Lost Grid Data in Los Angeles - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-06-2012, 07:41 PM - Thread Starter
Ray1938's Avatar
I have two machines. The grid on the 250 unit lists a few shows, and the grid on the 500 unit is completely blank. Clock is ok on both units. This problem has been going on for a few weeks.
Has anyone else in the Los Angeles area experienced this problem?
Ray
Ray1938 is offline
post #2 of 3 Old 08-10-2012, 11:36 AM
barbacoa's Avatar
Hi Ray... I'm your neighbor (Santa Monica) and have 2 DHG-HDD250's... One rebooted itself a week ago, and while I have a an accurate clock, there are only about 3-4 lines of grid remaining. It does seem to be recording shows that I had previously set up. I'm wondering
what the next step might be? I have not been into the 9181 service menu, as of yet. Might this require a "reset or default TVGOS" command, or some such thing? Any ideas out there?
I am OTA only v. 1.2.21 firmware-- BTW My other machine is fine w/ a full grid
barbacoa is offline
post #3 of 3 Old 08-20-2012, 09:42 AM
LimeyGreg's Avatar
I have been experiencing loss of grid info for at least a week, maybe more. I have two machines, a 500 and a 250. The problem I'm having is that both machines are simultaneously resetting at least once every hour, and several times a day twice an hour, at around 3 or 4 minutes past the hour and half hour, I have most of my grid but Ch 11 & 13 seem to have a lot of "no listing". This is very perplexing and I was wondering if anyone else is seeing the same issues?
Could either or both of you check the "error re-set page" in the 753 menu to see if you are experiencing a similar reset? This could be the cause of your loss of grid info.
Just to add to my issues I had a 10 minute power outage yesterday (breaker tripped) and now my 500 has lost it's grid completely due to loss of zipcode & timezone data. This morning the zipcode was set but the timezone offset was completely wrong, so I might have grid back when I get home later.
Greg.
LimeyGreg is offline
Reply HDTV Recorders
