Cisco 8742 HDTV Recorder - AVS Forum | Home Theater Discussions And Reviews
Old 02-07-2012, 02:16 PM - Thread Starter
ragtops's Avatar
Just got a new Cisco 8742 recorder through BHN. There is virtually no information on this recorder. The only thing i could find is a two page layout guide that is worthless. Does anyone have any info on this new model? Also, I am having a heck of a time trying to locate the IR remote sensor.
ragtops is offline
Old 02-07-2012, 06:37 PM
walford's Avatar
Bright House should have provided a user manual with the 8742. Contact them and have them send one to you.
walford is offline
Old 02-23-2012, 08:39 PM
purcell21's Avatar
It's basically right on top of the word EXIT on the front. I used a Niles "mouse" blaster and put the blackout cover over it to hold it in place. I had to trim about 1/8" inch off the right side of the cover so it wouldn't hide the power LED on the info display. The real trick was to turn up the IR power output for that port on my control processor. Apparently the smoke cover on the front of the box is pretty dark, so you've got to blast through it.
purcell21 is offline
Old 03-15-2012, 10:28 AM
GreedyB's Avatar
Having trouble getting my IR extender to work with this model. Great little box but IR seems to be a problem. Can you give a more precise location of the IR sensor?
GreedyB is offline
Old 03-18-2012, 08:48 AM
stuvwxyz99's Avatar
Time Warner just gave me one of these. I have it connected to my Onkyo Receiver via HDMI, and the Onkyo is connected to my Panny Plasma via HDMI also.
When I turn the TV off, the sound is no longer output. This did not happen on my previous system (8300HD). It's a pain, because my wife likes to listen to Music Choice channels and it means the TV has to be left on.
Is this a limitation on this system? Any ideas if it could be fixed by using Toslink to connect to the Onkyo?
stuvwxyz99 is offline
Old 11-05-2012, 08:36 AM
polyorchid's Avatar
I had 16 hours and 35 minutes of HD content recorded on my DVR, along with 16 hours and 25 minutes of SD content, and my 8742HDC reported it being 76%. I purged the cache but that knocked it down only to 72%.
In this thread here: http://www.avsforum.com/t/1219141/cisco-8640hdc-hd-dvr-thread/330 there are references to how to run the hard disk drive diagnostics tool, which is kind of like a ChkDsk type utility that attempts to diagnose hard drive problems and repair them, but this procedure (holding down select and volume up buttons while unplugging and then plugging in the box) doesn't seem to do anything on the 8742.
I'm looking for some suggestions. Time Warner Cable's response, from both technical support people I talked to, along with their supervisor, has been to try to tell me this really isn't a problem and that it's totally normal for it to be that full because high-def takes up a lot of space, but I know from experience that that is wrong.
polyorchid is offline
Old 11-05-2012, 11:13 AM
polyorchid's Avatar
But this morning I talked to a tech support guy that understood that it was a problem, and suggested this, which I posted in another thread: http://www.avsforum.com/t/1219141/cisco-8640hdc-hd-dvr-thread/360#post_22558679
Old 11-29-2012, 09:22 AM
booj90's Avatar
Check out this article for the location of the IR Sensor Eye for the Cisco 8742HDC.
http://samkear.com/hardware/cisco-8742hdc-cable-box
Its to the right of the USB port. I put my IR repeater system sticky to the right of the USB port and it worked right away. It doesn't seem like that would work since the plastic is not the see through smoke like the top part of the box but it works.
Searched for quite a bit to find the article... wanted to get this out there for others in need.
booj90 is offline
Old 12-01-2012, 07:34 AM
gopromiller's Avatar
yeah,i think so, Time Warner just gave me one of these. I have it connected to my Onkyo Receiver via HDMI, and the Onkyo is connected to my Panny Plasma via HDMI also.thanks for your sharing.
gopromiller is offline
Old 02-05-2013, 12:53 PM
Mark Shapiro's Avatar
Just saw this thread. This worked perfectly, thanks!
Mark Shapiro is offline
Old 04-22-2013, 08:46 AM
DRGARYGOODMAN's Avatar
THANK YOU THANK YOU THANK YOU - to the right of USB PORT! I could not find this for nearly an hour. YAY! Thanks again! Gary
DRGARYGOODMAN is offline
