Cisco Explorer 8742HDC Users Manual - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Shearwes
post #1 of 15 Old 05-27-2012, 12:20 PM - Thread Starter
skear's Avatar
Does anyone have a PDF copy of the Cisco Explorer 8742HDC users manual?
I've contacted my provider (Time Warner) and the only document they could produce was a 2 page quick reference guide.
I couldn't find any information about this DVR on the Cisco website either.
skear is offline
post #2 of 15 Old 06-30-2012, 01:21 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Join the club.
Issue DVR, provide no manual. According to one of their CSR's, there is none due to different firmware versions & updates. rolleyes.gif
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #3 of 15 Old 06-30-2012, 02:48 PM
Steve Mehs's Avatar
Why would you even need a user manual? The Quick Start Guide gives you all of the relevant info had the hardware. For firmware based features of the box, since every MSO is running different firmware, it would be impossible for Cisco themselves to publish a real user manual. I’m not sure about other providers, but Time Warner has a support section on their website, because navigator on an 8240HDC is no different than Navigator on a 8742HDC, the information is universal from one box to the next.
Time Warner Cable – Signature Home Premium View w/Epix, Sports Pass, HD Pass, Spanish Tier, Cisco Explorer 8642HDC, Cisco Explorer 8742HDC Both Running ODN 7.3.0_29
DirecTV – Premier, HD Extra Pack, NFL ST Max, NHL CI, MLB EI, Whole House DVR, HR34-700 Running 0972, HR24-200 Running 0802
Steve Mehs is offline
post #4 of 15 Old 07-01-2012, 04:31 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
I basically stated that.
Which basically contradicts what you just posted.
post #5 of 15 Old 07-01-2012, 07:50 AM
Steve Mehs's Avatar
Yup, you got me, I work for ePVision rolleyes.gif (not sure why that's even relevent)
There’s nothing contradictory about it. There is absolutely no reason for Cisco to put out a user manual when, for many MSOs, they are not the ones providing the firmware, and even if they did put out a manual for each platform, there’s no guarantee that those features will be around after the next firmware update. It would be a waste of effort to create a manual.
What reason do you even need a manual or this thing? If you’ve used any TW Navigator based DVR is the past, it’s basically the same thing. If you haven’t, all the info is on TW’s website. If you’re interested in the hardware of the 8742, that’s what the quick guide is for.
This is a much ado about nothing.
post #6 of 15 Old 07-01-2012, 01:13 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
No. What he is saying is that the manual should be put out by Navigator, not by Cisco. Cisco doesn't know if the user will be using SARA, PASSPORT, NAVIGATOR, or some other firmware. All Cisco manuals only cover SARA. PASSPORT and PASSPORT ECHO have manuals of their own. NAVIGATOR needs to do likewise.
domino92024 is offline
post #7 of 15 Old 07-02-2012, 04:56 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Yup, you got me, I work for ePVision (not sure why that's even relevent)
Take a look at the ePVision DVR thread. Three months and no manual!
I was planing on adding the same to my post. As long as someone supplies some documentation, either in printed form, or a printable on-line manual. Something!
I understand that. At no point did I state only TWC supplying the manual. You apparently assumed that's what I meant, sorry it wasn't. wink.gif
Confused by this. Isn't the term "Navigator" something TWC uses for their user interface (avoiding the terms "software" or more correctly "firmware")? confused.gif
Is "Navigator" some 3rd party that writes the firmware for these, as opposed to some fancy name TWC gave to their user interface?
post #8 of 15 Old 07-05-2012, 07:26 PM
Darth Bateman's Avatar
I would just like to know how to dim the display on the front because it lights up my entire bedroom even when the unit is powered off. I have to cover it with a shirt at night so I can get to sleep mad.gif. Do you have any information on this matter?
Darth Bateman is offline
post #9 of 15 Old 07-05-2012, 08:57 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
The menu should have a entry to change the display to none. No dimming, just off completely.
The only other way is to place a opaque material over the display to 'dim' the output.
post #10 of 15 Old 10-31-2012, 10:32 PM
Shearwes's Avatar
Here is the PDF user manual (or at least the closest thing I could find to one). I am so interested what the USB and Ethernet ports are for.
http://www.cisco.com/en/US/docs/video/at_home/Set-Tops/8000_STTs/4038345C.pdf
Clint S. likes this.
Shearwes is offline
post #11 of 15 Old 11-01-2012, 02:23 PM
Quoted: 126 Post(s)
Liked: 216
What firmware? With TRIO, it's:
SETTINGS->RECEIVERS->FRONT PANEL->FRONT PANEL STATUS->ON WITH RECEIVER
post #12 of 15 Old 11-03-2012, 11:15 AM
Ron-on-Mrng-Vsta's Avatar
As far as I know, the USB port can be used to power a USB device; that is all. On one of my Cisco ("SA") boxes, I use the USB port to power an IR extender. No actual functionality is supported. I can't comment on the Ethernet port.
Ron (Cox Phoenix AZ) SA 8300HD, Passport
Ron-on-Mrng-Vsta is offline
post #13 of 15 Old 11-04-2012, 09:16 PM
TNO821's Avatar
Quoted: 18 Post(s)
That sounds right. Usually those USB ports are there for the cable techs to use when troubleshooting the DVR. The end-user would be able to do nothing other than power a USB device with it.
TNO821 is offline
post #14 of 15 Old 04-07-2014, 09:02 PM
SiriusDoggy's Avatar
I know this is an old thread but I found it searching for an answer to a question I have about this same box so I figured I'd ask it here rather then start a new thread.
Is there any way to transfer programs that are recorded on this DVR to an external eSATA drive. My box is failing (glitching every 30 seconds) and I was told that I needed to exchange the box which would mean that I would loose every program on the DVR. Just looking for a solution before I ditch it.  Thanks!
SiriusDoggy is offline
post #15 of 15 Old 04-08-2014, 02:00 PM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 255
Nope, not that i have ever seen. The MSO's have these locked up tight. of course you can always ask them, but it will probably be a no.
Reply HDTV Recorders
