Grainy Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-14-2012, 09:55 PM - Thread Starter
Vaqua55's Avatar
My set up is Samsung 46 LCD with directv HD dvr in main living room going thru yamaha rvx667 receiver and another hd dvr to my bedroom Samsung 46 LCD . My main living room tv has occasional grainy , fuzzy hard to describe picture, see attached picture for better understanding. It happens quite frequently and when it does it continues with my apple tv in the same tv thus I'm not convinced its directv dvr issue , you think it is tv issue? Already changed the HDMI cable 2 times with no success. Again Apple tv is not connected thru HDMI and has the same issue.Need desperate help, thanks
Attachment 237320
Vaqua55 is offline
post #2 of 6 Old 02-22-2012, 05:15 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Not really "grainy", but some digital processing issue somewhere. It seems to be more TV related.
1. What does the TV's menu look like?
2. What does the video from the sets internal tuner look like? (You do have an antenna connected for when your DTV gos down don't you??)
3. How long are these cables?
4. Have you tried the component input?
5. Have your tried another device; a DVD player?
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #3 of 6 Old 02-22-2012, 05:55 AM
Phase700B's Avatar
Liked: 25
I agree, that looks more like an LCD processing or panel issue. It looks typical of LCD TVs when internal brightness or contrast setup was done improperly at the factory or the TV has suffered a marginal component failure.
Phase700B is offline
post #4 of 6 Old 02-22-2012, 10:57 AM
walford's Avatar
Can you provide a higher resolution image? The 100x75 jpg image you supplied does not provide a lot of information about your problem.
What resolution are you using to send the content to the TV from the DVR?
I don't think the cable is the problem.
Does the problem appear to channel or program related?
walford is offline
post #5 of 6 Old 06-11-2012, 03:56 PM - Thread Starter
Vaqua55's Avatar
After all it turns out that it was the TV with defective machanism and they have replaced it for me! Thanks for all your input!
Vaqua55 is offline
post #6 of 6 Old 06-12-2012, 09:58 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Reply HDTV Recorders
