8300HD --> Windows 7 64-bit: would Ubuntu work? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-20-2011, 09:36 AM - Thread Starter
Blaq's Avatar
I want to capture recorded videos off my 8300HD onto a Windows 7 64-bit box. From all the reading I've been doing, it seems no reliable 64-bit Windows Firewire drivers exist.
1) Can you confirm this? Are 64-bit Windows users still unable to capture from 8300HD via Firewire?
2) I prefer not to buy a used Mac for the sole purpose of Firewire video capture. Can I successfully run a capture solution in Ubuntu, inside a VirtualBox environment? If so, what software works with an 8300HD?
There are so many threads across the Net, it would be nice to have a single response point for this specific situation. Thanks.
Blaq is offline
post #2 of 3 Old 12-20-2011, 11:52 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
1. No you cannot capture through firewire on any 64 bit Windows OS.
2. I dont think any VM solution supports firewire pass through. Parallels does not, VMWare does not. Dont know about VirtualBox but doubt it.
Regardless, I think the SA boxes firewire implementation is broken such that no device can capture glitch free recordings, even DVHS decks????
If you have a friend with a mac laptop with firewire, see if you can borrow it or invite them over and do a test run to save yourself time and money.
Good luck.
qz3fwd is offline
post #3 of 3 Old 12-24-2011, 02:58 AM
TNO821's Avatar
Quoted: 18 Post(s)
^ Yes, that has been my experience. SA cable boxes have screwed up FireWire. I have only been able to capture a few frames of video before it screws up.
Also, it is true that no VM technology emulates FireWire.
And, to correct the earlier poster: it's not just that there aren't *reliable* FireWire HDTV capture 64-bit Windows drivers...there aren't *any* 64-bit Windows drivers for it whatsoever. And there won't be.
TNO821 is offline
Reply HDTV Recorders
