ePVision PHD-VRX & VRX2 Owners Thread - Page 77 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #2281 of 2559 Old 07-15-2014, 03:07 PM
Quoted: 46 Post(s)
OK thanks - some HDTV boxes I've read about (can't remember which) claim to have a guide but actually require switching through each channel to see the program information.
CanadaJimmy is offline
post #2282 of 2559 Old 07-15-2014, 05:01 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
You do have to scroll through the channel list for each stations programming. The only DVR I know of that uses PSIP data for the program listings that remembers the data is the TiVx (which is discontinued). I'm not sure about the DVR+.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #2283 of 2559 Old 07-15-2014, 05:18 PM
Quoted: 46 Post(s)
TiVx is interesting, shame that the company is dead, looks like there was a lot of potential there. I definitely need to look out for more ATSC products coming out of south korea.
post #2284 of 2559 Old 07-15-2014, 05:50 PM
Aleron Ives's Avatar
Quoted: 1692 Post(s)
Liked: 1449
You can still get them, if you want one, just as you can get the DTVPal (although the latter is rarer, due to being older).
Aleron Ives is offline
post #2285 of 2559 Old 07-15-2014, 06:47 PM
docemc's Avatar
I misspoke; it is an epg program guide. A picture is on p48 of the manual
http://www.epvision.com/HDTVSTB/Docu...anual_v1.0.pdf
I will attach it. Note that the DTVPAL is unfortunately no longer available. It is much more limited that the PHD but is far superior as a DVR
docemc is offline
post #2286 of 2559 Old 07-17-2014, 12:41 PM
JHBrandt's Avatar
Quoted: 1792 Post(s)
Liked: 860
The DTVPal also remembers PSIP data so you don't have to tune to each station to see its guide. In fact it auto-scans all channels with its second tuner (if it's not recording something) to keep the PSIP guide updated.
Like you I'm not sure about the DVR+, but generally I'd expect it, or any device sporting a grid-style guide, to remember PSIP data; otherwise navigating the guide would be too slow to be useful:
I once used a Samsung HD STB (not a DVR) which had a grid-style guide but didn't remember PSIP data. Every time you brought up the guide you lost the video and audio while it rebuilt the guide channels following the current one. Once it was done the A/V would reappear (the video was in a preview window) but if you scrolled the guide it'd stop for several seconds again
JHBrandt is online now
post #2287 of 2559 Old 07-17-2014, 05:01 PM
OTnA's Avatar
Quoted: 21 Post(s)
I'm a new owner of a PHD-VRX2 and I'm hoping one of you can help me out. I apologize if this has been addressed already.
When I play back a recording from a SD 480 channel, the aspect ratio has changed to widescreen, and I mean a very exaggerated widescreen (image attached).
I've tried changing several settings like Scale Window, the Aspect button and the Picture options in the main menu but I still can't get a playback with anything that resembles a 4:3 or a 16:9 picture.
Recordings from HD 1080 channels playback fine. It's just the SD 480 channels that have the altered scaling.
The lowered volume on playback is something I can live with, but this wonky picture size really annoys me. Any suggestions?
OTnA is offline
post #2288 of 2559 Old 07-17-2014, 07:06 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
It's a known issue when you record sub-channels. Sorry, I forgot what the 'fix' was.
Have you tried to change the aspect choices?
post #2289 of 2559 Old 07-17-2014, 07:24 PM
OTnA's Avatar
Quoted: 21 Post(s)
Yes, I tried all the picture sizes available via the Aspect button:
Normal
Full Screen
Panoramic
Zoom1
Zoom2
4:3
Direct
None made any difference
Hopefully someone will remember.
OTnA is offline
post #2290 of 2559 Old 07-17-2014, 08:47 PM
OTnA's Avatar
Quoted: 21 Post(s)
Problem solved!
You were right, videobruce. The solution is in changing the Aspect from Normal to any of the other choices. I don't know why that didn't work for me earlier. My ineptitude, most likely.
OTnA is offline
post #2291 of 2559 Old 07-18-2014, 02:40 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
It won't work in the preview window, just when you are actually watching it in full screen. The aspect names are not exactly correct.
post #2292 of 2559 Old 07-29-2014, 08:56 PM
Ed Bear's Avatar
Quoted: 13 Post(s)
Aspects of Aspects
The PHD-VRX has a unique feature nobody else can boast: complete aspect, offset and size control. You can fine-tune the aspect you want, though you should turn off Auto Aspect in the playback menu to avoid having to re-set it all the time.
I'll be specific: from TV-watching mode (after hitting [EXIT]):
[MENU]
select [PICTURE]
select [AUTO ASPECT]
select [OFF]
Then, after you start playing a program OR watching live, press [QUICK] and select [SCALE WINDOW]
Now you can select and adjust horizontal or vertical size and/or position. For example, you may want to move your image to the top of the screen for a more comfortable viewing angle, or to avoid granny's tchotchke in front of the screen. You get 1% increments, and a RESET button when you've given up on getting it right or don't want to have to move the image 100 pixels back.
Then turn on AUTO ASPECT once you want to go back to common viewing aspects.
Note that you can leave AUTO ASPECT off and just use [QUICK][SCALE WINDOW], but you'll have to re-adjust it after every time you leave viewing, say, to visit the recordings list.
FOOTNOTE: This is one of the pains about the extra remote ePivision sells: there's no QUICK button, so you have to manually set AUTO ASPECT and adjust SCALE WINDOW without being able to see a played-back program as you adjust.
ED BEAR<<(+*+)>>
(SASK//proved)
JHBrandt likes this.
Ed Bear is offline
post #2293 of 2559 Old 07-30-2014, 08:13 PM
docemc's Avatar
unfortunately you cannot distinguish between digital programming and non digital programming as you can on the DTV-pal. The old stuff is shrunk and distorted. This DVR is a piece of ****. Better to buy a used TIVO series III with lifetime service for about $200.
docemc is offline
post #2294 of 2559 Old 07-31-2014, 11:36 AM
JHBrandt's Avatar
Liked: 860
To be clear, the DTVPal doesn't tune non-digital (aka analog) programming. It just passes the RF through when in standby, so your TV can tune the analog signals. The PHD-VRX does tune analog signals, but you can't record them
(There are very few OTA analog signals left in N. America, but some folks still use analog RF for in-home video distribution.)
But the Pal does have both SD (composite and RF-modulated) and HD (HDMI and component) outputs, and lets you set the aspect independently for each. That may be a unique feature.
post #2295 of 2559 Old 07-31-2014, 11:48 AM
docemc's Avatar
Originally Posted by JHBrandt View Post
To be clear, t
yes; that is what I meant. There are over the air subchannels that broadcast old stuff like Lucy, Jack Benny etc and the Pal shows these full screen unlike the PhD; the PhD is very poorly designed and is full of bugs that they will NEVER correct
docemc is offline
post #2296 of 2559 Old 08-01-2014, 12:13 AM
Ed Bear's Avatar
Quoted: 13 Post(s)
Smile Other Options
IF you have a wide-screen TV, it also probably has aspect controls. I know, no help if you don't.
I find the "stretching" of SD signals to be a benefit at times - when using my VCRs, I can record the stretched picture at better quality than if it was letterboxed and using only part of the tape's vertical bandwidth. Then I use the PHD-VRX or TV set aspect controls to fit it back to the screen and it looks better as a result.
It definitely took some learning and experimenting to get to know and love the PHD-VRX, but now I'm so glad I chose it! Most True Geeks will enjoy the challenge, especially Linux users.
ED BEAR<<(+*+)>>
(SASK//proved)
Ed Bear is offline
post #2297 of 2559 Old 08-02-2014, 07:44 PM
radio star's Avatar
Quoted: 17 Post(s)
Liked: 0
Question composite video (CVBS) input and network video server connection
Does the PHD-VRX2 composite video (CVBS) input port work well for converting analog media from external devices such as a VCR?
Also, in order to bypass the 2 TB limit for music, pictures and video streaming is a Network Access Storage (NAS) drive like the Seagate Central STCG4000100 4TB Cloud Storage a good option? This is under the assumption the limitation is based solely on the USB 2,0 port and not the PHD-VRX2 home network video server connection. Therefore, would using the NAS drive as the video server connected through the Ethernet port pose any problems?
radio star is offline
post #2298 of 2559 Old 08-02-2014, 10:01 PM
Liked: 1449
You can't record analogue sources. You can only record DTV received by the tuners. The USB standard has nothing to do with the maximum HDD capacity that a DVR supports. That's controlled by the firmware.
post #2299 of 2559 Old 08-03-2014, 04:15 AM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
radio star;
Are you talking about viewing the upconverted material?
As to the 2nd question, maybe HDTV1980p, Smithdoor or LenL may of.
post #2300 of 2559 Old 08-22-2014, 11:35 AM
Liked: 0
Can anyone tell me how to stop the record mode in upcoming recordings. Can't record anything till I fix this problem. I have the PHD-VRX.
Dan
hayu is offline
post #2301 of 2559 Old 08-22-2014, 02:55 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
You have to go to the upcoming recordings screen to do so, not in the guide. The green button should be th shortcut to that screen.
post #2302 of 2559 Old 08-22-2014, 03:45 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
Hitting the delete button (red) won't delete it? I seem to remember this being discussed some time back. Maybe someone else that encountered the problem will chime in.
post #2303 of 2559 Old 08-22-2014, 03:50 PM
Liked: 0
Thanks Bruce:
The problem is in the upcoming recording screen. I want to delete a recording that was recorded over a week ago. It shows that it is still recording and I can not delete it because it tells me that I must stop the recording before I delete it but nothing is recording. This is stopping the unit from recording anything at all.
hayu is offline
post #2304 of 2559 Old 08-22-2014, 04:13 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
This was discussed.
What do you have on your HDD? How many recordings?
How many recordings do you have scheduled? Are these scheduled through the Guide or manually? Are these one time or repeating?
Also, how about the recording history, how dos that show?
Lastly, what firmware version do you have?
If you uncheck the "Active" check box, does that solve the problem? You can also try purposely trying to schedule a conflicting recording and then let it delete to existing one. (a long shot). Anything else, you will have to wait until one of the others chimes in. I only use this as a occasional tuner.
post #2305 of 2559 Old 08-22-2014, 05:01 PM
Liked: 0
I'm sorry I did not know or could find anything discussed when searching. I only have fourteen one hour recordings on My HDD. I have only three right now scheduled to record. I have the latest firmware and the active is off. Thanks again I will wait for some one to chime in hopefully. You have been helpful in the past that is why I hit you up.
hayu is offline
post #2306 of 2559 Old 08-23-2014, 08:36 PM
Smithdoor's Avatar
If any one want one I have two and only using one
I will sell one for $95.00 plus shipping
FYI do take PayPal
Dave
Smithdoor is offline
post #2307 of 2559 Old 08-25-2014, 06:57 AM
windermere's Avatar
I am not the person in our family that normally programs ours, but I believe this is how you would do it:
-Go into programing and choose the item causing the problem by highlighting it and then click "enter" so it brings up the item and all the attributes of it's program. Go through each item(channel, start time, etc.) as if you are re-programming it to a different schedule.
-Try and "Stop" it from there. If it still does not respond go out of the programming area, switch from one tuner to the other and back again and try again.
-If it will not let you stop it you may have to disconnect power (which will cause all the programing to be lost).
If you have read previous posts, you may have noticed that these units seem to have more "hiccups" if you are asking them to do several things at once. If we are recording on both tuners, and watching a previous recording at the same time, we try not to erase the recording until after at least one of the recording programs is done (preferably when it is not recording at all).
windermere is offline
post #2308 of 2559 Old 08-26-2014, 04:51 AM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
hayu;
windermere beat me to it.
Edit that entry to start 5 minutes later than the current time, have it run for 5 minutes record time. When the recording starts, stop it. That should do it.
For the heck of it I maxed out the number of scheduled recordings in two sessions to see if I could get it to lock. After #32 , it did lock. These were random manual recordings set for 10 or 15 minutes each, set to daily, Sat & Sun & weekly using both tuners.
My guess is memory corruption. I deleted every entry scheduled, then fully power down overnight. I was still showing recording. )I didn't wanted to do a reset except as a last resort.)
Try that and post back.
post #2309 of 2559 Old 08-26-2014, 11:11 AM
Liked: 0
Thank you both:
Well it worked, did the whole dog and pony show B.S thing with it and it's clear now. Would have introduced it to my 12 gauge long ago if it wasn't for your help.
EPvision does not responded to problems, so I guess Allen has given up on this half baked piece of crap for supporting the PHD-VRX 2 (the other more three quarters baked piece of....)
I guess it's sorry if you have the old one, shet out of luck. Should have waited till we had a better one. But thanks for your money.
Oh well!
hayu is offline
post #2310 of 2559 Old 08-26-2014, 02:33 PM - Thread Starter
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
It was a bad choice for a system chip. I wonder if more memory would help.
Actually, that is just an annoyance, nice if it wasn't there, but at least not major.
I'm surprised it took me so long to get it to act up. All 32 events.
Reply HDTV Recorders
Epvision Phd Vrx
