Slooow Channel Surfing w/most DVRs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-23-2012, 11:16 AM - Thread Starter
500GB's Avatar
Hi Folks:
I'm currently using a DirecTV HR24 DVR for my time-shifting, but will soon have a Verizon (Motorola) QIP7232 DVR (don't tell DirecTV!). DVRs in general take more or less forever to change channels, presumably to set up buffering for the new channel. Most of us have been told that, in order to get faster channel-changes, you should set the DVR to output a FIXED resolution (say, 1080i) and avoid using "native". So, here's my question:
WHY wouldn't it take less time for the DVR to leave the resolution untouched (native)? Wouldn't it take more time to upconvert every SD channel (or cross-convert a 720p channel) to 1080i? Beats me.....
500GB is offline
post #2 of 3 Old 05-23-2012, 12:01 PM
veryoldschool's Avatar
I think there are two parts to this.
1) the TV needing to resync to the new resolution. Mine adds about a sec or 2 as it has to change.
2) the decoding process of the receiver, which might be like changing the resolution on your computer's monitor. A fixed output doesn't slow down your computer as it's playing video.
A.K.A. VOS
veryoldschool is offline
post #3 of 3 Old 05-26-2012, 08:17 AM
Scooper's Avatar
Hi Folks:
Get with the program man - that is what the EPG is for. DBS subscribers have had that same issue ever since it became available. It's time to get out of the "channel surfing" age and into the "EPG" age.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Reply HDTV Recorders
