Windows Media Center vs TiVo Premiere - Page 36 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #1051 of 1061 Old 03-12-2015, 04:03 PM - Thread Starter
Charles R's Avatar
Liked: 303
Originally Posted by happy2Lurk View Post
I thought about trying other skins, but haven't gotten around to it yet. Please save me some time, by letting me know, which skin(s) to try.
Of course it doesn't add recordings options/features that don't exist but from a pure user interface Titan MediaBrowser is pretty slick. I actually like it better and you can customize it for mouse or remote support and it changes accordingly. A few shots...
ID:	599065   Click image for larger version
ID:	599073   Click image for larger version
ID:	599081   Click image for larger version
ID:	599089   Click image for larger version
| Home Theatre Tweets |
120" 16x9 | Mitsubishi HC7900DW | 7.2.4 Boston Acoustics & Power Sound Audio | Denon AVR-X5200W + AudioSource AMP 110 | OpenELEC/Kodi HTPC Build | WMC/DVBLink/TiVo DVR
Charles R is offline
post #1052 of 1061 Old 03-13-2015, 11:46 AM
happy2Lurk's Avatar
Liked: 25
Thanks for the suggestion. I'll give Titan MediaBrowser a try.
happy2Lurk is offline
post #1053 of 1061 Old 03-13-2015, 01:15 PM
csmith's Avatar
Quoted: 35 Post(s)
Liked: 27
I like Black Glass Nova, guide is high-contrast and information is easy to read far away.
Some skins are not as snappy on some systems and just too much for it (i.e. Raspberry Pi), but the chromebox seems to be able to handle most.
csmith is offline
post #1054 of 1061 Old 03-16-2015, 02:49 PM - Thread Starter
Charles R's Avatar
Liked: 303
I haven't use WMC for a week and I'm at the point of no return. DVBLink has been rock solid with only one viewing issue and zero recording issues. I'm still debating on which NAS to use so I won't say it's a done deal. But it's about as close as it gets. I do have WMC installed in my desktop so in an emergency it can fill in. My guess is all told I'm giving up more than I'm gaining but I'll keep that for my letter of resignation.
post #1055 of 1061 Old 03-17-2015, 08:37 PM
clarkss12's Avatar
Quoted: 58 Post(s)
Liked: 32
I am humbled by all the rich people on this thread. I, unfortunately don't have the financial means to acquire a TiVo and minis in order to record TV, nor can I afford an expensive PC that uses a lot of electricity.
However, I am able to create a whole home DVR solution using one $35 Android TV stick for DVR/PVR backend and a $70 HDHomeRun tuner. An $80 Android TV box connected to each TV that has full DVR capability and all the internet apps.
This is a poor man's solution and it works very well.
clarkss12 is offline
post #1056 of 1061 Old 03-19-2015, 08:34 PM - Thread Starter
Charles R's Avatar
Liked: 303
My Windows Media Center days are gone. Approaching two weeks since I have used it and I must say I don't miss it at all. I have have a couple of bumps during the transfer process. Such as WMC recording at the same time as DVBLink and running out of tuners. Bottom line I'm giving up recording intelligence (better Repeat logic, conflict resolution, etc) and gaining the ability to be PC less for recordings. Along with something new. After almost three years I was ready for a change.
My NAS is scheduled to wake up at 6 pm and powers down at 2 am (WoL for clients and maintenance). While alive it does all of the recordings and stores them locally. It's completely self-contained. I can manage my recordings with Kodi or any browser via the DVBLink interface. The browser interface is rather plain Jane but it comes in handy for your typical maintenance. Easier than Remote Desktop and or powering up the PC.
Now I have to thank or curse RTK (Rick) for his suggestion to look at Kodi's Titan MediaBrowser skin. I don't think I would have switched if I hadn't. It took a couple of hours to configure but once I did my user experience was superior to WMC. Now for those advanced thinkers yes I can use Kodi with WMC via ServerWMC so that's irrelevant. However it isn't on one level. It introduces enough of a change that I'm willing to change other things right along with it... if that makes sense.
Again the real swap is taking a PC out of service and re-purposing it. Letting my NAS handle recordings and having a client for viewing. I like that I'm not relying on a PC for recordings. It was never really an issue but it just feels better knowing you don't have to worry about a PC being up. Also, my viewing is done via clients which are completely independent of the recording process so no matter what they can't influence it. In the past I have used my desktop or a dedicated PC for both recording and viewing.
During the process I did give TiVo a passing thought but I watch a fair of TV on my desktop and I can have the identical interface as my clients. Only difference is I tweaked the skin for mouse support versus a remote.
Is DVBLink better than WMC? On a generic level I would recommend WMC. In my case I give DVBLink 51%. If they educate the recording logic a fair degree it will be closer to 75%. My buy in was roughly $50 in software (NAS recordings apps) and $30 annually for guide data. The data comes from the same service TiVo uses. Unfortunately DVBLink doesn't implement a few options based on the guide data that TiVo does... hence my earlier comment.
If you have any interest there is a similar DVBLink thread linked in my signature with lots of pretty pictures and a little information. I leave WMC with more affection than when I started and I'm certainly not running from it. Rather I'm looking forward to something new I'll hopefully appreciate to the same degree.
Attached is the NAS resting on an old-school DVD player that hides a few wires and isn't even plugged in.
post #1057 of 1061 Old 03-21-2015, 11:53 AM
Quoted: 16 Post(s)
Liked: 0
1. What NAS are you using? Custom Built? I didn't know you can actually make NAS power down and up itself. I know a computer can do that.
2. What Media viewing software is that I believe I never heard of DVBLInk?
mbmcallister33 is offline
post #1058 of 1061 Old 03-21-2015, 12:00 PM - Thread Starter
Charles R's Avatar
Liked: 303
Just follow the NAS Based DVR link in my signature. It's not for everyone but it's rather cool. The NAS is a (very) low-end QNAP at $149 and most vendors have power scheduling and drive spin down.
post #1059 of 1061 Old 03-21-2015, 03:19 PM
Quoted: 16 Post(s)
Liked: 0
...Wow. Turning NAS into personal TV server? That's awesome....I just might look into this. I'll be sure to tread the water carefully.
I been researching to find a good meaningful HTPC to allow to watch TV without cablebox but extend extra channels through every room.
post #1060 of 1061 Old 04-01-2015, 06:19 AM - Thread Starter
Charles R's Avatar
Liked: 303
I have been full-time NAS for roughly a month and so far so good. No complaints at all. I just picked up another PC client for $70 (Fry's barebone kit) running OpenELEC/Kodi/Titan Mediabrowser and I much prefer the user interface over WMC.
The same DVR software runs on PCs but I find having it isolated on the NAS removes one layer of concern. Accessing it from my browser comes in handy when you want to update this or that and don't really want to turn on the TV and all of the other equipment. Certainly not perfect but so far I'm glad I switched.
post #1061 of 1061 Old 06-12-2015, 08:20 AM
rms8's Avatar
Quoted: 305 Post(s)
Liked: 178
Great, informative thread.
Thanks for the details and time!!!!
*DIY ConcreteBunker Rustic Dream Build w/11' screen, 11.2chnl, 8x18" IB subs, 28.8KW*
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
April 2015 HToM <> SuperCharged 10 second II
rms8 is offline
Reply HDTV Recorders
Tivo , wmc
