Windows Media Center vs TiVo Premiere - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #901 of 1106 Old 09-23-2014, 09:10 AM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
Originally Posted by mdavej View Post
Just be careful with Shark. Last time I tried it a few years ago it completely killed all media playback on my PC. I had to reinstall my OS from scratch. It was a very unpleasant experience. It's also now a minefield of malware and spyware unless you know the installation tricks. While LAV is a bit less comprehensive, it's far simpler and less risky.
I use shark on my original Win7 MCE, but use LAV on new WMC 8.1
mark_anderson_u is offline
post #902 of 1106 Old 09-23-2014, 09:11 AM
Quoted: 43 Post(s)
Liked: 42
Originally Posted by Charles R View Post
You can call/run XBMC from inside of WMC if you want to keep the interface easy.
Thanks for reply. Is there a plug-in required for this?
What are you using these days?
post #903 of 1106 Old 09-23-2014, 09:37 AM
Quoted: 43 Post(s)
Liked: 42
My favorite media player on a PC is Daum Pot Player.
Never come across that one before. Used various others in past. Not too much info on site. Have a few questions if you don't mind
  1. Does it support Blu-ray ISO's? Guessing not and can live with MKV, but really like having the whole BD ISO
  2. Does it support DTS-MA and TrueHD?
  3. Is the integration seamless (i.e. click MKV and it will launch player - I currently use MB3 with MBClassic plug-in)
TIA
Mark
post #904 of 1106 Old 09-23-2014, 09:51 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
TIA
Mark
Sorry, can't answer most of that. I don't do ISO's. But you can associate any or all file types with it if you want. Seems like I had to do some sort of conversion for some audio formats due to licensing. Just try it and see if it works for you. Install/uninstall is very clean as it uses its own codecs. I found it to be light-years ahead of MBC. I've tried MB3 many times, but have never had any success (bogs down WMC to the point its unusable - takes tuners and never lets go, Roku player too buggy, resource hog on my bare bones WMC server).
It's best to get the English version from here, otherwise you'll end up with the original Korean version.
http://www.videohelp.com/tools/PotPlayer
mdavej is offline
post #905 of 1106 Old 09-23-2014, 10:17 AM
Quoted: 43 Post(s)
Liked: 42
I have same issue with MB3. Seems to have huge resource leak. Close to trashing it.
post #906 of 1106 Old 09-23-2014, 10:37 AM - Thread Starter
Charles R's Avatar
Liked: 536
You simply need to unzip the download and run the Shark007 setup utility which allows you to bypass all of the container software. I think there was one version (for a few days) that installed malware even if you selected no... however by running just the Shark007 setup you are good to go.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #907 of 1106 Old 09-23-2014, 10:47 AM - Thread Starter
Charles R's Avatar
Liked: 536
I presume it's still current...
http://www.teknowebworks.com/xbmc-Wi...er-Integration
I use WMC 100% for DVRing. I also use ServerWMC to view WMC recordings/live TV via XBMC/Kodi. Currently with Windows and OpenELEC. Fantastic app and makes Kodi the perfect extender for my use. If it didn't work so well I'd go back to TiVo...
https://0df317251eddfb99d4fce96eecb4...T2c/index.html
post #908 of 1106 Old 09-23-2014, 11:38 AM
mdavej's Avatar
Liked: 940
ServerWMC is precisely what makes WMC unusable for me. Eventually uses every tuner, leaving none for WMC, even if I kill the service. I'm probably just doing something wrong, but I can't get it to work without causing major stability issues in WMC.
mdavej is offline
post #909 of 1106 Old 09-23-2014, 11:57 AM - Thread Starter
Charles R's Avatar
Liked: 536
Are you up to date? I know he has updated the server a couple of times in the last few days. Not for you as you probably know but you can update it inside of the app itself now. I had ServerWMC viewing recordings and all four tuners active most of last night without issue.
I did have to punt commercial skip for Windows 8.1. It was a nightmare per se. I would get errors and one show would be recorded instead of another for a few minutes - then the recording would switch to the correct show. In all of the cases it was when multiple recordings would get fired off at the same time. This was when it was set to scan live... during the recording.
I couldn't find a setting to restrict the number of workers like the Windows 7 version and I never had issues with the Windows 7 version at all. I might take another look at some point and perhaps try to set it to only process after the recording has completed. But right now I don't want to take the risk of losing any recordings.
post #910 of 1106 Old 09-23-2014, 12:26 PM
mdavej's Avatar
Liked: 940
Actually haven't tried it in months. If it doesn't work right away I have to uninstall or a lot of people inside and outside my house get mad at me. Sounds like it may be worth another try. Still have problems with MB3 in general though. Didn't work well when I tried it with Roku last week.
Problem is I don't really need any of it. Remote Potato is old and clunky but works well enough for my purposes.
mdavej is offline
post #911 of 1106 Old 09-23-2014, 01:13 PM - Thread Starter
Charles R's Avatar
Liked: 536
You should be able to keep an eye on the tuners via the ServerWMC Tuner tab. I tend to view more recordings than live TV which doesn't require a tuner. Here's a few shots of the WMC PC (Remote Desktop) and the desktop I'm using... a couple live and a recording.
ID:	276345   Click image for larger version
ID:	276353   Click image for larger version
post #912 of 1106 Old 09-23-2014, 03:01 PM
mdavej's Avatar
Liked: 940
Nice. Didn't know that was there. I'll give it a shot.
mdavej is offline
post #913 of 1106 Old 09-23-2014, 04:32 PM
Quoted: 43 Post(s)
Liked: 42
post #914 of 1106 Old 10-12-2014, 12:45 PM - Thread Starter
Charles R's Avatar
Liked: 536
This poor thread needs a post...
Since I moved my WMC PC to the TV and started using another for my desktop I have really been using XBMC (Kodi) as an extender and it's working great. It even wakes my WMC PC from deep hibernation. Also my Chromebox (linked in my signature) has been working just as well for TV viewing. The Chromebox has been getting rave reviews... see the thread... and I highly recommend it as a $150 extender (won't do protected content however) that obviously handles local streaming wonderfully.
This has been the first time I have had ServerWMC running constantly and I have had zero issues.
post #915 of 1106 Old 10-22-2014, 02:58 PM
hubcityraider's Avatar
Liked: 0
How weak of an old desktop can I get away with as my server for this setup?
At most the server would be recording 2 OTA things while playing another. It would not serve any other computing purpose beyond being a pvr backend and file server for the xbmc clients.
For example I'm looking at a 2010 HP with the following specs:
Hardware:
2.7ghz Dual Core Processor
4gigs DDR3 Ram
1tb Hard Drive
Thoughts?
hubcityraider is offline
post #916 of 1106 Old 10-22-2014, 05:44 PM - Thread Starter
Charles R's Avatar
Liked: 536
That would be more than enough horsepower. If you want to use commercial skip (either Windows 7 or Windows 8) horsepower can become an issue based on how it's configured but outside of that virtually "anything" can handle the load. Here's some images of XBMC running on this PC and the ServerWMC via Remote Desktop. It's an old i3 and pretty much idles with 4 recordings and serving a few clients.
ID:	325442   Click image for larger version
hubcityraider likes this.
post #917 of 1106 Old 10-24-2014, 07:58 PM
bowenap's Avatar
I'm not quite sure if this is a WMC problem or an HDHomerun Prime problem but I have recently bought a WMC remote that I have programmed my Harmony 700 to. I have the activity set to turn the TV on, turn the sound system on, turn my Eagle Aspen antenna rotor on, wake the HTPC from sleep, and then start WMC and go straight to Live TV. I have both an HD Homerun Dual run from an OTA antenna on my roof, and an HD Homerun Prime for digital cable.
When I turn it off, I have the activity set to turn off WMC, turn everything else off, and put the HTPC to sleep.
Both activities seem to work fine. However, when I turn the system back on after putting it to sleep, the picture on the digital cable (i.e. the HD Homerun Prime) is all messed up. I get a green pixelation effect that only seems to go away if I restart the computer. I imagine this is a problem with the Tuner itself as the Dual shows the OTA stations just fine. However, I am left wondering if it could possibly be a CableCard problem.
bowenap is offline
post #918 of 1106 Old 10-25-2014, 08:50 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1733
Not sure if this helps your issue or not, but when I boot up the HTPC, it has to be with the receiver off, or at least with something other than the HTPC selected (video routes through the receiver in my setup). For whatever reason, if the graphics card sees the receiver during boot, it changes the settings to something the TV can't render. I don't know about waking from sleep. Mine goes into standby and the hard drives spin down, but it never sleeps.
So, try waking the HTPC before turning anything else on.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #919 of 1106 Old 11-20-2014, 08:11 AM - Thread Starter
Charles R's Avatar
Liked: 536
FYI: The Add-on for ServerWMC has been released for Kodi (14.x) using OpenELEC.
Which means when Kodi (14.x) ships you'll be able to use OpenELEC as an extender. With Beta 3 it's working like a champ and appears to be faster than ever. Such as tuning channels which has always (up to now) been a challenge.
If you are curious about OpenELEC you can find them here.
http://openelec.tv/
If you click on my signature Chromebox link you can find out about running it using a Chromebox for as little as $118 (recent Fry's price). You get one heck of a media player thrown in for free.
post #920 of 1106 Old 11-24-2014, 07:12 AM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
limited time deal
I have been trying-out WMC on an old laptop while searching for a good deal on a pc. I hit on a deal I think is good enough to pass on. It's a "Redistributed," Lenovo H530 with win7HP-64, Intel® Core™ i3-4150, 6GB DDR3 & 1TB, 7200RPM Serial ATA 2.5" Hard Drive - Full specs:
Model Highlights
Part number: 57327876
Condition
Redistributed
Processor
Intel® Core™ i3-4150 Processor (3M Cache, 3.50 GHz)
Operating system
Windows 7 Home Premium 64 - English
Graphics
Intel HD Graphics 4400
Memory
6GB (2GB & 4GB) PC3-12800 DDR3 1600MHz SDRAM UDIMM Memory
Display
None - Desktop
Pointing device
USB Full Size Keyboard and Optical Wheel Mouse
Hard Drive
Optical Drive
DVD Recordable Serial ATA
Battery
No Battery Included - Desktop
Network Card
11b/g/n Wi-Fi wireless
Bluetooth
No Bluetooth
WWAN
No WWAN Supported
Finger Print Reader
No Fingerprint Reader
Warranty
1 Year On-Site Warranty
Form Factor
Tower - Glossy black and brushed meta
Lenovo H530 -- All for $235.36 !!!
While supply lasts at Lenovo outlet.
http://outlet.lenovo.com/outlet_us/i...s/57327876/445
All desktops.
http://outlet.lenovo.com/outlet_us/desktops/#
Currently offering, Free shipping and returns.
My understanding is that, "Redistributed" = new, returned unopened.
Happy Holidays!
happy2Lurk is offline
post #921 of 1106 Old 11-24-2014, 07:27 AM
scubasteve2365's Avatar
Quoted: 261 Post(s)
Liked: 344
I've been using WMC without issues for a little while now. Happy I went this direction.
One warning for users, my PC that runs WMC received a windows update from Microsoft (I'm running 8.1) and for some reason after rebooting it flagged my home network as "Public" instead of "Private" and the result is that the PC refused the ethernet/ip connection to the HDHomeRunPrime so I missed a few recordings. Simply going into "network connections" and making the network "private" opened it up.
"The Scuba Tank" thread here
PSN/XBL : ScubaSteve2365
VR Roundtable
scubasteve2365 is online now
post #922 of 1106 Old 11-24-2014, 11:58 AM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
wireless keyboard suggestions?
Originally Posted by happy2Lurk View Post
I have been trying-out WMC on an old laptop while searching for a good deal on a pc. I hit on a deal I think is good enough to pass on. It's a "Redistributed," Lenovo H530 with win7HP-64, Intel® Core™ i3-4150, 6GB DDR3 & 1TB, 7200RPM Serial ATA 2.5" Hard Drive - ...
Well, they didn't last long. When I posted a few hours ago, there were 1,200+ in stock - now all gone.
Sorry about that.
Anyway, now that I have a dedicated pc on the way, any wireless keyboard suggestions?
I have considered the, Rii i8 Mini 2.4GHz Wireless Touchpad Keyboard with Mouse - but concerned about quality, durability.
I like the idea of the Logitech Unifying wireless receiver - one less usb port if I get separate wireless mouse.
What about KB's with touch-pads - any that work well?
I don't expect to do a lot of typing, so looking for inexpensive but reliable. Wondering what you guys use.
post #923 of 1106 Old 11-25-2014, 12:42 PM - Thread Starter
Charles R's Avatar
Liked: 536
I'm running 8.1 as well and haven't seen the issue. I'm patched up to today...
post #924 of 1106 Old 11-25-2014, 07:33 PM
kwg
kwg's Avatar
happy2Lurk,
Logitech Wireless Touch Keyboard K400
kwg is offline
post #925 of 1106 Old 11-26-2014, 09:32 PM
happy2Lurk's Avatar
Quoted: 34 Post(s)
Liked: 27
TunerSalad the only way to beat wmc 4-tuner limit?
kwg, thanks for the tip, the LogitechK400 is one I've looked at. Is that what you have? Do you like it? Pros/cons?
Anybody need a SiliconDust HDHomeRun HDHR4-2US? Both Newegg and Amazon have them for $70 right now. Best price I have seen.
I just ordered another, which will give me 6-tuners. So I need to ask, is TunerSalad the only way to beat the wmc 4-tuner limit? When I first started looking into wmc, I thought I read about a registry hack to remove the limit. I have searched and just can't find it. All I can find is TunerSalad. Is there another way to get more than four HDHomeRun tuners working in wmc?
post #926 of 1106 Old 12-05-2014, 12:28 PM
Y2KFirehawk's Avatar
This thread is awesome. I was a Windows XP MCE user for a long time in the infancy of HDTV. Along came HDTV and there was not a "home-brew" tuner option so I ended up going TiVO. Missed many of the functions Media Center had. The interface cannot be beat. Shortly thereafter I went DirecTV and subsequently one of the first users of their whole-home DVR service.
Fast forward to about 2 years ago I got myself an HDHR and slapped a CableCARD in it and built a Windows 7 machine to run it and I was back in my glory days.
Now reading through this I am considering my extender options. I have a Raspberry Pi with XBMC loaded on it but it was mentioning I needed to purchase some sort of codec to make things work...
Y2KFirehawk is offline
post #927 of 1106 Old 12-05-2014, 03:47 PM
mdavej's Avatar
Liked: 940
I use free LAV filters, and my 4 Echoes play everything I've thrown at them. Besides Xbox, they're the only currently sold extenders that will play copy protected content from WMC. I used Pi for a little while and was completely underwhelmed. I never had to buy any codecs for it.
mdavej is offline
post #928 of 1106 Old 12-22-2014, 01:35 PM
DavidinCT's Avatar
Quoted: 243 Post(s)
Liked: 67
I've heard (have not tried myself), if you install the Ceton driver for the Infinty6 (6 tuner card), it will do the changes of the system so you can support more than 4 tuners of one type (You can by default do 4 of each type, 4 CC, 4 QAM, 4 analog etc).
There are a lot of other cool things you can do with Media Center...you can theme it with different colors and background images, you can ad ICONs next to the channels in the guide. 30 min pause time not enough? you can extend this out to as long as you want, mine is set for 12 hours...it's just a simple registry setting.
It's too bad that the eHome team broke up, They ended it right before Windows 8 came out. Still would like to see them update it a little, new layout (or really good themes), fixed Movie library (works but very flakey), support for 4K, Xbox one as a Extender, etc, the list goes on...
I used to build (my own business) custom Windows Media Center PCs, so customizing these can be pretty flexible if you wanted it to be.
I've been using Media Center from XP media Center the very first version of MC and my current system is a dedicated HTPC with about 300 movies(with HD audio), 2tb for recording TV, cablecard (infinty4) had QAM till Comcast shut it off, and 2 extenders...
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #929 of 1106 Old 12-23-2014, 01:57 PM - Thread Starter
Charles R's Avatar
Liked: 536
Happy Holidays WMCers
What's a Holiday without a little Marilyn cheer.
DavidinCT likes this.
post #930 of 1106 Old 02-04-2015, 11:32 AM - Thread Starter
Charles R's Avatar
Liked: 536
Well my faith in WMC is being tested. Of late I'm having the extremely rare issue I have seen for years on a regular basis. When (and only when) I fire off four concurrent recordings one/two of them might not record or stop recording within a couple of minutes. Never have seen the issue with three or less concurrent recordings.
WMC either reports a loss of signal (typically on one of the recordings) and the other keeps recordings but the file size never increases. Reviewing the WMC history it appears to be only happening with one of the HDHomeRun units (I have two for four tuners in total). Reception is never an issue and I can stop the recording and instantly view the channel.
Network (have used various network drivers) appears fine as I transfer 2TB+ at 110MB/s+ for hours without issue. Over the period I have used numerous hard drives and it appears to only happen with the one device. The other two recordings (via the other device) complete without issue. I'm guessing (and more or less confirmed) that WMC uses the tuners in a strict order so the fourth tuner is only used when recording four concurrent shows.
At this point the only common item appears to be the one device. I have swapped power, network, and coax cables to see if the problem travels with them. At this point I have to believe the device is iffy/flaky and I have ordered a replacement. If that resolves it great I'm sticking with WMC. If not, I think I'll punt back to TiVo. Too much of a hassle to debug elsewhere as I have had the issue with endless different PC configurations.
I posted at Silicondust's Forum and hopefully they will take a look at the logs and pass along anything they see.
Reply HDTV Recorders
Tivo , wmc
