MagicTV MTV7000D-MINI HDTV HDD DVR - Pure HD recorder - Page 2 - AVS Forum
post #31 of 59 Old 11-19-2012, 05:37 AM - Thread Starter
esdwa's Avatar
Originally Posted by videobruce View Post
After reading through the manual, (...) Other than the tuners frequency assignment, the only other negative is no digital (optical and/or coaxial) inputs
Both HDMI inputs pass through multichannel bistream so those who have HDMI compatible receiver should be all set even without coax and opt i/o.
esdwa is offline
post #32 of 59 Old 11-19-2012, 05:50 AM
videobruce's Avatar
Quoted: 83 Post(s)
Liked: 117
But those who don't...............?
It's the same problem with that VRX, though that is a output issue. My point is you can only feed it digital audio via HDMI. What if you have component to 'feed' it? The only audio would have to be analog stereo.
Abundant OTA television is what makes this country different from all others. Lets keep it this way.
The Internet is no place for streaming video.
videobruce is offline
post #33 of 59 Old 11-25-2012, 05:54 AM - Thread Starter
esdwa's Avatar
With this you should be able to fill your need for separate toslink/coax feed.
You may also need hdmi to dvi cable along with toslink or coax cable to connect your source.
esdwa is offline
post #34 of 59 Old 02-14-2013, 08:47 AM
Doug O's Avatar
Hmmm...can you pull the program content off the HDD? That is the million dollar question that everyone wants to know...
Doug O is offline
post #35 of 59 Old 02-14-2013, 09:40 AM
Headhunterx's Avatar
How do you get one??????????????
Headhunterx is offline
post #36 of 59 Old 02-14-2013, 09:58 AM - Thread Starter
esdwa's Avatar
Yes, you can pull files and store on external HDD. But you wont be able to watch it on your PC for example because TS files created with MagicTV for HD content are encrypted.
People import these from HK.
esdwa is offline
post #37 of 59 Old 02-14-2013, 10:17 AM
So, who imports them?
post #38 of 59 Old 02-14-2013, 10:34 AM - Thread Starter
esdwa's Avatar
Yourself.
esdwa is offline
post #39 of 59 Old 02-14-2013, 10:46 AM
That is a real good answer.... since we are discussing Unicorns what is the use...
post #40 of 59 Old 02-14-2013, 11:05 AM - Thread Starter
esdwa's Avatar
It is precise answer. This is how we got it. Not sure what else you expect me to say.
No need to be rude.
esdwa is offline
post #41 of 59 Old 02-14-2013, 11:30 AM
I wasn't being rude, just stating a fact ... If we cannot get it here then why talk about it it makes no sense... I just wanted to know where to get one and I am an American not foreign... so not an insult just fact... I figured someone knew how to get it but sorry for the assumption.
post #42 of 59 Old 02-14-2013, 02:05 PM
Doug O's Avatar
Why would the files be encrypted? I'm wondering if PVRExplorer could read the files as it does with some Bell/Dish receivers. The files are not encrypted and can be viewed or archived. The device is moot if you already have a PVR or the files cannot be saved from the hard drive. I thought that is the whole point of using such a recorder, that you are going to archive content. Otherwise, I already have a PVR I can't archive the programming from. Have you tried to recover the programs? What process did you use? What programs? Is there a Chinese user group for the device? I think there is one for the Australian/NZ model without the HDMI inputs. Means I have to do more reading...
Doug O is offline
post #43 of 59 Old 02-14-2013, 02:29 PM - Thread Starter
esdwa's Avatar
Look on eBay for reliable worldwide merchant based in HK with long history and lots of positive feedback. Many selling tech goods ship these recorders.
esdwa is offline
post #44 of 59 Old 02-14-2013, 03:05 PM
Doug O's Avatar
Interesting that according to the Aussies, the earlier model MTV4000 can definitely have its programming pulled at least from free TV using a USB flash drive or hard drive (see post #131) and the content can be edited using Videoredo:
http://www.dtvforum.info/index.php?showtopic=95076&st=125
Also, there is a menu pull down that says transfer to USB HDD in this video:
http://m.youtube.com/#/watch?v=iiTV3k4wgdc&desktop_uri=%2Fwatch%3Fv%3DiiTV3k4wgdc
I have to do more reading if the later models retained those features...
Mtv4000 spec clearly states content is transferable:
http://www.magictv.com/au/mtv4000pvr.html
It could be an undocumented feature as the devices seem to be aimed primarily for time shifting rather than archiving. Not mentioning something gets around the sticky problem of having a device that is legal in one country and illegal in another. Still trying to find info on Aussie users of the MTV7000 and what they are using the devices for...
According to this
http://forums.whirlpool.net.au/archive/1813180
you cannot rip the HDMI recordings to a hard drive for processing. I'm assuming recordings done from component can be recorded like the Hauppage and MTV4000 though and then transferred to a PC. No inputs exist for component on the mini model though they do on the full size MTV7000 and no HDMI inputs on the MTV4000. So, we are back to square one at this point...
Doug O is offline
post #45 of 59 Old 02-14-2013, 06:31 PM - Thread Starter
esdwa's Avatar
Have been using this recorder for a while and most of your questions has been answered in this thread as well as on another here
http://www.avsforum.com/t/1353038/recorder-with-hdmi-inputs-yes-it-exists
All files from Mini can be archived on separate hard drive, thumb drive or whatever you can plug to built in USB port on the back of the recorder. You can also have external drive connected at all times and use it as additional storage for your recordings and playback. But I think your point of using recorder is to have freedom to playback HD recordings on any other device incuding PC. And here where your freedom ends because in order to playback archived HD recordings you have to use MINI the one you used for recording or another within same LAN network (MINI has full streaming capability). This does not apply to SD recordings where TS files created by Mini are not encrypted. You say you already have PVR, is it HD recorder capable of recording through HDMI? I also wonder what do you mean by asking about "recovering programs". There is nothing that needs to be recovered, you simply select previously recorder program from internal or external drive and play it back. The recorder also works as typical timeshifting device so I do not miss a second of favorite program if I get interrupted while watching.
There is a NZ forum for users of similar model MTV3700 ou might want to check.
http://www.geekzone.co.nz/forums.asp?forumid=83&topicid=89464
There is also short website about someone hacking MTV3600 model:
http://2lostkiwis.com/wordpress/mtv3600/
Good luck.
esdwa is offline
post #46 of 59 Old 02-14-2013, 08:52 PM
Doug O's Avatar
As I understand it, the 3700 and 4000 series have component input but no HDMI input. The 7000D HK model has HDMI input but the recordings in high definition cannot be copied to a PC. The Hauppage HDPVR 1212 has component inputs but no HDMI input. The Hauppage HDPVR 2 has HDMI but only for recording non encrypted sources like video games consoles. I don't think the content on satellite or cable is non encrypted content, through the HDMI though the box states that you can record from those sources. It may be using the component inputs again however. I don't know anyone with the newer unit, so I can't check at this time. Several satellite STBs can have their hard drives read by a PC but that's another story. The files in that case are non encrypted, both SD and HD. Unfortunately, the model I have isn't one of those. Recovering programs I meant to say copying from the internal hdd to the PC. You say it can only be done for SD programs though, so that sort of defeats one of the purposes many of us here have. We tend to be viewers AND archivists. The general public has been made into viewers only by the content providers and distributors (movie and TV producers, cable and satellite providers). Sad in away...
Doug O is offline
post #47 of 59 Old 02-15-2013, 03:31 AM - Thread Starter
esdwa's Avatar
The MINI does everything that recorder suppose to do allowing you to record any HD program, store it or archive it for later playback. It has unique capability to record through hdmi and it is standalone recorder. it records anything including programs that are refused to be recorded by tivo. Some users are just dissapointed cause it does not allow to copy or rip HD recording to share with others outside your household. Well, if that is your objective than you have to look further. If not, then MINI does all you should expect from typical subscription free high definition recorder. These are three words I can say about mini, convenience, convenience and I repeat again convenience.
esdwa is offline
post #48 of 59 Old 02-15-2013, 08:02 AM
Kelson's Avatar
Quoted: 166 Post(s)
Liked: 323
For archiving HDTV, you need to forget this box and consider either TiVo or a media-PC -- I use both and have have quite a bit of HDTV content collected ("archived") on my servers as standard .m2ts files. The simple fact is that DRM is tough to beat. If the broadcast is copy-protected you can record it to your primary DVR (TiVo or HTPC) but it generally goes no further. The only way I know of now to get it into DRM-free form is to send the video out of the component outputs, through a copy-protection removal box and into a Hauppauge 1212.
This may be harsh but IMHO this MagicTV box is pretty worthless in the US market. It is a DVR created for a different region of the planet. In the US it is not a DVR. It does not have a serviceable US tuner or guide. All you can do is spool recordings by first manually programming the MagicTV box to record a time slot then manually programming your STB to switch channels at the appropriate time (assuming it can do that) -- esdwa must have a strange definition of the word "convenience" that includes lots of manual labor and the joy of constant attention to your scheduling. Then there is the very basic issues of how to get one and the cost -- I believe esdwa told me in a PM it was ~$500; for that you get a "grey-market" box with no warranty and no avenue for repair and probably no recourse if you get ripped off. For that money you could buy a TiVo/lifetime or put together a HTPC with WMC and a cable card tuner -- no "subscriptions", US tuners, real DVR's. And in the case of a HTPC/WMC you can buy as many disks as you want to hang off it or on the network to do the same kind of archiving of protected content.
This thread was already pretty much dead. I think it is worth letting it die again.
NOT . . EVEN . . CLOSE
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #49 of 59 Old 02-15-2013, 10:18 AM - Thread Starter
esdwa's Avatar
Originally Posted by Kelson View Post
Blah blah blah...
You assume that everyone who wants to put his hands on HD recording has to become PC gear maniac, meaning he or she will put together an HTPC with WMC, lease a cable card and use it just to record and archive hours of programming which becomes worthless if not shared among others. You admit the DRM is tough to beat meaning that you must be using 3rd party software to rip the recording to make them available for sharing. You bring up some Hauppage way of recording HD which by the way is not a standalone recorder but just external capture card which needs - again a PC to run. Any by the way. cheapest TiVo box cost $150 plus $500 where you pay for non-transferable lifetime service. And if you want to protect your equipment to ensure you will get covered with replacement when it craps out , you have to pay additional fee.
When I compare setting up timer recording with mini with simple one-click reminder on my cable box for the show I want to automatically tune at desired time with your HTPC which requires updates, booting time and periodical maintenance, I choose standalone recorder like mini. You turn it on like regular VCR, you can timeshift and pause live broadcast while you watching and you can record anything you want whenever you want. It's not a brainer, not even for a boy like you. So do not make hard for the others something that is not , especially when you did not even had a chance to use it. I guess your "special" AVS membership comes from your bitter and denying personality which by the way with the way you try to criticize the subject I find childish as much as amusing.
esdwa is offline
post #50 of 59 Old 02-15-2013, 10:34 AM
Administrator
Mike Lang's Avatar
Quoted: 300 Post(s)
Liked: 301
Cool it guys...
Mike Lang
Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Club and help support the site. Help Support AVS Forum Sponsors.
Mike Lang is offline
post #51 of 59 Old 02-17-2013, 07:43 PM
Doug O's Avatar
Two things that do not exist in Canada
1) Tivo
2) Cable card
Back to square one for recording things I want to watch over again unless I want to get a whole house PVR from my satellite TV or cable provider. The new units allow recordings from multiple channels at the same time with playback on multiple devices or home units (up to 4 simultaneously). Not what I want though since I have to pay forever for this system. I can understand where you are coming from for simplification as you don't archive. That's fine though. There are lots of things that I recorded over the years that were never released on DVD/Blu Ray or ran once and were never repeated. In an instance like that, I'm glad I DID make the recordings long ago. But many of those recordings were on tape and are starting to deteriorate. I have to archive them before they are lost forever.
Doug O is offline
post #52 of 59 Old 02-18-2013, 05:48 AM - Thread Starter
esdwa's Avatar
[...] There are lots of things that I recorded over the years that were never released on DVD/Blu Ray or ran once and were never repeated. In an instance like that, I'm glad I DID make the recordings long ago. But many of those recordings were on tape and are starting to deteriorate. I have to archive them before they are lost forever.
If these are recorded on tapes, look for standalone DVD recorders, these are still available in a price range of $100. Some people buy VHS/DVD combos for PC-free tape collection transfer to DVD. No need for HD recorder in such case. Good luck.
esdwa is offline
post #53 of 59 Old 02-18-2013, 07:20 AM
Doug O's Avatar
I have been doing just that since 2003 when I bought a Panasonic E80H for $1200. My last acquisition was a Pioneer 650 in mint condition for $150. Been transferring to DVD/Mpeg 2 for a decade now. High def is reserved for PVR to HDD or disc transfers but other here have also been transferring tapes to h264 formats so I want to see how well that is working. Probably not any better than recording at the maximum Mpeg 2 bitrate, but you never know.
Doug O is offline
post #54 of 59 Old 02-18-2013, 07:35 AM
fallingwater's Avatar
...I do not care about tuner or epg. All I care is to use it as buffer like TiVo without paying premiums or monthly fees...
You've presented an interesting product although one not practical for most US viewers.
I downloaded a manual (for the MTV3700TD-NZ) from New Zealand. A significant problem (correct me if I'm wrong) is that, like a TiVo or Sony DHG used without a CableCARD, it is not possible to add titles to manual recordings. Doesn't this limitation make a confusing mess of what soon would become a long list of recordings?
Even if a version of Magic TV was made compliant with US HDCP laws and was legally sold in the US for around $500 its inability to add titles to manual recordings would be a deal killer for me. How do you deal with that limitation?
fallingwater is offline
post #55 of 59 Old 02-18-2013, 07:45 AM - Thread Starter
esdwa's Avatar
On MTV7000 each recording can be quickly renamed anytime during or after recording has been made. So having multiple hard drives used with long list of recording is not a problem. Not sure about 3700 model though.
esdwa is offline
post #56 of 59 Old 02-18-2013, 08:22 AM
OK; I downloaded the MTV7000D manual from Hong Kong. It's 46 pages long and I'm apparently ignorant; where is the entry about renaming manual recordings?
If a version of Magic TV was 'street legal' for the US I'd be interested.
I've got a couple of S3 TiVos with Lifetime service which are now close to useless because in order to use them with local Comcast Cable, Comcast would charge $9.85 monthly for each (an $8.75 Additional Outlet fee + $1.10 for a 2nd CC) which just isn't worth it!
post #57 of 59 Old 02-18-2013, 09:00 AM - Thread Starter
esdwa's Avatar
Indeed this manual is missing "Rename programme" option which should be listed on page 54 among other available options listed in table on said page. I use this option all the time.
esdwa is offline
post #58 of 59 Old 01-31-2014, 04:00 AM
Karthik Raju's Avatar
my basic need for this recording device is to record my laparoscopic procedures(i am a surgeon) which come from my scope unit as HDMI output. i don't think the output will be encrypted and the output is 720p. Can i record with MTV and edit it by transferring to my PC. Because the HDMI output will not be encrypted....
Karthik Raju is offline
post #59 of 59 Old 02-05-2014, 04:22 PM
pacofortacos's Avatar
For your needs the newer Hauppauge HDDVR should work perfectly - if the output from your scope is completely open. It will record to your pc or better yet an external usb drive, in one of 3 formats - all pc friendly.
pacofortacos is offline
Reply HDTV Recorders
User Tag List
