Software bug - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2012, 03:00 PM - Thread Starter
rit56's Avatar
This happened to me twice. I was fast forwarding a show and I got a telephone call. Once the called ID appears on the screen it renders the remote useless. You cannot stop, pause, anything until the box disappears.
rit56 is offline
post #2 of 2 Old 06-23-2012, 05:20 PM
bobby94928's Avatar
Liked: 374
You usually have to press select to get the caller ID to go away if you want instantaneous use of the remote. It might help if you told us exactly which DVR and service you have....
Bobby
bobby94928 is offline
Reply HDTV Recorders
