Cisco RNG200N native resolution - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-18-2012, 05:28 PM - Thread Starter
Greg76's Avatar
I have a cisco rng200n with comcast since the recent updates sent out by comcast to set top boxes. It no longer gives the option for the box to out put the video in it's native resolution you are forced into 480 for SD content and 1080 for HD content. I would really like it to out put it's native resolution and let my iScan Duo do the up scaling. Talking with comcast reps they are clueless to what I talking about. Any help would be appreciated.
Greg76 is offline
post #2 of 12 Old 01-19-2012, 10:14 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
The last post in this thread sounds like it may be what you're looking for > http://forums.comcast.com/t5/Xfinity...i/td-p/1102177
Vin
Vin is offline
post #3 of 12 Old 01-19-2012, 02:38 PM - Thread Starter
Greg76's Avatar
Have tried all of that. Hopefully the new firmware update coming out will fix this.
Greg76 is offline
post #4 of 12 Old 01-29-2012, 04:51 PM - Thread Starter
Greg76's Avatar
Update. Got the option for passthru mode. But now it just puts everything out as 480p. Comcast had know clue how to do things right. Maybe just need to switch to fios.
Greg76 is offline
post #5 of 12 Old 10-24-2012, 12:28 AM
StarvinForHD's Avatar
Don't know if you found the solution...this was a long time ago. But, here's how you get passthru to work. First, do the initial setup of the resolutions your TV can display. This is done buy turning off the box and hitting HD zoom on the remote. Make sure you select all resolutions. Turn the box back on. Then, turn the box off again. This time hold in the CH + and the CH - buttons on the box. This takes to a different screen. You should be able to scroll through all the resolutions by pressing the left or right arrow key on your remote. Eventually you'll get to a selection that says "passthru". You can also turn on Close Captioning on this screen. Then, turn the box back on and passthru will work. Although it will display native 1080i and 740p, it will not display native 480i or 480p. However it's better than everything being displayed in either 1080 or 740, especially for sports.
StarvinForHD is offline
post #6 of 12 Old 01-26-2013, 07:57 AM
dreamtheatre's Avatar
Quoted: 60 Post(s)
Liked: 37
I did all your instructions today, and found that my box is only outputting 480i in a non-widescreen format. Weird.
Anyone else have this problem with the Cisco RNG200N on Comcast?
LG 65EF9500 OLED Display
Oppo BDP-203,Schiit Bifrost Multibit DAC, MF V-LINK 192
Parasound P5, Marantz SR-6010, EAD PM 1000 and PM 500 amps
NHT 2.5i (2), NHT AC-1 (1), NHT 1.5 (2), PSB XA (4)
Outlaw Ultra X12 and LFM-1 EX subwoofers
dreamtheatre is offline
post #7 of 12 Old 01-26-2013, 05:41 PM
Sonyad's Avatar
Quoted: 190 Post(s)
Liked: 111
Nope, I don't have that problem. However my rng200 gets ornery at times and I have to pull the plug on it for about 10 minutes. Once or twice I've had to call Comcast to send a new signal to it.
Sonyad is offline
post #8 of 12 Old 01-26-2013, 06:34 PM
Quoted: 60 Post(s)
Liked: 37
Well, I wonder if it's something else in the video chain then. For the record, here is what I did:
Ran the Advanced setup, and selected all resolutions. Went into the channel up/channel down menu and selected passthru. After I turned the box back on I am getting a non-HD 4:3 480i signal on an HD channel.
Don't get why, but I will keep playing with it till i get it working.
post #9 of 12 Old 01-26-2013, 10:01 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I don't have Comcast but I found this. Not sure if it will help but here it is.....good luck.
Solution for Cisco RNG200 reverting to 480i
1. Turn the box off
2. Press Menu and Info on the front of the box at the same time
3. Follow the on-screen instructions to test all the resolutions.
4. Exit
5. With the box off, press the channel up & channel down buttons on the box at the same time.
6. Change the resolution from 480i to 1080i (unless you want 720p)
Vin
Vin is offline
post #10 of 12 Old 01-27-2013, 08:17 AM
Quoted: 60 Post(s)
Liked: 37
1. Turn the box off
4. Exit
No Dice. It's strange as the front panel says "HDTV 480i" even though this is a native 1080i feed.
post #11 of 12 Old 01-27-2013, 08:23 PM
evanknighs's Avatar
me too,After I turned the box back on I am getting a non-HD 4:3 480i signal on an HD channel. good idea. 1.gif
evanknighs is offline
post #12 of 12 Old 02-16-2013, 10:01 AM
dsilva's Avatar
One thing you can check is in the user settings (steps outlined below) is to change the 4:3 override to 480p, that should have a full screen guide and info bar when on SD channels and the other experience when on HD channels.
1. To access user settings, turn OFF your set-top box; it will remain in standby mode.
2. Press GUIDE on your remote while the set-top box is in standby mode. OR press Channel Up + Channel Down simultaneously on the front panel of the set-top box.
3. From here you can set up your video settings and resolution output.
Video Settings: Configure the settings to your TV type. 4:3 Letterbox, 4:3 PAN/SCAN or 16:9 wide-screen. Resolution Output: Configure the HDMI/YPbPr output to either 480p std, 480i std, Pass Thru, 1080i. 4:3 Override: Options are Off, 480p, 480i, Stretch. Change the 4:3 Override to 480p
dsilva is offline
Reply HDTV Recorders
