar
Quoted: 41 Post(s)
Liked: 95
That worked...thank you very much!
DALI Epicon 2 speakers; SVS SB 13 Ultra subwoofer; PrimaLuna HP integrated amp; Esoteric K-03 SACD player; Oppo BDP 105 SACD/Blu-ray player; VPI Scout 1.1/Ortofon 2M Black; Audeze LCD-XC headphones
bwv1080 is offline
Reply HDTV Recorders
